Question about Hobart H600 Stand Mixer
H600t set screw in the head gear is loose and will not form a proper connection
60 qt Hobart mixer H600T makes buzzing noise and won't spin. The hook seems blocked, can't spin it manually. Opened the top part and everything seems fine. What can it be and how to fix it? Thank you
call in an electrician as it may be the start/run capacitor for the motor ( indicated by motor humming but not running)
the gearing will make it very difficult to turn the blades by hand as the motor will be spinning at either 1400 rpms or 2400 rpms down to around 50 rpms for the blades
Jun 30, 2016 | Hobart Food Mixers
I have a kitchenaid K5SS. The beater keeps hitting the bowl even after adjustment screws was adjusted. What else can I do to fix problem
Check the four large screws at the back of the motor housing. They screw up thru the pedestal into the gear/motor housing. If they are loose that can allow the motor to tilt forwards. Check also the ones under the pedestal base, I have never seen those ones loose though and they would not cause your problem.
Mar 24, 2014 | KitchenAid K5SS Heavy Duty Commercial...
Breville mixer
A long screw driver for sure and a magnet
on a stick to pull the screws up.
Once the bottom is off the rest is easy.
Take your time, a lot little things to undo
but easy. Enjoy
The Gears
breville-mixer-5cd23g4f5wgf02ym52jckcyw-5-0.jpg Remove and fit the bearing caps one at a time to keep the head in
swing position.
breville-mixer-5cd23g4f5wgf02ym52jckcyw-5-3.jpg Use needle nose pliers to remove this plug, just wiggle it out.
Don't pull on the cable
breville-mixer-5cd23g4f5wgf02ym52jckcyw-5-6.jpg Opps
breville-mixer-5cd23g4f5wgf02ym52jckcyw-5-15.jpg A belt sander works for this.
Apr 03, 2012 | Breville Food Mixers
Mixer head loose
Turn the mixer upside down and you'll see the screws up inside that hold the head to the base. You'll need a long screw driver.
May 15, 2010 | KitchenAid KL26M8XOB Stand Mixer
Cant adjust flat beater so it wont hit the bowl,when trying to the head of the mixer is too loose
all tilt head mixers pivot on a pin which goes thru the head and the base. This pin is held in in place with a screw which you can access from underneath the base. Try tightening the screw and see if that tightens up the the loose head.
If the looseness is in the gear head then the five screws which hold the top and bottom halves of the gearcase together. Remove the chrome ring by gently prying it off, then drive the pin out which goes thru the planetary housing and the shaft and drop the planetary housing to access the 5 (item 19) screws.
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%208212010.pdf
Apr 05, 2010 | KitchenAid Artisan Series Tilt-Head Stand...
I took out the side bolts and removed the top, now have no power to unit. did I put it back wrong? Problem I needed to address was the paddle was too low and scraping the inside of bowl. Help with both...
sm_schedule, the side bolts you removed were, in fact, the brush holder caps, and if you remove the brushes, you cut off the power to the electric motor (armature). I suspect that one or both of the brushes is (are) not seated properly. Did you remove the brushes to replace them or were you just inspecting them? I'd suggest removing them again and make sure the concave contact face of the brushes are resting completely on the armature. If you've turned a brush 90 degrees too much, it wont' seat properly. As far as adjusting the mixer head so that it doesn?t droop, this should be pretty easy to fix if you?ve got a small blade screw driver and a small hex driver (or jewelers screw driver). First, do you still have the KSM90 Parts List? If not, you can download a PDF version from the KA website. Click on Customer Care>Locate Manuals & Guides> Enter the 6 character model number (in your case, use KSM90P) and select one of the files that appear under Parts List. Turn to page 4 - Case, Gearing and Planetary unit, which shows the exploded view diagram and locate Illus. Nos. 29 & 30. Page 5 lists the parts as Adjusting Screw and Set Screw respectively. What?s probably happened is that over 12 years of operation, the vibrations from your mixer has caused the set screw to loosen and drop, hence the lower mixer head. Both screws will need to be ?adjusted? to move the head back to its original position. Now the problem is removing the head from its pedestal. Turn to page 8 and gently remove Illus. No. 7, Hinge Pin, with a hammer and pin driver. With the hinge pin removed the mixer head and pedestal can be separated and you should have access to adjusting and set screws. I would inspect them for wear and tear, and replace them, if you deem appropriate. It may take a few trial reassemblies to get the mixer head back to the original factory position, but once there, everything should be OK. I hope this helps! Howard, Burke, VA
Oct 21, 2009 | KitchenAid KSM90 Ultra Power Series Stand...
The motor is loose a little and needs adjusting up, because it hits the bowl when in motion.
I think from your description that the the head connecting to the base shaft needs tightening. Put the mixer on it's side UNPLUGGED. Look up inside the base and you'll see a small set screw.
With a flat blade screw driver tighten that screw and it should stop moving. If it doesn't you probably need another shaft because it's worn. If after tightening it stops rocking but it still hits the bowl there's another screw at the front, on top of the neck under the head. Turn this until it clears the bowl. Good luck!
May 01, 2009 | KitchenAid K45SS Classic Stand Mixer
Taking the top off my kitchenaid mixer
Remove the back housing by removing one screw and liftingand pulling rearward.
Remove two screws holding the metalic edge trim. This uncovers the seam. Screws are on the back.
Remove four visible screws from the bottom of the head around and near the pillar.
Now gently using a screw driver, push the metallic ring on the mixing head down and off.
This uncovers five more screws about the mixing head. Remove them.
Using a very small screw driver or punch, puch the pin out of the mixing head shaft.
Remove the mixing head housing.
Lift up on the motor housing to remove it.
The motor/gear housing is the top protion of the mixer. Its loaded with grease so do this over a covered countertop or some place easy to clean. The grease won't run, but it can fall out in gobs.
Make sure all sealing surfaces are clean, especially the gasket around the gears. This will insure a good seal. No gear grease in your famous cookies!
Reinstall in reverse.
Feb 03, 2009 | KitchenAid KSM150PS Artisan Series Stand...
What type of oil is used in hobart-h600
hi / I have to chang hobart mixer h600t oil seal on the end of dough hook , but not sure how ? please let me know if any one
knows about that
Jun 23, 2008 | Food Mixers
Hobart H600 Stand Mixer Logo
19 people viewed this question
Top Hobart Food Mixers Experts
Ross Keen
John Tripp
John Tripp
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Hobart Food Mixer Expert? Answer questions, earn points and help others
