Question about Midea Heating & Cooling
Multi zone mini split
Install 36000 btu (2X18000) multi zone with 2 25' linesets. Will I need to add additional refrigerant to the unit to install?
  • 2,133 Answers
The package of multi condensor is pre charged. No need to charge again unless if there was leak.
Posted on Sep 03, 2015
Myminisplit
  • 11 Answers
SOURCE: LM-2430C2L 24000 BTU Cooling Only Dual Zone Mini Split Air Conditioner: Does LG makes AC which can cater two rooms at time...
Yes they Do they are called Dual Zone Units. At http://www.paylessminisplit.com they are very helpful if you call them they can answer alot of questions about many brands of mini split air conditioners.
Posted on May 21, 2010
icemelts
  • 246 Answers
SOURCE: Celiera 12000 btu Mini-split ac unit blows cool
It's 'possible' but not likely that you need additional freon.
What is more likely is the 'filter' (for inside coil) is dirty and possibly the coil itself - and/or - the outside coil is dirty.
I would check out the filter - if dirty - I would change it and would also inspect the inside coil. If it's also dirty I would clean it the best I could (with a brush of some sort).
I would also check the outside coil and clean it if need be.
Hope this helps.
Posted on Jun 11, 2010
heatman101
  • 43501 Answers
SOURCE: Brand new LG mini split,24,000 BTU. One indoor
That is a typical indication of a low charge of freon....
Check the charge and also for a leak in the system...
Here is a tip about trouble shooting your air conditioner...
Air Conditioner Trouble -Review the Possibilities
http://www.fixya.com/support/r3571569-air_conditioner_trouble_review_the_possi
heatman101
Posted on Jul 19, 2010
hvac1960
  • 2133 Answers
SOURCE: can a 9k btu and
No you should not, as the total capacity higher tan condenser capacity of 24k
Posted on Dec 13, 2010
  • 125 Answers
SOURCE: Hello We just installed a Sanyo KHS1271 mini-split
The condensate drain line was not properly installed. Make them pull the wall unit and correct the problem.
Be persistant until you are satisfied they have the problem corrected. Do not pay any additional money. If they do not correct the problem then report them online to the state board of heating and air. Fill out their requested complaint form and follow thru with a second complaint if you do not get total satisfaction from the contractor that installed the unit.
Hope this helps.
Posted on Sep 23, 2011
What does E2 code indicates on a Winchester brand ductless air conditioner?
Try turning the power off for 15 minutes.
Tech Tips: How to Resolve E1 and E2 Error Codes - YouTube
? 1:48
https://www.youtube.com/watch?v=COIxQBT-J2k
Oct 14, 2015 - Uploaded by MitsubishiHVAC
In this Tech Tips video, Jeff explains the E1 and E2 error codes, possible causes and some ways to resolve ...Missing: winchester ‎brand
Error Codes - Room Air Conditioner - LG
www.lg.com > Home > Support > Product Help > Help Library May 19, 2017 - An error code on the display of the room air conditioner can usually be ... P2 or FL; CH34; E1 or CH02; E2 or CH01; E3 or CH03; E4; E5; F1,F2, ...
Pioneer Air Conditioner AC Mini Split ERROR CODES And ...
https://removeandreplace.com/.../pioneer-air-conditioner-mini-split-error-codes-and-tr... Jun 19, 2017 - Pioneer AC Ductless Wall Mount Mini Split Indoor Unit Error Code = E2 What Does The AC Error Code Mean? = Zero-crossing signal detection ...
QSHX-242 24000 BTU Mini Split Air Conditioners With Multi-Fold ...
https://www.pinterest.com/pin/542894930052841690/
Panasonic S22NKU-1 Cooling Only Wall Mounted Ductless Mini Split ..... Room temperature, set point temperature and status codes are all indicated on the ... The Goodman brand is well known for affordable pricing covered by some of the ..... Winchester Air Conditioner Quick Connect System 4rac36q-30 - 36000 Btu 13 ...
Sep 27, 2017 | Heating & Cooling
New install Gree 3 head 24k btu ductless mini split. Ran for 3 weeks, then got 3 red flashes on outside unit board. Compressor does not kick on anymore. Fan units inside just blow room temp air.
It's low on refrigerant. Chances are it's on one of the flare fittings where the copper connects to the unit. You should have a one year labor warranty from the installer, should not cost you anything...3 WEEKS???
Apr 15, 2017 | Heating & Cooling
What kind unit is
This type of unit is called a Mini Split Air Conditioner.
Hope that helps you check us out at Air Duct Cleaning
Nov 02, 2015 | Samsung AQV36JA Classic 36000 BTU Single...
The system cannot be turned on. Need a tech.
[PDF]Service Manual - Quietside
https://quietside.com/max/.../Service%20Manual_MAX%20Series.pdf
Samsung Electronics ... Users should not install the air conditioner by themselves. ...If this happens, turn off the air conditioner and contact an authorized service center.... Wall-mounted ...... In a COOL operation mode, the compressor does not.Samsung Electronics ... Users should not install the air conditioner by themselves. ...If this happens, turn off the air conditioner and contact an authorized service center.... Wall-mounted ...... In a COOL operation mode, the compressor does not.
Sep 28, 2015 | Samsung AQV36JA Classic 36000 BTU Single...
New LG mini split installation getting error CH05
I believe the wiring may be incorrect. Here arethe fault codes.
05
Comms Error, check your wiring, remove external pumps. Split/Multi - check volts from terminal N to 3 = 0 - 65 Vdc, Multi V - 4 Vdc terminals 3 and 4
5
Hope this helps
Bob
Aug 08, 2014 | LG LA120HYV Art Cool Premier 120HYV Ultra...
Cant un lock lg 360 need code
You'll need to purchase an unlock code.You will probably find a number of companies via google a I have used a couple, which I'm not sure I'm allowed to post here so I recommend you visit Unlock-Zone.com, which is nearly perfect and they were recommended highly in the cell phone forums.Click the unlock your phone and select the mobile phone, current service provider to get the available unlocking service which ranges from $5 to about $25, depending on the model of phone you have.
Nov 05, 2011 | LG LM360CE 36000 BTU Cooling Only Tri Zone...
I also have a grunaire dual zone mini-split that doesn't work worth a ****. I've had it looked at multiple times and had freon r410a added twice and still nothing. Without the high side - how do you know...
an FC fault on a Grunaire is typically a defective PFC board in the outdoor unit or a Grossly overcharged system, where the drive cannot overcome the standing pressure to start the system up...
the ONLY CORRECT way to charge one of these units is to WEIGH in the charge..
the Label on the side of the unit will give you the correct charge amount.. this is for 25 feet of Lineset on Each indoor unit... typically on a 9 or 12k btu indoor unit (1/4" liquid line) you will add 0.7 oz refrigerant extra per extra foot of lineset.....
the PFC board failure is a very common failure on all of the grunaire / chigo built units...
Jun 25, 2010 | Heating & Cooling
Heating & Cooling Logo
61 people viewed this question
Top Midea Heating & Cooling Experts
Steve F
Mike
Shehu Pro
Shehu Pro
Are you a Midea Heating and Cooling Expert? Answer questions, earn points and help others
