Question about CookTek MC3502F MagnaWave Double Induction Cooktop
Cooktek error code e 4 - CookTek MC3502F MagnaWave Double Induction Cooktop
What does error code E-13 mean
Hello there
Sounds like a 'gas sensor' (whatever that is) error. I recommend calling Samsung Support or a qualified Microwave Technician
SMH2117S/XAA Microwave Is Displaying An Error Code If your microwave is displaying an error code, such as -SE-, E-11, E-12, E-13, or E-14, or any other trouble code not listed here, cycle the power to the microwave by either unplugging the unit, or cycling the circuit breaker for approximately 60 seconds before restoring power.
If the above suggestion does not work,and the error code returns, your microwave will require service.
namo_fileview.jsp?type=nfs&pid=decisiontree&did=466719&cid=5uwnecasicas@namo.co.kr&sep=%7c
Sep 21, 2014 | Samsung SMH2117S 2.1 cu. ft....
Whirlpool error code e2 f3
The error codes are in the operating instructions if you don't have it ask Bosch to email the error code page to you.
Apr 10, 2014 | Bosch Cooktops
Electrolux induction hob stripdown
there should be screws at the back loosen then push forward and that should do it x
Sep 25, 2012 | CookTek Magnawave 3500W Single Hob...
Electrolux cooktop E14 error
Hello Winnie - Error code 14 means that there is a communication failure with the key sensor for cook place 4 (left position) - right board. Base on the intensity of the issue; contact a professional technician to diagnose the following: Test flex cable between boards, change right board, change center board (on 36" models only), change left board.
Sep 23, 2012 | Electrolux 30" Built-In Electric Cooktop -...
Error 11 Electrolux induction cooktop
You will need to consult a professional to have the following repaired:
1. Test flex cable betweenboards.2. Change right board.3. Change center board (on 36"models only).4. Change left board.
Jul 23, 2012 | Cooktops
How to repair the twoo burner cook tek not functioning?
Here is a tip that I wrote to help people troubleshoot problems with their cooktops not igniting.
Cooktop Range Stove spark ignition does not work
http://www.fixya.com/support/r5649407-cooktop_range_stove_spark_ignition_not
heatman101
Jun 01, 2010 | CookTek Cooktops
I have a kenmore gas range and on the display is says EO F2
The "F2 - E0" error code means "Shorted keypad".
Remove power from the range, open the control panel and unplug the membrane switch ribbon from the control board.
Reconnect power to the range and observe for an hour.
If the error code reappear - replace the control board.
If not - replace the membrane switch.
If I get the model # I can help you pind the right parts.
Good Luck and please rate 4 thumbs for the free answer
Apr 17, 2010 | Kenmore 30 in. 32384 / 32385 / 32389 Gas...
F2 error after oven cleaning came across my display. I had to throw the breaker. Is this something that can be easily fixed?
Long Drain
If the drain time exceeds 8 minutes, the water valves are turned off and "F/02" is flashed.
NOTE: After 4 minutes the "Sud" error will be displayed, then 4 minutes later the F02 error code will be displayed.
Press PAUSE/CANCEL twice to clear the display.
  • Check the drain hose and make sure it is not plugged or kinked.
  • Check the electrical connections at the pump and make sure the pump is running.
  • Check the drain pump filter for foreign objects.
  • If the above does not correct the problem, replace the pump.
Mar 09, 2010 | Jenn-Air Cooktops
Whirlpool induction ceramic cooktop error E6
my induction ceramic cooktop is showing an error code E6 on two of the elements...what is the problem and how do I get it fixed
Dec 15, 2009 | Cooktops
CookTek MC3502F MagnaWave Double Induction Cooktop Logo
130 people viewed this question
Top CookTek Cooktops Experts
Dan Webster
Dan Webster
Paul Carew
Are you a CookTek Cooktop Expert? Answer questions, earn points and help others
