Question about Sentry Fireproof Safe
How do you dispose of a fire box when you have no use for it?
I do not store it in a damp place, and yet I have some docs covered with mold. I'm done.
Mold
Techniques for Cleaning Surface Mold
Surface molds grow in just about any damp location, such as the grout lines of a ceramic tiled shower. They\'re easy to scrub away with a mixture of 1/2 cup bleach, 1 qt. water and a little detergent. The bleach in the cleaning mixture kills the mold, and the detergent helps lift it off the surface so you can rinse it away so it won\'t return as fast. You can also buy a mildew cleaner at hardware stores, paint stores and most home centers.
Even for simple cleaning, protect yourself from contact with mold and the bleach solution by wearing a long-sleeve shirt and long pants as well as plastic or rubber gloves and goggles.
If the mold doesn\'t disappear after light scrubbing, reapply the cleaning mix and let it sit for a minute or two. Then lightly scrub again.
Seal the clean surfaces when they\'re thoroughly dry to slow future moisture penetration. Apply a grout sealer (available at tile shops and home centers) to tile joints.
Caution!
Don\'t mix ammonia or any detergent containing ammonia with bleach. The combination forms a poisonous gas.
Read more: http://www.familyhandyman.com/cleaning/mold-and-mildew/how-to-remove-mold/view-all#ixzz39zX8rYj8
Aug 10, 2014 | Tools & Hardware - Others
How to cover gap at back of kitchen sink cut out that sink rim will not cover up
You can use a schlueter T molding for tile in a stainless finish. Cut the T Molding to the length of the gap, - silicone the area and place, and put some weight on it to hold it in place until the silicone hardens. You can get the molding at a tile store, or big box store
Oct 22, 2017 | Blanco - Kitchen Sink - 2 Bowl - axia 6S -...
I have a brinks home security security fire/water proo fsafe QC3530 NOAH 184535 - I opened the safe and was astonished that all the contents, papers, coins, etc. had a musty, damp and some mold. Any...
I would add a "dri-air" dehumidifier to the contents and it will **** up all the water. Then change the location to some place higher as humid air like to "lay low".
Nov 23, 2011 | Computers & Internet
Horizon Group Power Balls Super Balls made by me! has no instructions, can you help?
From the box:
Cover work area with scrap paper.
- Decide which shape mold and colors you are going to use to make your power balls.
- Next snap together the two parts of the plastic ball mold
- Open the color crystals package that you would like to use first and pour the desired amount into the funnel on the top of the ball mold. Do not fill the funnel part of the mold all the way to the top or your ball will not bounce very well when you remove it from the mold.
- Holding the funnel part of the mold, carefully place the filled mold in a cup. While holding the mold, fill the cup with water right up to the bottom portion of the funnel. Let the mold sit in the water for five to ten minutes.
- Remove the mold from the water and wait ten minutes before opening it.
- Carefully open the mold and remove the ball. When you remove the ball from the mold it may feel a little sticky. Let it dry until it is no longer sticky before you start playing with it.
- Find a clean, flat surface to bounce the power balls on. When you are done playing, store each ball in resealable bags until you are ready to use them again.
Jan 01, 2011 | Roseart Toys
How do i remove the car battery from the 2006 Pontiac Grand Prix?
Hi. Please procedure below:
Find the 12-volt, side post battery on the driver's side, just behind the headlamp.
Remove the cables from the battery terminals with a battery terminal puller or socket wrench.
Lift the battery out of the compartment. Keep your gloves on at all times to avoid getting acid on your hands. Safely dispose of the battery at an auto parts store or a recycling center.
Use a wire brush to clean the surface that holds the battery. Clean the insides of the connector cables with a pointed wire brush.
Wipe the cables and the battery tray with a damp cloth and let them dry out. Use a rag that you can throw away since it will be covered with acid.
Place the new battery on the shelf. Place the correct cable on each terminal and tighten them securely with pliers or a socket wrench.
Thanks!
Dec 20, 2010 | 2006 Pontiac Grand Prix
I have a 97 Honda Civic that I just bought that gives me a headache after 20 min. of driving. I used a CO meter and air quality meter and all readings were normal. There is no taste of anti-freeze in the...
have you had it checked for mold, a musty damp odour. sometimes moisture can build up in the heater box and ducting creating mold. you can buy clean out kits that have varied success at auto parts stores. hope this helps
Jan 28, 2010 | 1997 Honda Civic
Why does so much scum and mold develop in the water tray and on the filter ?
Mold and algea form in the tray and filter of drum style humidifiers because humidifiers are a warm damp place, perfect breeding grounds! I suggest updating to a drain through style humdifier, as it does not allow water to sit stagnent in a tray. Hope this helps
Jan 21, 2010 | Humidifiers
How to install front bumper cover on 2001 BMW E39
Installation of the Molding
Take the Molding Trim whether it is stock black or painted. Mine is black because my car is a year 2000. Painted side moldings were done in the year 2001. Snap them into place.
dscn5738%20copy.jpg 5 Installation of the Rubber Gaskets
From the stock bumper, retrieve the upper rubber gaskets unless you ordered new ones. Simply take a screw driver and pry a corner off to get you started. Wash thoroughly. NOTE which one belongs on which side.
Place the rubber gasket on the M5 Front Bumper onto its appropriate side. Top dscn5717%20copy.jpg The M5 Bumper is now Fully Assembled!!! Place aside where it can't be damaged.
Nov 15, 2009 | 2001 BMW 5 Series
How do I get rid of mold on the seal ?
Bleach and water solution will get rid of the mold but will not deter future buildup. To prevent future growth of mold leave door open to dry out. Mold likes to grow in damp dark places. Hope this helps
Jul 29, 2009 | Maytag Neptune MAH5500B Front Load Washer
Hearing Aid Question
Behind-the-Ear (BTE) - Sits behind your ear and is connected to an ear mold placed inside your ear via tubing. BTE devices are fastened on the ear with an ear hook and the ear molds are custom made to fit the user's ear. In the Ear (ITE) - These are placed in the ear of the wearer. In the Canal (ITC) and Completely in the Canal (CIC) - With ITCs and CICs, the whole hearing aid is placed inside the canal. ITCs are often larger than CIC devices. CICs are extremely tiny in size and are almost invisible. Body-worn hearing aids - These aids use an external box worn by the user. The user wears an ear piece which is attached to the box by a wire. There are also disposable hearing aids available which have a built-in battery and, after the allotted hour or time usage, the user simply replaces the entire aid.
Aug 27, 2008 | Maxi Aids The e-pill Cadex 12 Alarm...
Sentry Fireproof Safe Logo
197 people viewed this question
Top Sentry Home Security Experts
Jim London
Jim London
Computer Repairing
Computer Repairing
 Brian Main
Brian Main
Are you a Sentry Home Security Expert? Answer questions, earn points and help others
