Question about Maytag Dryers
Neptune maytag dryer model mde5500azw has thumping noise .i also notice a number of small silver bearings when i removed the lint cleaner
dididsaythat
  • 291 Answers
SOURCE: Maytag Dryer not working properly after cleaning lint trap.
where does the noise sound like its coming from??
Posted on Oct 08, 2007
  • 65 Answers
SOURCE: Remove front of dryer to clean lint from interior
open door remove eight screws, four on plastic guides and same location on hinges. wiggle door and it will remove . now grab narrow ends of front panel and pull toward you. wwhen panel gets to 45 degrees pull off tabs at bottom.
Posted on Feb 16, 2008
SOURCE: how to remove lint tray receiver: maytag dryer model#pye2300ayw
Unplug first with a straight blade screwdriver, pry up on the top of the dryer where the front wall of the dryer and the top meet. there are 2 screws 1 on each side inside the dryer where the sides and front meet, remove them and unhook the wires from the door switch. the whole front will now pull out and up, now open the door remove the 2 screws at the bottom of the door opening and the whole lint tray will pull out. sounds like a lot but only takes about 5 minutes.
Posted on Dec 04, 2008
SolutionGuy
  • 331 Answers
SOURCE: How do I remove the lint housing of Maytag Neptune dryer
Hi Kate,
Gaining access to the lint housing sounds more difficult than it is. As a matter of fact, I could get to it and have it back together in the time it takes me to type out the instructions!
Tools needed;
1.) Phillips screwdriver
2.) 5/16" nut driver or socket
UNPLUG THE DRYER FIRST!!! Or risk a funky new hair-do...
Open the door and remove the four screws at the hinges then remove the door. Opposite the hinges, you'll see 4 more screws, remove these too. Now grasp the front panel on both sides near the top and pull it toward you. Lean it out to about a 45 degree angle and lift it off the clips that are holding it (at the bottom).
Now you'll see the lint trap housing. Look around the housing, you'll probably see a yellow wire near the 5 o'clock position, remove it. Now, on either side, you'll see four 5/16" screws... Don't remove the top ones, just remove the three below the top ones. You can now pull the entire panel off of the frame for cleaning.
Rebuild in the reverse order (and don't forget to re-connect that yellow wire!)
There ya go! Please don't forget to rate this as "FixYa", OK
SG
Posted on Apr 11, 2009
Jahn27
  • 1554 Answers
SOURCE: how to remove the front panel of a maytag neptune gas dryer
Removal of the front panel requires the removal of the top cover and the console. Disconnect power to the dryer prior to servicing to avoid the risk of electric shock.
Remove the 2 screws attaching the top cover to the rear of the dryer then slide it rearward to clear the screw head from the top cover flange and lift the cover off the dryer cabinet.
Remove the screws securing the heater PCB board and disconnect the black and white wiring harness connectors from the board.
Remove the four screws attaching the console to the washer cabinet and rotate the console down to remove it from the dryer.
Remove the four screws attaching the top of the front panel to the cabinet and the two screws at the bottom of the door opening.
Pull the front panel forward and disconnect the interior light wiring harness then lift the front panel off the tabs across the bottom and move it away from the dryer.
Reinstall the front panel, the console, and the top cover in reverse of the removal steps.
Posted on Apr 21, 2010
How do i take apart the my dryer
Sounds like a drum roller bearing. When they go bad they form a flat spot and that against the drum will give a loud thump. Turn the drum by hand and you should feel the flat spot. You may have to remove the back panel to get a good look see and a repair access. Good luck.
Jul 11, 2010 | Maytag Neptune MDG5500AW Gas Dryer
Maytag neptune dryer making a thumping noise while drum turns, as if there were a tennis shoe in it, but there isn't? Ideas?
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Jan 23, 2010 | Maytag Neptune MDG5500AW Gas Dryer
Loud banging noise while drying
the Idler bearing maybe going. its fairly easy to replace. go here http://www.repairclinic.com/Maytag-Dryer-Parts?s=b4a8c203
the part is cheap and i will show you how to remove the front door and replace the bearing.
May 28, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Maytag front load dryer thumps while turning, empty, full etc.
If your Maytag is like my Maytag, there are two screws at the two bottom corners of the front panel. Once you remove both screws the front panel will lift out, up, and off. Then you can see what is going on inside.
Mar 28, 2009 | Maytag Dryers
Maytag Neptune Dryer making vibrating noise while working
a bearing in the back for your drum sounds like what you describe. It needs to be taken apart and the bearing lubricated with high temp grease
Feb 23, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Maytag neptune front load dryer
Your exhaust vent is probably plugged. Remove venting from the dryer and check for lint build-up, and also check the vent flap on the outside of your house for clogs. If venting appears to be clear, you might have a bad blower (although you should notice an abnormal noise with that).
Jun 20, 2008 | Maytag MDE9700AYM Electric Dryer
Neptune dryer
sounds like one of your tumbler veins inside the drum is loose. there should be two or three screws holding them in
Nov 20, 2007 | Maytag Neptune MDE5500AY Electric Dryer
Dryers Logo
21 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
