Question about Siemens Washing Machines
SIEMENS WASHING MACHINE S12-38 DOOR WILL NOT OPEN
kjmac
  • 97 Answers
SOURCE: washing machine
is all the water out of the machine if not the door wont open.
if all the water has gone, have a look behind the small flap on the front of the machine where the filter is and there might be a small plastic loop which when pulled should release the door catch.
please note i say might as some models have this feature and some dont.
hope this helps
Posted on Jul 25, 2008
  • 3600 Answers
SOURCE: Washing machine front loading door won't open.
that is the way it's made you have to turn it off before you can open it or water would go every where.
Posted on Aug 20, 2009
SOURCE: my siemens washing machine S14.39 keeps stopping a...
Hi
It is your pump that is failing / bolked with hair and treds behind the impeller. The pump is not the best design as ther can enter smal treds and hair behind the impeller into the paking ring (seal). There is only one sollution that help - change the pump. Can be don from the fron of the mashine. Only one screw on the right side has to be removed to remove the plastig cover and the one screw to losen the pump.
Posted on Aug 22, 2010
rickead1
  • 1998 Answers
SOURCE: I have a Siemens WM14S794GB
F-23 is an error due to an internal leak inside of your machine this is usually due to a bad seal between the inner and outter tub also if done by a technician a very costly repair in which they usually charge 4-600 for the repair itself includeing the parts. If you feel you are capable of doing the repair the parts are the inner and outter seal and sold as a kit usually for around 90-110 dollars and you can find the parts at www.marcone.com under contact us there is a 1800 number as well as an overseas number if you have any further questions message me back and please remember to rank how this opinion has helped it allows me to help others in similar situations when our chat has fully concluded Thanks Rick
Posted on Feb 21, 2011
  • 6277 Answers
SOURCE: how do you deactivate the
Couple of things-
Just in case no-one else answers (I don't know how to release the child lock on your particular machine) methinks you need a manual! You will need to type into your search engine/web browser '(make model number) washer manual' and you should be presented with a number of sources from which you can either download for free or have to pay a nominal amount.
You could also try the manufacturer's web site direct ;-0)
Now- is it showing 'child lock' on or just not releasing the door?
If it's just the door I would gently suggest as a first step that you clean the drain motor/pump lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to spin or release the door lock if there is any water still left inside.
Here are my complete and generic guidance notes for checking both the drain motor filter and the drain motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!). These panels are either held on by (plasic) screws or will just pull off. Most filters are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play.
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT.
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning.
If these have assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Posted on Jun 16, 2011
Siemens front load washing machine. Cloth stuck between the door and the panel. Can't open the door. F23 appears.
the tub beneath the washer is full and is not draining. the clothes have probably opened up the seal between the door and washer allowing water to leak. tip the machine and empty the sump to clear error.
Jun 09, 2016 | Siemens Washing Machines
What does f26 mean for siemens washing machine
F26 come up This error code indicates that the door needs to be opened and closed.The F26 code may appear the first time you try to use the washer. Open and ...
Jan 03, 2016 | Siemens Washing Machines
Have any idea how to open the washing machine door iQ700 Siemens
Wait for cycle to fi?ish, plus another minute or so. Then activate door release. If this fails I suggest that you have the machine looked at by a technician.
Jul 16, 2015 | Siemens Washing Machines
How to open front door Siemens iQ500 washing machine?
if the door is locked shut the inter lock needs replaced u will have to take lid off
Apr 26, 2015 | Siemens Washing Machines
Door of Washing machine doesnot opened
the door interlock has failed
other then try to leave it off and struggle with the door
you need sometimes to release it from behind
not easy sometime with some machines
the replace the door lock interlock catch
it will work fine then
Sep 19, 2014 | Siemens Washing Machines
Broke handle off of siemens TOP WD1200 champion, the settings are all in chinese and my clothes are locked inside. help?
This is a common and easily fixed problem. The door should NOT be opened after the wash is completed. You have to wait for AT LEAST 2 minutes to try the door, do not use force. There is a built in mechanism for most front loaders to delay the door opening, so be patient.
If you have used force you have already damaged the door lock, so replace. You are lucky if the door can be opened after the lock sign goes off - otherwise you just have to change the door lock.
Click if helped.
Mar 30, 2013 | Siemens Washing Machines
How to open the door of the siemens iQ300 washing machine
This problem has nothing to do with water in the machine. My IQ300 regularly refuses to open on the drying cycle! You have to open the small round compartment beneath the door and pull down on the black plastic strap to the right - you may need a utensil to pry it out. What a rubbish machine.
May 29, 2011 | Siemens WIQ1633 Front Load Washer
Washing Machines Logo
143 people viewed this question
Top Siemens Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Siemens Washing Machine Expert? Answer questions, earn points and help others
