Question about Dell Dimension C521 PC Desktop
Communication port drivers
Some months ago after downloading some updates to my Earthlink internet software they left my communication ports disabled, since then I have tried everything to reinstall or get new port drivers to fix the problem. I have gone through a lot of run around with the Dell site and tried many other things to no avail. I am using a HIRO PCIE dial up modem that is using COM port 8 since the other ports are disabled. Could you help me find the drivers to Com ports 3, 5, 6 so I can fix my problem?
  • 341 Answers
SOURCE: undetected com port 3
You may have to enable the other com ports. You go into the Control Panel and click on Add&Remove Hardware. When the first window shows up with everything that is already installed list, look at the top of the list. Highlite Add New Device. When ask, choose Select From A List. Then select COM Port and follow the wizard.
Posted on Nov 26, 2008
  • 3 Answers
SOURCE: install usb2 to rs232 dongle
driver is not supporting the window version
or the port is not working properly
Posted on Dec 12, 2008
Mastersage
  • 164 Answers
SOURCE: I can't find PCI or USB drivers for a Dell Optiplex GX270
Do you know the motherboard mfg?
if it something other than the Dell then you can get the drivers.
USB drivers are mostly generic and are available at Microsoft. there is an application called "Driver Detective" and they are good. They check the computer and get everything you need.
Posted on Feb 23, 2009
Dellea
  • 30 Answers
SOURCE: com.port failed
Download and install the latest proper driver for the TU-S9 cable.
Also, are yo sure that this mysterious "external serial device" is working properly, or is even compatible with the computer?
Last but not least, you could buy and install a PCI serial port card...
http://astore.amazon.com/dellebizcompu-20/detail/B000EDPY86
Posted on Mar 27, 2009
gymowner
  • 679 Answers
SOURCE: Sound Card/ Codecs broken
http://www.codecguide.com/klcp_update.htm, just download this codec pak, that will give you everything you are missing, use the "full" one
Posted on Apr 08, 2009
Panasonic dp1515p driver
click start control panel administrative tools computer management device manager scroll to ports(COM&LPT) + to expand you should see a communication port and Ecp printer port
you might see a yellow? ! question exclamation mark or a red X this will mean you need to install a new driver for this device right click
you will have options to update driver disable uninstall or select properties again you will have the similar options also you can troubleshoot the device
http://download.cnet.com/panasonic-dp-1515p/3000-2116_4-144478.html
hope this helps you
Apr 05, 2012 | Panasonic DP-1515P
Software - Printer drivers Epson PM-870C
http://support.epson.net/vista/updates/printers/download/86010000.exe 32 bit
http://support.epson.net/vista/updates/printers/download/64010000.exe 64 bit
if these fail
You might have to uninstall the printer restart your computer then reinstall your printer
click start control panel administrive tools computer management device manager scroll to ports(COM&LPT) + to expand you should see a communication port and Ecp printer port you might see a yellow?question mark this will mean you need to install a new driver for this device right click you will have options to update driver,disable,uninstall or select properties again you will have the similiar options also you can troubleshoot the device
This self-extracting file contains the LX-300 driver files, version 2.0, for use on machines running Windows 3.x.http://download.cnet.com/%7Bvalue=http://www.download.com/epson-lx-300-printer/3000-2116_4-10012184.html
cnetdownload.com
on the home page you should see a search tab just type in what you are looking for(be precise)also the download software finder under that there will be a list
platform
category
sub category
price
rom the category drop down list select drivers
them from the price drop down list select free or which ever applies to your need
hope this helps
Jul 06, 2011 | Epson Computers & Internet
Hi. I bought an Epson Stylus TX210 printer not to long ago, and it was working fine. Everything except the scanner. so, my parents and I were trying to fix it and I'm not sure what we did wrong because...
im not sure what i'm and doesn't means
the drivers for the scanner might have been corrupted
you might have to uninstall the printer/scanner restart your computer then reinstall the printer/scanner and its drivers
click start control panel administrive tools computer management device manager scroll to ports(COM&LPT) + to expand you should see a communication port and Ecp printer port you might see a yellow?question mark this will mean you need to install a new driver for this device right click you will have options to update driver,disable,uninstall or select properties again you will have the similiar options you can troubleshoot
hope this helps
Apr 17, 2011 | Computers & Internet
It won't print.. new ink cartridges and alignment failed. Printer is less than 6 months old
hope this helps
Apr 13, 2011 | Computers & Internet
84 Replace PC Kit message and red light flashes, printer will not work. Purchased PC Kit approx 3 wks ago, needs to be reset.
hope this helps
Apr 07, 2011 | Computers & Internet
LasrJetM1132 MFP scanner driver
click start control panel administrive tools computer management device manager scroll to ports(COM&LPT) + to expand you should see a communication port and Ecp printer port you might see a yellow?question mark this will mean you need to install a new driver for this device right click you will have options to update driver,disable,uninstall or select properties again you will have the similiar options plus you can troubleshoot
hope this helps
don
Feb 27, 2011 | Computers & Internet
I want to download driver for my scanner.
hope this helps
dont forget to vote
Feb 17, 2011 | Computers & Internet
Getting earthlink off my computer
Download & install Ccleaner from here
http://www.filehippo.com/download_ccleaner/
In tools select startup tab. Find Earthlink and select, click disable.
Select uninstall & if eaarthlink appears select it run uninstaller. If asked do not reboot.
Select registry and scan for errors, follow prompts to fix errors (back up reg when asked).
Reboot and all should be OK
Oct 18, 2009 | Computers & Internet
Error code 80072745
Disable ESET for a moment and then try to connect to Live Messenger
Apr 22, 2009 | Microsoft Office Outlook 2003 for PC
No Sound at all!
try this link download and install.
http://www.realtek.com.tw/downloads/downloadsView.aspx?Langid=1&PNid=23&PFid=23&Level=4&Conn=3&DownTypeID=3&GetDown=false
Jan 27, 2009 | Computers & Internet
Dell Dimension C521 PC Desktop Logo
20 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
