Question about AEG S75388KG Bottom Freezer Refrigerator
How do I take the panel off in the freezer to see if it's all iced up
My fridge has stopped working, the temp is up to 14. I called a guy out, he told me to switch it off to defrost it, then it should be ok, I have done this but still have the problem, also when it was up plugged for 2 days there was hardly any water.. I have read a few articles saying to take the panel off in the freezer to see if it's iced up, how do I do this no screws??? My freezer is working fine, any suggestions please. Thank you in advance. Sue
Noggin
  • 944 Answers
SOURCE: AEG fridge/freezer isn't working
This sounds like your fridge has a leak somewhere and it slowly discharged its refrigerant. the compressor can sustain damage when there is no refrigerant and often will hum and eventually fail. Sorry but you may need a new compressor - if you were going to replace the fridge soon anyway then i would go ahead, but a compressor and the labour to fit it etc may be cheaper than a new fridge - you need a refrigeration repair man/shop (if you can take the fridge to a repair shop it will always be cheaper than calling a guy to your house) Sorry i can't really help, but the symptoms are classic, if you are lucky then a technician may be able to fix the leak and restart the compressor, but not always if you want to try something yourself just try tapping the compressor smartly but not too hard with the end of a dry wooden or plastic stick or similar with the fridge plugged in. the compressor is the thing at the bottom in the back that looks a bit like a small fuel tank, should be right in the middle and will be the largest thing in there. Just be careful not to break any copper tubes or touch any wires. Sometimes a stuck compressor can be freed this way, but you will almost certainly still need the leak fixing and a refill of refrigerant. Sorry about the bad news :( Hope this helps :)
Posted on Mar 09, 2007
  • 68 Answers
SOURCE: ice develops at back of fridge
hi chris
dave here hope i can help
I would test the defrost timer, defrost heater or defrost limit switch
TESTING AND REPLACING THE DEFROST TIMER
This timer activates the heater that melts frost in the evaporator for 10 to 20 minutes every 10 to 12 hours. In the process, it turns the compressor off and on. If it fails, the compressor may not run. Or the heater may not go on, eventually causing a hidden ice buildup that blocks the cold-air flow and disables the evaporator fan. An access hole lets you test the timer. If the timer isn't in the control panel, look behind the front grille or behind the rear access panel. If the compressor fails to run turn the timer until it clicks. If compressor goes on, timer is faulty. If unit isn't defrosting automatically and turning timer stops compressor or fan, timer is faulty.
Before replacing timer, spray it with electrical contact cleaner through access hole and turn it a few times. Stop just before a click and wait to see if timer advances on its own.
To replace timer, unplug the refrigerator and open control panel. Remove screws holding timer to panel and pull of leads. If wires aren't in a plug, move then one at a time to new timer.
EVAPORATOR AND DEFROST HEATER
In a frost-free unit, the evaporator coils, their fan, and the deforst heater are located behind the freezer's back wall or under its floor. The fan, which circulates cold air between the coils and the two food compartments, is controlled by the door switch, the thermostat, or both. To check the fan, open both doors, wait for the compressor to go on, and hold in the door switch. If you can't hear the fan running, test the fan(below).
The defrost heater, which melts frost on the coils, is cycled on by the defrost timer(above). If the frost melts before the end of the defrost cycle, the defrost limit switch turns the heater off. The heater may be a metal rod, a wire wrapped in foil, or a coil inside a glass tube. All are tested the same way. Test terminals for the heater are often located in the control panel or under a doorjamb; check the wiring diagram. Or test the heater leads inside the evaporator compartment.
TESTING THE EVAPORATOR FAN
To remove the evaporator fan, unplug unit; open back panel(or floor) of freezer. Then unscrew housing holding fan, and take off leads going to fan motor. With VOM(Volt-Ohm Meter) on RX1, probe motor terminals(except green ground wire terminal). Look for moderate resistance(50 to 200 ohms). Replace fan if much lower or infinity.
TESTING THE DEFROST HEATER
Open control panel. With VOM on RX1, probe test terminals. Look for 15-to 100-ohm reading. If infinity, turn defrost timer(as above); retest.
TESTING DEFROST LIMIT SWITCH
Trace and disconnect leads. With VOM on RX1, probe leads. Look for infinity reading when switch is warm, zero after 20 minutes in working freezer.
Hope this sources your problem
Thank you for using Fixya.com
Posted on Jul 20, 2008
heatman101
  • 43501 Answers
SOURCE: fridge freezer not keeping temp
As the weather is getting warmer for many people their freezer2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Posted on May 27, 2010
MNfisherman
  • 11896 Answers
SOURCE: AEG A 2674 GS6
Sounds like either the defrost timer is bad or defrost thermostat is not engaging. If it works sometimes, then the defrost heater is probably ok. Most likely the timer. It is behind the farthest wall in the freezer. You will have to remove the panel to access it.
Posted on Aug 26, 2010
imufo2
  • 3773 Answers
SOURCE: i have a aeg santo
The drain in the freezer behind back lower panel
needs opening. You can see it at the bottom of the back panel
underneath the evaporator coils. (The cold coils)
Run Hot water in the drain until it clears or use a hairdryer.
When the defrost melts the water it goes down the drain
If the drain is clogged with Ice or ? it overflows into the ref.
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME IF THIS WAS HELPFUL
Posted on Aug 08, 2011
Hi there! My Amana BR22 with freezer on the bottom is not cooling anything. It started last week when I noticed my ice cream was mushy, so I turned the freezer dial higher but it just kept getting...
U need a new compressor for ur fridge, if u go behind ur fridge...there is a black oval shaped unit with gas pipes connected to it. Jot down dtails on the sticker (rating; horse power) and use that data to find a replace. The service man wil have to refill the gas for u too. Please vote if it works, good luck.
Jun 14, 2011 | Amana Refrigerators
Fridge freezer not keeping temp
heatman101
Apr 11, 2010 | AEG Santo 3888 KG8 Bottom Freezer...
GE Side By Side refrigerator. Freezer melts ice together
Call GE since this refrig is still under warranty . But , you should turn your freezer to 0 degrees first .
Jan 28, 2010 | GE Profile 26.6 cu. ft. Side-by-Side...
Freezer working but Fridge not cooling... Tried adjusting temp to max cool and nothing. Unblocked vents, still nothing... Pulled off back panel cover to vacuum and brush... still nothing... help??? In case...
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
Oct 26, 2009 | Amana ARB1917CSR Bottom Freezer...
Samsung fridge RS2630, icing up on freezer and fridge not cooling
Could be the defrost element. If it does not work and melt the ice off of the evaporator, icing will continue and serve as an insulator. Freezer and refrigerator temps will suffer.
If you unplug the unit and let it defrost for a day and plug back in it will work fine till it freezes up again.
Jun 25, 2017 | Samsung RS2630WW Side by Side Refrigerator
Freezer is working good but the frige is 52
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp .
OR
Aug 17, 2009 | Refrigerators
Can't get temp in fridge to go below 50 F. Freezer works fine and makes ice. It started when our area had a heat wave and the inside of our house was 85+ most of the day. The ice maker stopped working,...
Have you checked the evaporator fan(freezer fan), This problem is hard to detect because the fan spins but not fast enough to circulate the chilled air thru the freezer and refrigerator.
Aug 01, 2009 | Refrigerators
MAYTAG REFRIGERATOR ICE MAKER NOT WORKING, AND REFRIGERATOR ONLY COOL WHEN TURNED UP TO HIGHEST LEVEL. FREEZER IS COLD
Is the freezer cold enough to make ice maker operate. 10 degrees or less.
The fridge gets its cold air from the freezer through a vent between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp .
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
Jul 03, 2009 | Refrigerators
Creda R335NW Fridge/Freezer. The fridge section is not cooling down anymore, The freezer is working ok. Any ideas please?
My refrigerator it's not cooling bu the freezer
The fridge gets its cold air from the freezer through a vent between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp ..
Jul 01, 2009 | Refrigerators
AEG S75388KG Bottom Freezer Refrigerator Logo
21 people viewed this question
Top AEG Refrigerators Experts
Oscar Netto
Oscar Netto
ashburton
Jim Goldsmith
Jim Goldsmith
Are you an AEG Refrigerator Expert? Answer questions, earn points and help others
