Question about Rex RX-07
Not sure if it's threaded right - Rex RX-07
Ho are do i thread my machine but the thread keep coming ot of the needle
do you have it threaded right meaning make sure that the thread is through all the loops then check to make sure the needle is in right
Oct 07, 2014 | Sew Pro ZZ401 Sewing Machine
I can't get the tension right
try rethreading the machine--use every thread guide
make sure the top thread has not come off the thread take up lever
change the needle --make sure it's the right one for the fabric
being sewed
make sure the bobbin is turned the right way in the bobbin case
if the bobbin is a front or side loading also make sure the bobbin
case is inserted correctly into the machine
if none of these suggestions help then the machine needs to be
checked to see if it's a timing problem
Dec 14, 2012 | Sewing Machines
Thread balling up at start
make sure the thread has not come off the thread take up lever
try a new needle
make sure the bobbin is turned the right way and inserted the right
make sure the bobbin is not over full
make sure the bobbin is not warped
Nov 08, 2012 | Sewing Machines
Thread nests
try changing the needle--make sure the needle is turned the right
way--and that the needle is the correct one for the fabric being
sewed--example--cotton fabric take one kind of needle and stretch
fabric take another kind of needle
try rethreading the machine top thread and bobbin
make sure to use every thread guide
if the bobbin and bobbin case have to be inserted togeather,,
make sure that the bobbin case is secure and snug in the machine
make sure the thread does not come off the thread take up lever
Nov 04, 2012 | Brother InnovIs 4000D Computerized Sewing...
Lower bobbin thread gets tangled
try changing the needle --make sure the needle is the right one
for the fabric being sewed
try a different thread
make sure the bobbin is not over filled
Oct 04, 2012 | Brother XL-3500
Lower thread is coming up double
try changing the needle--make sure it's the right one for the fabric
being sewed
rethread the machine top & bobbin
make sure the bobbin is inserted correctly into the bobbin case & also
turn the right way before it's inserted into the bobbin case
make sure the top thread hasn't come off the thread take up lever
Oct 03, 2012 | Janome Sewing Machines
How to thread a Frister and Rossman 35
Presser foot up, takeup lever at the top, thread on the top spool pin, take the thread to the left and over the top guide, straight down the right hand side of the tension and go round it making sure the thread goes between the discs, up the left hand side to the takeup lever, thread the takeup lever right to left, take the thread all the way down to the needle going through any guides on the way, thread the needle left to right, make sure the flat side of the needle is facing right.
Mar 22, 2010 | Sewing Machines
Thread not picking up bobin tread
not sure which model you have, the best thing is to re thread the upper and the bobbin, make sure you put the bobbin in the right way. if you have the tenson on the front of your machine make sure the thread goes between the disks and correctly goes around the spring tension wire the right way it should be under it after lifting up on the thread.
if the bobbin is in wrong the thread will not be pick up try flipping it and turn the hand wheel by hand to bring up the thread,
Sep 04, 2009 | Necchi Sewing Machines
How to thread necchi 537L sewing machine
From the reel pin take the thread to the left and over the top thread guide above the takeup lever, make sure the takeup lever is up and and make sure the presser foot is up, take the thread straight down and round the right hand side of the tension unit and back up the left hand side to the takeup lever, thread the takeup lever right to left and take the thread down any guides to the needle, if the bobbin case goes in the front thread the needle front to back, if the bobbin case goes in the side thread the needle left to right.
Jun 09, 2009 | Necchi 3101 Mechanical Sewing Machine
Machine not sewing
Make sure you have threaded the machine from right to left, it sounds like the needle thread is trapped under the lower looper thread and cannot form a stitch.........start the threading over from scratch like this:
  1. Lower Looper
  2. Upper Looper
  3. Left Needle
  4. Right Needle
Is there a diagram for how to thread on the inside of the door ?
Follow that slowly and carefully to make sure you have not missed any thread guides on the way, as each one needs to be followed through to ensure correct tension and thread progression.
If you are certain that all threaded correctly, did you have a fabric jam and pulled it loose ? If so, the timing may well be affected.
Post an update and we'll get this right.
Bargain Box
Feb 01, 2008 | Sewing Machines
Rex RX-07 Logo
18 people viewed this question
Top Rex Sewing Machines Experts
Jim Goldsmith
Jim Goldsmith
ray gallant
Joseph Mueller
Joseph Mueller
Are you a Rex Sewing Machine Expert? Answer questions, earn points and help others
