TV states no signal from computer - Televison & Video
When I put my computer on it comes up with scanning no signal and the screen stays black with the little light in the corner is yellow but sometimes leaving the computer on by itself
The monitor is stating that there's no signal from any device. It could be that the monitor cable is unplugged from the back of the tower, or the graphics card could be bad. "Scanning" suggests you're using a smart TV rather than a monitor. In that case, you may need to change the setup type to VGA, DVI, HDMI or whatever type signal the computer sends.
Oct 18, 2015 | HP Pavilion Computers & Internet
My hisense is hooked up but says there is no signal
Using the Hisense remote, enter setup menu fpor TV. Choose SAT/Cable as signal source.
Feb 22, 2015 | Hisense LTDN50K360GUS 50" LED TV...
No signal on my bush 320GB satellite HD digital tv recorder
i have a signal while watching TV
But when i try to record it states no signal
Dec 03, 2012 | Televison & Video
Hp w1907 VGA no input signal
its is telling you the truth (99.9999999% of the time)
believe it !
no PC stated
no TV model stated nor clear connections stated.
are you trying to get the PC (the tower means that)?
to run to video concurrent ports at the same time?
so do both fail,
VGA side
and DVI side,
you never said.
hard to help lacking
what TV
what Tower
what connections, and special adapter (HDMI)
the TV has DVI??
sorry, cant see what you have there. at all.
Feb 01, 2018 | HP w1907 LCD Monitor
LED TV no signal from hdmi connection
if you have a laptop or a pc or a dvd player , anything with HDMI out try that to see if it is the tv or not.
Apr 04, 2017 | Westinghouse Televison & Video
Tv will power on, but no picture..tv states no signal low signal
okay it sounds like your tv is having a problem in the IF or video section.this will require you to have a tech repair your tv.if you dont have a training in tv repair then dont open your tv.good luck.
Sep 25, 2011 | Samsung 50 in. Plasma TV
When I connect my Toshiba L505-S6946 to a Samsung TV via a VGA port, the computer screen goes black and the TV says signal not supported. Could anyone help me? I know they are talking since when the...
Try pushing the FN button, next to the left CTRL button, and then hit the F5 key at the top. By the number of times you hit the F5 button, you are telling the computer to display on its lcd screen, on the monitor (TV), both, or neither.
Dec 12, 2010 | Toshiba Satellite L505-S5966 Notebook
Akb error signal produced and TV goes to shut-down state
Yes mate, you can fix it if you know basic know-how in electronics. pls confirm to get further help as projection TV has high voltage risk inside and I want your safty 1st.
Aug 14, 2008 | Sony KP-53HS10 TV
Samsung 52 inch dlp tv purchased in 2003 will not handle 1080i signal from brighthouse hddvr. states no signal detected thanks howard
Be sure you are using the correct component input
This model has three component inputs and only one (the third from left) will work on 1080i signal the first two only handle 480i and 480p
This tv will not operate with 720p signal
supertek57
Jun 17, 2008 | Televison & Video
"No Signal"
Might need a tuner, I suspect if you arent seeing any snow/static you probably need to press the tv/video button untill you get the ANT input.
Jul 31, 2007 | Sony FD Trinitron WEGA KV-32FS100 32" TV
Televison & Video Logo
12 people viewed this question
Top Televison & Video Experts
