Question about Electrolux EW30ES65GS 30" Slide-in Electric Range with 5 Radiant Elements, 4.2 cu. ft. Self-Cleaning... Range
Cannot turn on stove or unlock oven door - Electrolux EW30ES65GS 30" Slide-in Electric Range with 5 Radiant Elements, 4.2 cu. ft. Self-Cleaning... Range
Used self cleaning process on my oven yesterday and today the oven will not turn on, we keep getting message to unlock the oven door even though it is. What can we do?
The oven gets extremely hot during the self-cleaning mode... the door switch might have got stuck in locked position, or broken in locked position (to be replaced), let's hope it's just stuck...which you'll need to work the mechanical lock-unlock latching back and forth to hopefully unstick....and if that doesn't work just re-run self-cleaning process but this time let the oven cool completely before unlocking the door. Hope this helps.
May 11, 2014 | GE Ovens
WIFE SET "oven lockout" ON
Press and hold the START button for 3 seconds. A beep will sound 2 times. The DOOR LOCKED will continue to flash until the oven door has completely unlocked. Hope this helps.
Jun 28, 2011 | LG LRE30451 Electric Kitchen Range
My oven code is F5E1 , my oven was in self clean , now the door is locked
F5E1 is door latch assembly. One way that may work to unlock is to turn circuit breaker to stove off for few seconds then turn back on and door lock should activate and unlock. If not you are going to have to replace the door lock assembly.
Mar 03, 2010 | Whirlpool 30" Self-Cleaning Freestanding...
Kenmore oven door will not unlock, it is an older model and i have lost the manual. i tried to activate the self clean but i couldn't remember how all that ended up happening is that the door has locked...
Look around the console area for a button that says push to unlock. If it is there push the button in while unlocking the door. Some models may require that you also place the stove into self clean then canceling it out thus enabling you to unlock the door. Without a model number off stove tho it is all just guess worjk as all stoves are not the same.
Feb 28, 2010 | Kenmore Ovens
Oven door lock engaged while NOT in cleaning mode with door open
The question isn't that clear as to what your problem is but try unplugging the stove or turning the power off to the stove at your main fuse/breaker box and then turn it back on. You should then have the oven door unlocked
Aug 08, 2009 | Frigidaire FEF336BC Electric Kitchen Range
Jenn-Air stove locked
After the lock indicator light goes out, move the door lock lever to the left. The oven door can now be opened. Turn the selector and temperature knobs from clean to off AFTER THE DOOR IS UNLOCKED. If the temperature knob is turned to off BEFORE the door is unlocked, the door will not open. Forcing the lock will damage the lock mechanism. If this should happen, return the temperature knob back to CLEAN, unlock the door, THEN turn the temperature knob off. Source(s): Jenn-Air Grill Range with Self Cleaning Radiant Bake and Convection Oven models S136, S156, S161
Dec 10, 2008 | Ovens
Self cleaning oven directions
MAKE SURE OVEN IS EMPTY LOCK OVEN DOOR AND TURN OVEN SETTING TO CLEAN, IF YOU HAVE A VENT TURN IT ON THERE WILL BE SMOKE! LET RUN TWO HOURS,TURN OFF,LET COOL BEFORE TRYING TO UNLOCK IT (WILL NOT UNLOCK WILE STILL HOT!) OPEN DUST OUT ASH ITS CLEAN!!!
Dec 07, 2008 | Whirlpool GR465LXLS Electric Kitchen Range
Oven Door Locked
the oven door does lock during self clean, otherwise it will not work. however, the door is supposed to unlock after the oven has cooled. if it is still locked, turn the oven to self clean and wait about a minute and then hit cancel and see if the door unlocks. if not, there may be a probelm with the door lock mechanism. Joe
Nov 18, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Oven does not work
According to the manual, the self cleaning latch could be stuck.
If the oven door is open, press STOP/CLEAR to clear display, then depress and hold switch plunger for 6 seconds (Located in the upper right corner of the oven front) and the oven door will unlock.
If the oven door is locked, press STOP/CLEAR to clear the display then apply pressure to the upper right corner of the oven door and the door will unlock. If the "F" code reappears, contact a Sears trained repair specialist.
Sep 15, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Electrolux EW30ES65GS 30" Slide-in Electric Range with 5 Radiant Elements, 4.2 cu. ft. Self-Cleaning... Range Logo
23 people viewed this question
Top Electrolux Kitchen Ranges Experts
Rommel Balcita
Mike Henne
Level 1 Expert
Are you an Electrolux Kitchen Range Expert? Answer questions, earn points and help others
