Question about Fein Multimaster Rs - Msxe 636 - 2 Rs
Variable speed not working - Fein Multimaster Rs - Msxe 636 - 2 Rs
How to replace bearings
If you cannot work out how to pull it apart by looking at it, you are probably better to take it to a Dewalt repair centre and have then do the repair. They make good equipment so it is worth spending the money to have a professional do the repair.
Feb 25, 2016 | Dewalt Get the lower price on DW625...
My Ryobi RBV3000vpc will not start
Sounds like a bad switch. Possibly a loose wire.
Mar 08, 2015 | Ryobi RBV3000VP Variable Speed Electric...
How to get a rag unclogged from electrolux hose?
If you have a plumbing 'snake' and an AC variable speed drill, mount the snake (remove handle if present) in the drill and try to get the tip entangled in the rag.
Use a slower speed and once the rag drags down the drill's speed, pull on it and it should free the rag.
Worked once for me-
Jun 07, 2014 | Electrolux Canister Vacuum Cleaner Lock...
My 250q surges speed control doesnt work
Fein 30762198013 but first before replace try to clean the variable resistor with a contact cleaner or wd40. and blow it out of dirt little chance sometimes it can help.
Mar 30, 2014 | Fein Multimaster Rs - Msxe 636 - 2 Rs
Dw621 pulsing speed problem
Try to start it at various speeds. Use contact cleaner on the switch, and the variable speed control resistor.
Mar 02, 2014 | Dewalt DW621 2 HP Evs Plunge Router W/...
I CAN'T TURN MY VACUUM ON.
Use the button on the canister to turn it on but make sure the variable speed is also turned on.
Mar 11, 2013 | Fuller Brush FBPTCAN Bagged Canister...
Miele canister keeps shutting off when i press + it starts again for short while and off again whats problem i have changed bar but still no good
Was it hot when you pressed "+" button? Did you check the filters(Hepa) or bag if clogged or suction path was blocked? Does it happen after it was cool down? From what you said, it seems none of the above. Only thing I can think of is circuit board. The mortor runs in variable speed. "+" increase the average voltage to the motor thus higher suction. PWM circuit in main pcb may not working correctly.
High priced vacuum cleaner like this shouldn't fail like this but it does. JMO.
Nov 07, 2010 | Miele S548 Bagged Canister Vacuum
Miele vacuum cleaner not working properly
Is the suction low or ok at the vacuum without the hose attached? If it is ok, then there is a clog in the hose. If it isn't, then check filters, is the speed variable, is the contol set too low. Could be a bad motor, running too slow.
Mar 05, 2008 | Vacuums
Motor stops running after a few minutes
One thing you could have a bad motor control, part #05408630, mounted by the motor, the other could be a bad variable speed control, part #05412914, it is on top near the back.
Dec 08, 2007 | Miele s558 Silver Moon Vacuum
Fein Multimaster Rs - Msxe 636 - 2 Rs Logo
Top Fein Vacuums Experts
Bill Boyd
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Fein Vacuum Expert? Answer questions, earn points and help others
