Question about Confidence Power Plus Motorised Treadmill
Display pannel not working - Confidence Power Plus Motorised Treadmill
Why isn't the display panel working?
What part did you replace? Can you still print to it? What model is it?
Jul 03, 2015 | Xerox Phaser 7400DN Laser Printer
Sony dtc 77es
This usually caused by a defective state sensor on a DAT type deck.
They are sensitive to smoke contamination. They might be possible to clean and recondition if the sensor was taken out.
Apr 25, 2014 | Audio Players & Recorders
Display is not work
Try plugging in the monitor.
Mar 13, 2014 | Computers & Internet
The display on my oven is not working at alll!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
mine did the same thing. the contol pannel is bad. sears.com has a replacment pannel. here is the parts number. 5765M433−60
if the door is locked then try the unlock metod. it also will lock the screen from working. press and hold both cancel-cook&hold buttons at the same time for 3 seconds. if it works your in luck. if not it will cost 190.00 for a new pannel. cheers.
Dec 21, 2010 | Maytag MEW5530D Electric Single Oven
GE refrigerator, the temp display was flickering,
If you are careful and can acess the pannel easily sometimes the pannels are hard to get off, and it would be good for you to have a ohm volt meter and no the safe way to operate around live voltage when testing.
Jul 28, 2009 | GE Refrigerators
Display pannel does not display/work
I had the same problem... fading on the display. Replaced the display internal panel. It is a common part with other major appliance manufacturers. The problem was corrected.
Mar 23, 2009 | Jenn-Air JJW8527C Expressions Collection...
Canon ir 3300 xerox machine display board not working
dispaly and pad is not working who to open it tell me the codes
Feb 13, 2009 | Canon Office Equipment & Supplies
I change the memory ic of lg 700e monitor the control pannel menu not displaying in english?
1. replace the control panel Micro switchs.
2. replace the 7805 reguletor near to control proccer.
Oct 14, 2008 | LG Studioworks 700S 17" CRT Monitor
Compaq Persario V2000 Black (very dark) Display
Hello Bigkahn, The problem you have is related to the power inverts that powers on a small fluorescent light on the bottom of the actual LCD pannel. The "display" is composed of mainly 2 parts. One is the TFT active matrix that is build up by using many transistors. There are 3 of them for each pixel, each transistor displaying one basic color (RGB code red-green-blue) and 3 of them, like i said, forming a single pixel. They don't produce light by themselves they only filter the light that pass through the TFT pannel. So if a transistor displays "green" it will do that by filtering the light that comes from the fluorescent lamp i was talking before. It produces white light so therefore the transistor pannel will filter the coresponding wave lenght to block anything else than "green". (white light is a combination of all spectrum lenghts) Therefore in your case, if you light up the display using an external light, you may see something on it because the pannel will try to filter the light you give to it. This shows that the actual transistor matrix is working. Your problem is like i said, related with the power inverter. It'a small device inside your laptop that will raise the tension given by the batteries to about 2-3000volts needed to fire up the fluorescent light (some kind of "neon"). If it doesn't work that light woun't come on and the display woun't light up therefore the transistors on the pannel woun't have anything to filter and display on the screen. This problem can happen because of either a faulty connection between the inverter and the fluorescent lamp, or the inverter to the mainboard. Another cause can be the hardware failure of the actual inverter that is preventing it to raise the tension to the specified values. Either of these will require you to have your laptop checked at a service center because we are talking about tensions ranging 2-3000Volts and sensible component. This shouldn't be an expensive repair because the actual pannel (the screen) is working fine and all that needs to be done is to check the inverter or replace some components relating to it. If you have further questions please feel free to reply to this. Good luck.
Apr 04, 2007 | HP Compaq Presario V2000 Notebook
Confidence Power Plus Motorised Treadmill Logo
57 people viewed this question
Top Confidence Exercise & Fitness Experts
ray gallant
Electro Med Services...
Are you a Confidence Exercise and Fitnes Expert? Answer questions, earn points and help others
