Bizhub 350 c5102 error - Office Equipment & Supplies
3 Suggested Answers
  • 19 Answers
SOURCE: bizhub 350 error code
c3852 means low fuser(hot section) temp setting. hold down utility or stop key, then you should be abel to do trouble reset. if problem persist it would most likely be a lamp or a sensor, which will require a technician to come out.
Posted on Apr 16, 2008
SOURCE: error c1183 on bizhub 350
Check this solition
Posted on Dec 02, 2009
Error code c5102
take each of the image units out not toner image units. Then shake each unit along its axis to spread the developer in side each one along the whole image unit. then reinstall. next pull out the transfer belt and reinstall properly. if this does not work you might have and burned out main motor or worse the control board that controls it is bad.
Oct 16, 2015 | Konica Minolta Minolta Bizhub C353 Copier
Bizhub 164 error code c-5102
Code
C5102
Description
Main motor malfunction
- The main motor (M1) lock signal remains HIGH for a continuous 1-sec. a period at any time 1 sec. after the main motor has started turning.
Remedy
1 Check the connector between M1-PRCB CN6 for proper connection and correct as necessary.
2 Check M1 for correct drive coupling and correct as necessary.
3 M1 operation check.
4 Change PRCB.
5 Change DCPU.
Oct 03, 2013 | Konica Minolta bizhub C250 All-In-One...
Error Code C-5102
C5102 Transport motor's
failure to turn
• The motor lock signal remains HIGH for a
predetermined continuous period of time
while the motor remains stationary
Some thing is binding the drive
Aug 22, 2013 | Konica Minolta Minolta Bizhub C353 Copier
Bizhub 350 manual de servicio codigo de error el c0500
In correct code for a Bizhub 350. What is the model # Bizhub Fuser errors start with 34, 37 ,38 for the Bizhub 200/350
May 11, 2013 | Minolta bizhub 200 Copier
Bizhob 250 c5102
The error code C5102 is a fixing unit error code.
Dec 23, 2012 | Minolta bizhub 350 Black and White Copier
Error C-5102 minolta C450
C5102: Main Motor's failure to turn
Relevant Electrical Parts
Main Motor (M1) Mechanical Control Board (PWB-M)
DC Power Supply (PU1)
Step Action
WIRING DIAGRAM
Control Signal
Location (Electrical
Component)
Check the M1 connector for proper connection
Check M1 for proper drive coupling and
Check the PWB-M connector for proper
M1 operation check PWB-M CNDM1-5 (REM)
PWB-M CNDM1-8 (LOCK)
L-2
5 Change PWB-M - -
6 Change PU1 - -
thanks&regards
Sep 06, 2012 | Minolta Di3510f Bizhub Copier
Error code c5102 on bizhub c353
I tried all the above but still it shows code C-5102.
Please advise.
Apr 17, 2012 | Konica Minolta Office Equipment & Supplies
Error code c-5102 in Konica minolta c252
Here’s your GEEK-steer …
This thread appears to cover the solution to your problem related to error "C5102: Main Motor’s failure to turn":
http://www.copytechnet.com/forums/konica-minolta/15515-c252-m1-operation-test.html
In addition, here’s the link to “Bizhub C250P” related support downloads:
http://kmbs.konicaminolta.us/content/support/supporthome.html
Hope this helps, and please post back with a status report and/or any further assistance you might need.
"Today's the best day of my life...and NOW you're part of it!"
Dec 15, 2008 | Konica Minolta bizhub C250 All-In-One...
Bizhub 350 error code
Apr 15, 2008 | Konica Minolta bizhub 350 All-In-One Laser...
Erroe code
You post a wrong printer nr, you must have bizhub C350 not bizhub 350, beacause 350 doesnt have that kind of code.
In Bizhub C350 that code means:
C12C0: Hard disk recognition error
You have the following options:
- reinstall the hard disk
- change hard disk
or as a last chance change PWB-MFP
good luck
Feb 06, 2008 | Konica Minolta bizhub 350 All-In-One Laser...
252 people viewed this question
k24674
jasbo
jasbo
