Question about GE Refrigerators
How do I access the drain on a GE Arctica PSS25SGNABS side by side fridge. Water keeps pooling under the bottom drawer and fills up every couple days.
  • 183 Answers
SOURCE: Kenmore / GE side by side defrost drain keeps freezing up
Check under the base, the tube must be clear to the water tray, often there is a rubber flow restrictor, this either perishes or blockes, either way remove it, defrost over night and then turn back on, should then work ok within 24hrs. Regards Adbvisor
Posted on Aug 23, 2007
fridgetech
  • 473 Answers
SOURCE: clogged fridge drain tube
The drain is behind the back panel in the freezer at the bottom. Sounds like it is frozen over which is pretty common. Will need to remove panel and thaw out drain by running hot water down. You can use a putty knife to break up ice first. Make sure you get all ice around the drain above and below the thin aluminum tray at the bottom. After the drain is free don't be alarmed if you get some water on the floor because the drain pan may not hold all of the water you ran down the drain. Not anything you can do to prevent this on this model.
Posted on Oct 07, 2007
  • 219 Answers
SOURCE: ge profile water/ice fridge side under bottom drawer
take out the back panel in frzzer side use a steamer to clean out your drain hole
Posted on Mar 19, 2009
woodchuck789
  • 4059 Answers
SOURCE: Model TBX21KLK water pooling UNDER vegetable bins
Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the freezer.
Posted on Sep 21, 2009
  • 256 Answers
SOURCE: We have an old GE
Normally on the older models the door seals start to fail. If that happens, condesation builds up in the fridge and water starts building up. You will not always be able to see exactly where the seals are perished, but once changed, your problem should be solved. Hope this helps
Posted on Aug 22, 2010
I have a 2002 GE Arctica (PSS25NGMDWW) side-by-side refrigerator and recently has started pooling up water underneath the crisper drawer.
check the drain on the refrigerator side also you may have to disconnect to open the panel and clear with hot water or a heat gun.
Dec 19, 2014 | GE Refrigerators
Water collecting inside fridge, under meat drawer
Yes most responses are the freezer drain even if it is in the bottom freezer. If the drain is blocked water will build up anywhere inside your refrigerator only because it has no place to go during the defrost. Defective door seals can also can make the problem much worse. See Leaking Refrigerators I am here should you need me, Thanks John Tripp Appliance 911
Apr 21, 2014 | GE Profile 22.2 Cu. Ft. Side-by-Side...
Why is water pooling in bottom of fridge under veggie drawer.? Also freezing ice cubes in back part of cube drawer
Just above the veg drawers at the back is a channel that collects water when the fridge defrosts. It has a hole to drain the water which is blocked and the water is pooling under the drawers. Clear the hole with a drinking straw.
May 15, 2012 | GE Refrigerators
We have a slow water leak in our fridge. The water pools under the bottom 2 produce drawers.
On most newer fridges, there is a very shallow 'V' shaped collection channel at the back of the fridge just above the bottom drawers, this is for condensate collection. In the middle of this channel there should be a hole, this quite often gets clogged, and over flows, hence the water at the bottom of the produce drawers, clear the hole and it should cure your leak, worth checking every couple of months.
Mar 22, 2011 | Samsung RM255LASH Side by Side...
Water in the bottom of the refrigerator
this sounds like a clogged defrost drain remove cover and check drain tube for obstructions
Apr 04, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Have a TFX26ZPDA that occassionally leaks from front freezer corner. notice of leak anywhere, but find water under the fridge on the floor (facing fridge left bottom)..........why is this
I would check the bottom of the freezer. If its a solid block of ice then you have a frozen drain line. You may have to remove the back panel to access the drain or on some models there is a gap there its located in the back. If you take a turnkey baster and fill it with hot water and keep shooting it down the drain line it should eventually thaw out. The water is coming from your evaporator coils when they defrost.
Hope this helps _MJ_
Feb 07, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Ge profile water/ice fridge side under bottom drawer
Mar 15, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
I have a GE Profile Arctica Side By Side refrigeratorand the water despenser is not working. I have narrowed the problem down to be a frozen waterline, but it is not frozen in the frezer door. The line is...
There may be an issue with the water dispenser line freezing in this model. The fix for it might be this dispenser water tube heater kit # WR49X10173. Hope that helps you out and best of luck
http://tclaundryrepair.com/
Feb 25, 2009 | GE Profile¿ Arctica® Energy...
Water leaking - GE Profile Refrigerator, Model: TPX21PRX
Check to see if the drain at the bottom of your freezer is plugged. When the refrigerator goes on defrost, the water has to go somewhere. Look below the coils in the freezer section and see if there is ice in the drain.
Jul 15, 2008 | GE Profile 20.7 cu. ft. CustomStyle...
Refrigerators Logo
Top Refrigerators Experts
Sal DeAngelo
dweatherby
