Question about Andis ProMotor PM-3 Hair Trimmer
And is T outliner won't cut - Andis ProMotor PM-3 Hair Trimmer
My T-outliners are running correctly but they are not cutting even the smallest but of hair and they are pulling. I have adjusted, cleaned, and examined them thoroughly and cant find a problem, they are...
sometimes the blades don't align properly when we put them back together. try to re adjust the blades, they should be 1/16th of inch apart and be level, also makes sure you are oiling the blades before every use, friction causes wear and they won't last as long.
Jun 12, 2011 | Andis T-Outliner Hair Trimmer
I have an Andis outliner II I purchased a year ago. I recently changed the blade but it won't cut my hair. Do you kow why?
Sometimes the new blades from Andis are not sharpen enough to get that clean cut. also all trimmers need to be readjusted for power and alignment, plus sharpening the blade, it look like you need a complete sharpen & service on your Andis trimmer. check out Manny's Sharpening they have a Mail Order service, the service they provide is fast and they will sharpen make all the adjustment and give your trimmer more power and the blade will cut clean. They will even adjust the blade at your request on how you want that blade to be set at. Line Ups or Fade Cuts and even shave set. Manny's Sharpening been around for over 20 years and they have a very good rating on the net. Check it out Manny's Sharpening
May 21, 2011 | Andis Outliner II Hair Trimmer
MY ANDIS T OUTLINER BLADES ARE CLOSER TO THE LEFT THAN RIGHT AND ARENT CUTTING RIGHTHOW CAN I ADJUST THEM
e-mail me and I will have photo's on hold to adjust them. askmannyssharpening@yahoo.com
Apr 18, 2010 | Andis Outliner II Hair Trimmer
How do i get blades closer on the pivot pro t liners
You really can't move the cutting edge on any andis trimmer blades without throwing them out of spec. I say this to say that if you try (and the blades are not precisely set) it will scrape and cut the skin when you attempt to use them. They are factory set for optimum cutting. If you have found that they aren't cutting as closely or as cleanly lately, it just might be time to replace the blade entirely. I have a set of those, and a styliner II, but I prefer the cutting power of my T-Outliner over all.
Oct 04, 2009 | Andis T-Outliner Hair Trimmer
It keeps geting hot every time i cut my hair
you should put clipper oil where the blade contacts it's base (near the middle of the base) and spray kool lube or a similar product on the cutting edge.
Aug 08, 2009 | Andis T-Outliner Hair Trimmer
Adjust blade
On the Andis T-Outliner or Outliner if you have use the trimmer for more than 3 hair cuts or 3 time or more I do not recommend moving the blade, reason why is that you have all ready start or have a sit in or a grooved, I have found that by moving the blade it won't cut at all.You need to resharpen the blade with a professional sharpener and have them reset the blade for the type of hair cut you want. The blade can be set to shave or do line ups, and Fades. This type of trimmer is for that kind of hair cut the professional barber use them all the time. Call Mannys Sharpening 323 263-4697 They have a good rating on Yahoo Local.
I have try many sharpener and had no luck, until a friend of mind told me about Mannys Sharpening, They know what they are talking about highly Professional in thier work.
Sep 05, 2008 | Andis 04603 Hair Trimmer
Put it back together
Purchase the DVD on "How to adjust your trimmers and clipper blades" at www.alexccampbell.com
Jan 15, 2008 | Andis Outliner II Hair Trimmer
Andis ProMotor PM-3 Hair Trimmer Logo
29 people viewed this question
Top Andis Health & Beauty Experts
Anglia Clipper...
shaveroutlet.com
shaveroutlet.com
Kolbrun...
Are you an Andis Health and Beauty Expert? Answer questions, earn points and help others
