Question about Garden
Need to know iniatial settings of carb adj.
How to set carb adj after assembling carb
    Sergeant:
  • 458 Answers
Gently turn the needle valves in till they stop. Then turn eachvalve one full turn out.
Posted on Apr 29, 2014
3 Suggested Answers
  • 149 Answers
SOURCE: need initial carb adjustments for both high and low adj.
start at 1turn out on both that should grt it running from there..
Posted on Jan 31, 2009
dontbother10
  • 2220 Answers
SOURCE: need carb setting wont idle runs in spurts
There is usually a sticker with a craftsman Model Number on it, often "358.Something". That number can be used to find an IPL and if you are lucky an OM here: Sears PartsDirect http://www.searspartsdirect.com/partsdirect/index.action Start at 1.5 CCW from lightly seated then tune for performance like this:
Carburetor Adjustment by Madsens.com
http://www.madsens1.com/saw%20carb%20tune.htm
CW is leaner; to lean will destroy the saw. If over tightened closed (CW) the adjustment screw faces are easily marred; marred adjustments are difficult to impossible to set properly.
Clean the air filter; adjusting with a dirty filter can cause a run lean condition once cleaned and the saw run.
There are 2 wav (sound - idle & full – may not be highlighted) files that I find most helpful, I think you will too. HTH
Lou
Posted on Feb 20, 2010
Carb setting on cs 510 evl?
Hoping this is echo? If so screw L and H all way clockwise till stop then back each out 1 1/2 turn. Start and let warm up hold throttle to max rpm and adj. The H to max rpm then let idle and adj. L until it idles good and has very little hesitation when throttle is squeezed fast. Then adj H again to max rpm and then back off until it sort of growls not squeel.
Nov 17, 2017 | Garden
Craftsman 16"what is the starting carb adj
Gently turn both carb screws in all the way. Then turn each out one turn. The fast screw is marked with an H and the slow is marked with an L.
Jun 25, 2014 | Craftsman sears 18" Chain Saw Chain (...
Got carby off how do clean jets properly??
Very carefully, all your parts need to be taken care of, the honda shop doesn't sell complete kits anymore, they sell the parts you need, only, so you need to know what you need. The jets have tiny o rings on them that only come with carb parts, so protect them, the jets need to be wired out with a guitar string, .009, you can get one from a music store from the garbage can, unless you play. Clean them out so that you can blow through them, make sure there is no rocks in there, no turpentine, no gunk, soak them in carb cleaner, then reassemble, There is no adj on them, they are fixed. If they don't work you need a different jet. I bought a kit from dynaflow, adj jet kit for my bike, the factory set jet didn't do diddly, but the dynaflow worked great, Hope this helps.
May 27, 2011 | 2005 Honda CRF 230 F
I have a 1994 xcr440 liquid cooled sled carb settings
YOU DONT NEED SETTINGS TO SYNC CARBS. YOU NEED A CARB SYNC GAUGE. TURN THE SYNC SCREW UNTIL BOTH GAUGES READ THE SAME! AS FAR AS THE SLOW SPEED ADJ. USUALLY 2-2.5 TURNS OUT FROM BOTTOMED WILL SUFFICE.
Oct 20, 2009 | 1988 Yamaha XV 535 Virago DX
My john deere 1600 weed trimmer starts fine cold, then runs on high speed for several minutes then dies .Then will not start.I cleaned spark plug, checked proper oil/fuel mix, cleaned air filter,tightened...
Your fuel low fuel high adj on carb arent set right. one is for idle and low running while other is for high rev. Getting these set just right is very tricky and takes some time doing it to become good,Im starting you off on a crash course,Im not gauranteeing anything but here it goes. LOcate the two fuel adj. screws on carb,if they have plastic caps on top remove them with needle nose pliers so the screws themselves are exposed. Next,I want you to take a screw driver and turn both in all the way till they stop. Now take and turn each one out counter clockwise three full revolutions. Now start it to see if theres any improvement. (Note: further adj. may be required you may have to consult an expert to have it be done for you if you cant get it).
Aug 02, 2009 | Garden
Need to know how to set up carb on 1985 johnson outboard. front adj on the carb got moved looking for starting point to get me close to running.
try disconnecting the throttle cable, loosen carb linkages, assure that both carbs are FULL closed....tighten linkage - and cable ...check for FULL open and close with the throttle....this will be your starting point, advise to get a service manual for your outboard model to correctly adjust the carbs for max performance....GL hope this helps..
Jul 04, 2009 | Sport & Outdoor - Others
When givin throttle dies
if they are not capped with limiter caps
you can try this turn both adj. cw with a small screwdriver until
they bottom out do not force once they stop turning
now back them out 1and1/4 to 1and1/2 ccw
that is the approx. initial setting.
May 28, 2009 | Ryobi Garden
Engine runs but wont idle!
set you carb adjustments at 1 1/4 and try that
Jan 30, 2009 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Need initial carb adjustments for both high and low adj.
Jan 23, 2009 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
