Question about Kobo Arc
Charger port is broke
Charger port is pushed in
My tablet won't charge
First try to charge it with a different charger, and test the factory charger on another device (you tablet may have the common micro USB connector). This will test if the charger or cable are bad. But if the tablet will not charge with a different charger and cable, and it is still covered under the factory warranty, return it for a refund or a replacement.
I have repaired many tablets with a bad charger port, and it seems to be either a poorly designed connector, or an open wire inside due to pushing in too ******* the cable into the port.
if you cannot replace the tablet, maybe you can find help from someone who can open the tablet and fix the charger port.
Nov 27, 2017 | Tablets & eReaders
My Charger Port is no longer there is there any other way to charge it
Jillian, Check warranty, I beleive should be one year, call manufacturer right away if under warranty. Option 2 Have charger port replaced at a computer/cell phone repair shop. Check links below and see how they fixed this issue.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Android tablet charging port fix
How to Fix the Charging Port on Tablet
Is there any way to charge my tablet without the micro USB port
http://forums.androidcentral.com/amazon-kindle-fire/283806-anything-i-can-do-if-my-charging-port-broke.html
Apr 26, 2016 | Tablets & eReaders
How do I fix a pushed in charger port on a pink kids Prontotec Wimo tablet?
unless you know how to open the case I would take it to a computer repair shop .
Oct 28, 2015 | ProntoTec Tablets & eReaders
How do I fix a Samsung galaxy SM-T2178 tab charger port is broke
send for repair if you try self repair you will lose any warranty you have speciality tools required
Aug 07, 2015 | Samsung Tablets & eReaders
Charger port broke on Lenovo a3000 tablet
Most of the time they are not worth fixing since the charger port is connected directly to the main board so you would have to replace the whole board. Rich
Apr 13, 2015 | Lenovo Tablets & eReaders
The charge dock on tablet broke so we can not charge tablet can it be fixed? We just got it this October.
Juello. Did some research on your tablet at Amazon, (http://amzn.to/1xWx6S5) and see that they also have an AC charger (AC charger adapter with a 3.5mm power jack and delivering 5VDC 2A). Available for $5: iRulu Black AC Home Wall Adapter Cable Charger for Tablet PC 5V 2000mAh or a there's a nice replacement KB and cover: iRulu New Portable 10 1 10 5 Android Tablet USB Keyboard Case Black . I would guess the connector snapped off inside the tablet, so you will have to remove it with some tweezers. If the pin for the AC adapter broke off inside the tablet, that's a problem, but most everything can be charged from the USB port too see this website:
How To Charge Samsung Galaxy Tab 2 Via USB Port On Computer Laptop PCNEXUS (Samsung used as an example). GL
Jan 08, 2015 | Irulu 10.1"tft Wifi 3g Android 2.2 Tablet...
My charger plug broke off my charger cord and is stuck in the port of my tablet.How do I fix it myself?
The only way i know of is to take off the back casing and look at where the the charger port is and you might be able to remove it with an object a little bit bigger than the end of the charger. otherwise you cant do it your self withput messing something up on the tablet.
Jun 05, 2014 | Nextbook Premium 8 Se Android
If I am reading you correctly the charger port from the charger has been lodged in the tablet. Get some tweezers and pull it out very very carefully. Hopefully no damage has been done. Buy a new charger afterwards.
Kobo Arc Logo
66 people viewed this question
Top Kobo Tablets & eReaders Experts
Andrew Taylor
Andrew Taylor
Tom Chichester
Are you a Kobo Tablet and eReader Expert? Answer questions, earn points and help others
