Cerwin Vega LW-12 Active Sub hum after Power supply Caps replaced
I have an Cerwin Vega LW-12 sub that after years of great service started to "flutter" when hitting the higher frequency in its range. It sounded as if the speaker was blown. I tried 2 other woofer speakers and the same thing would happen. I took it to an "authorized" CV repair shop and they found the PS caps were swollen and replace them. I took the unit home and hooked it up but now it has this God awful hum. Even when no music is playing. The shop invoice reads they replaced the caps with higher rated ones that are supposed to be better. Can these new caps be causing the hum or is there something like a cold solder or ground loop issue that came about due to the repair work?
SOURCE: sound problems through subwoofer
check all speakers wires andcheck test mode. every thing ok, may be input wiring problem ,check every thing after that internalcircuit may be problem..
Posted on Oct 09, 2007
  • 14 Answers
SOURCE: Auto Sub woofer
There are several causes of distortion in an audio setup.
1) Speaker is unable to handle the frequency that it's being fed
2) The volume is too high for the speaker to handle
3) The amp can't provide enough power to drive the speaker adequately.
Either way distortion is BAD & best to be avoided unless you want an excuse to buy a new set of speakers :P
Posted on Dec 28, 2007
SOURCE: Cerwin Vega ve-28s subwoofer and new Cervin Vega 2-way satellites
I bought my VE-28s and it did exactly that crackled, cerwin replaced part in amp but few months later problem persisted. they then replaced entire amp assembly and its been fine. i really push it to and its been fine. to test it, unplug the connection from amp/ reciever and see if it persists. if so its the sub, if not its the amp/ reciever. dont dump it, these subs really crank and can put out some deep loud bass.
Posted on Mar 05, 2008
SOURCE: reg: Cerwin-Vega! 250SE 125 watt
i had the same problem & got them fixed at a professional audio place in town & now my speakers are like new. They will last me another 10 years. I suggest you have them fixed by a professional.
Posted on Aug 25, 2008
  • 396 Answers
SOURCE: HUM noise at PSW3000 if i connect the Yamaha RX-V995
the conections some where are dirty you need to unplug everything clean all connections and the hum will go away
Posted on Nov 06, 2009
When turning on the power on my cerwin vega 15" sub the protect light which is a built in protection on the amplifier keeps coming on the power on light does not come on at all just the protect light
The sub could be shorted or the wire connections of the sub could be shorted, or there could be an internal problem with the amplifier such as a shorted output stage or failure of some other component(s)
Feb 21, 2013 | Cerwin Vega Audio Players & Recorders
I need a replacement sub woofer for my LW 12
Polk Audio PSW505, BIC America F12, Hsu, SVS, Outlaw, Axiom Chane Subwoofers
Sep 03, 2012 | Cerwin Vega LW12 Subwoofer
I just pick up a used LW 10 Powered sub and 2 channel sherwood receiver.What is the preffered method of hook up up the sub with out a pre sub out?
"Sherwood Receiver" doesn't really tell us much about that end of the scenario.
Look at this picture of the sub amp.
http://cgi.ebay.com.sg/CERWIN-VEGA-LW-10-SUBWOOFER-AMPLIFIER-Speaker-Blade-Amp-/350444290153
You COULD run the Main speaker output to the large Red/Black speaker inputs, then some more wires Out from the other Red/Black connectors to your Main Speakers. That way your amp volume control will affect both equally.
Tweak the sub volume, crossover and phase to match it up to your mains.
May 15, 2011 | Cerwin Vega LW10 Subwoofer
Specifications of cerwin vega pro stax scoop sub
http://www.cerwinvega.com/pro-audio/portable-sound-system/int-118.html
You can always contact Cerwin-Vega and tell them the model number to get the exact info you need even on older models.
-Chris
May 25, 2010 | Cerwin Vega Pro Stax 12" 2 Way Stage...
Cerwin vega passive subwoofer model sw-12b
Passive woofers are hooked up to the output of a sub amp.
Active woofers are hooked up to the sub out of a receiver. They have the amp built in.
Mar 09, 2010 | Cerwin Vega Audio Players & Recorders
What enclosure do i need for cerwin vega v-max 124 12" sub
Just get a 12" sub box enclosure for an audio store near you or make a custom box, a larger box supposedly gives you more bass yet at the cost of boot space. I have a type R sub and the box is only as big as it needs to be for the sub to fit and it gives amazing bass.
Aug 04, 2009 | Cerwin Vega V-Max 12 Car Subwoofer
Crackles and pops,even in standby mode
Does it only pop and crack when its connected to your amp or receiver ? i have the same thing with my sub [its not cerwin vega] but when i turn my amp off the sub doesnt pop anymore so i think my amp is the problem not the sub , yours might be the same problem .
May 19, 2009 | Cerwin Vega VE-28S Subwoofer
Cutting on and off
Same thing is happening to my Cerwin Vega 18" sub. Can't find solution at all. Guess I will have to buy a new sub.
Jun 19, 2008 | Cerwin Vega LW12 Subwoofer
Speaker Box Specs??
i need to know what the box dementions are for a 15 inch cerwin-vega subwoofer v max 1000 w peak power?
Mar 24, 2008 | Audio Players & Recorders
Cerwin vega ve-28s
I have the same problem and was told that it is failed amplifier....
Dec 02, 2007 | Cerwin Vega VE-28S Subwoofer
Computers & Internet Logo
24 people viewed this question
David Payne
David Payne
