Question about Poulan Garden
Chain saw starts then quits wont run
4620avx chain saw poulan brand
    Sergeant:
  • 415 Answers
Sounds like the fuel pump diaphram in the carb. It is a small film membrane that will stretch over time. A rebuild kit should solve this problem.
Posted on Jul 02, 2014
  • 211 Answers
SOURCE: chain saw starts then dies shortly after
hi
I think you have a carburation problem.Carefully disassembly the carb and clean it.Check the fuel line and filter,the ventil of the gas tank.
regards savumihai71
Posted on Dec 02, 2008
Idaho_Biker
  • 32 Answers
SOURCE: 38 cc Poulan Chain Saw
Since You weren't Model Specific...I assumed you meant a Poulan Pro 38cc, here's a Contact Site for OEM Manuals:
http://www.poulan.com/poulanpro/manualSearchResultsAJAX.do
Posted on Jan 18, 2009
  • 2692 Answers
SOURCE: poulan chain saw won't stay running
Carburator needs to be removed and cleaned.
Posted on Feb 15, 2009
dontbother10
  • 2220 Answers
SOURCE: I need t find an air filter for poulan 306a chain saw
I got 1 hit for your filter, if you haven' already give them a try "Poulan air filter 530023046"
http://www.lawnmowerpros.com/Poulan-Parts-Search.asp
Lou
Posted on Sep 05, 2009
  • 15 Answers
SOURCE: 18"poulan chain saw wont rev up
either the carb has dirt in it and needs cleaning or the muffler is choked up take of the muffler to see if it is clean
Posted on Oct 19, 2009
How to tighten chain on 4620avx poulan pro
First, RTFM- read the manual. Lost it? No problem, download it from Poulan PRO website page for PP4620avx. Pick a version you like, save and read it. Google is your friend.
Chain Adjustment Part cut and pasted as follows:
Adjusting the tension:
Chain tension is very important. Chain stretches during use. This is especially true during the first few times you use your saw. Always check chain tension each time you use and refuel your saw.
1. Lift lever on bar knob and turn counter-clockwise 1.5-2 turns to loosen clutch cover.
2. Turn adjusting wheel (downward direction) to tension chain until chain solidly contacts bottom of guide bar rail. Lift tip of guide bar while adjusting tension. Tighten chain Adjusting Wheel
3. Use a screwdriver to move chain around guide bar to ensure all links are in bar groove.
4. While lifting tip of guide bar, tighten bar knob securely (clockwise).
Hand tighten only.
Be careful not to destroy the adjustment mechanism. When it breaks, go for a clutch cover with the simple adjuster that needs a "scrench". Longer term, learn how to search this info. Saves time. Now you can work on sharpening chains- very important.
Manual page:
http://www.poulanpro.com/ddoc/PPOO/PPOO2006_USen/PPOO2006_USen_PP4620AVX_952802146.pdf
Jul 21, 2014 | Poulan Pro Chain Saw 46cc 20"
Brand new poulan pro 4620avx--bar oil is coming out of oiler but not getting onto chain
Hello. Thin your bar oil just a wee bit with some kerosene. If you have a gallon of bar oil add 1/4 cup of kerosene, stir it up and you will be fine. For starters also, directly apply some bar oil to the chain so that you are always using a well lubed chain. Joe
Oct 03, 2010 | Poulan Pro Chain Saw 46cc 20"
Specs on 4620avx chain
Both questions are answered on page 16 here (if original chain):
http://weborder.husqvarna.com/order_static/doc/NOUS/NOUS2010/NOUS2010_545186802.pdf
Quite a few of the questions on this page apply to your undertaking.
http://www.oregonchain.com/pro/service/faq.htm
Please take few minutes to read any that may remotely apply. A few minutes spent here may prevent the frustration of a chain that will not cut straight through teh log.
If you have more questions or need additional help please reply below and I will get back to you. HTH & Good Luck.
Lou
Thank You for using FixYa.
May 02, 2010 | Poulan Pro Chain Saw 46cc 20"
Chain saw won't start
Check the fuel filter for plugging (which is common when fuel is left in the machine over winter storage). You should run the carburetor dry after emptying the fuel tank for storage.Hope this helps!
Apr 14, 2010 | Poulan Pro Chain Saw 46cc 20"
I have a Poulan 2450 chain saw which runs great for awhile and then won't run or start. I checked for spark on the plug and none there. A week went by and I checked it again and now it works. So I...
It does happen they quit when hot. More often they just quit.
There are 7 different "2450 Gas Saw Types" here: (Type 1 $25.35)
Poulan.com
http://www.ordertree.com/modelinfo/POULAN-WEED-EATER/75.59.html
There is a help link on top that will eventually find someone with a pulse. If you go this way please have your saw within easy reach before calling. HTH
Lou
Good for you on the spark test and isolation of the problem. You also listed the make and model. I think I'm in love, LOL.
Thanks, it makes our help easy.
Oct 19, 2009 | Poulan Pro Chain Saw 46cc 20"
carbs dirty need cleaning. try adding some stabil you can buy at auto zone with fresh fuel it may clean itself out w/o having to remove the carb.
Sep 14, 2009 | Poulan PP4218AV 18" Chain Saw
Poulan 46cc has very little power
you need to adjust the gas an air on those two little screws on the carburator
Feb 03, 2009 | Poulan Pro Chain Saw 46cc 20"
Garden Logo
85 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
