Question about Oregon Scientific Audio Players & Recorders
Fading projector on Oregon Scientific RM818PA-T needs replacing. Hoped to use laser from battery only model. Need instructions to disassemble unit.
Thought I could possibly replace fading laser with one from a battery only unit I bought. Need to know how to disassemble the unit.
SOURCE: Light on the projection is fading
if the led is fading it waring out and it will need replacing try and **** smith electronics or Radio shack take the clock in with you so they can provide better service for you
Posted on Jul 18, 2008
informatica
  • 1114 Answers
SOURCE: need to replace battery on projector on EM-CKS3516.
Hi - You can download the manual from the link underlined in blue below:
EM-CKS3516
Please take a moment to rate this solution & let us know if the information given was useful to you - Good Luck!
Posted on Jul 30, 2008
SOURCE: Wireless thermo clock not reading outside temp
I've had a similar problem with another model, an Oregon Scientific Model IWA-80055 Wireless Thermo Clock, in which when I replaced the batteries in the remote sensor, the clock would not read the temperature from the remote sensor.
I found it fairly consistent to solve this by taking a battery out of place in the clock and putting it back in.  Unfortunately this also messed up the clock's time and date.  This is also in the instructions catalogue for the device, check and see if yours gives a similar solution.
Posted on Apr 13, 2009
leethedeuce
  • 4472 Answers
SOURCE: Need Instruction Manual to operate the clock
http://www2.oregonscientific.com/assets/manuals2/RM826.pdf
This is the link to the PDF, you should have no problems printing it. If you can't print then read the instructions from the computer while you set the clock.
Thanks,
Lee
Posted on May 28, 2009
SOURCE: Manual for oregon scientific rm313PNA
http://pdf.smithgear.com/RM313PNA.pdf
Posted on Dec 20, 2009
I have a Oregon Scientific weather radio. I have lost instructions and am try to figure out how to set alert status by counties.
From the Oregon Scientific site top ten questions: click the link below to download the manual for the model number of your radio:
Manuals XF
Apr 08, 2015 | Oregon Scientific Audio Players &...
Oregon scientific model no rar186 how to set up outdoors sensor
I have had this Oregon Scientific model RAR186 unit for years and it works great. The only issue I ever have is when the batteries need to be changed in the remote sensor unit (Oregon scientific model #THN122). It never fails that once I change the batteries that the unit does not send a signal to the base unit. I will often hit the reset button and change the channels on the remote sensor before I finally remember that you need to do the following to get the sensor to talk to the RAR186 base unit:
On the base unit (RAR186), hold down the CHANNEL and MEM buttons for at least two seconds.
You will then see a graphic appear above the channel number that shows that it is searching for the sensor.
Within a minute, you will then see the temperature displayed for the sensor showing that they are communicating.
This is buried in the manual that you probably discarded as did I.
Apparently, if your sensor is broken, you can either search to find a new sensor of the same model or also use the following sensors: THC138, THGR122NX, or THN132N
I have not needed to replace the sensor as once I found the instructions to reset the communication between the sensor and base unit, all was fine. Hope this helps someone. I wrote this instruction using a Sharpie on the inside cover of the sensor since you have to remove 3 screws to replace the AAA batteries (2) in hopes I will remember next time and not waste my time searching the internet and not find the answer. Good luck!
Apr 02, 2013 | Oregon Scientific Measuring Tools &...
Remote sensor (thn122) not working, batteries changed, terminals cleaned
Mar 05, 2013 | Oregon Scientific Measuring Tools &...
ONLY SHOWS INDOOR TEMPERATURE DOES NOT SHOW OUTDOOR TEMPERATURE
I have a similar device and the instructions say to remove batteries from both units and wait for 10 minutes without pressing any buttons before installing batteries first in the remote unit then the indoor unit. The outdoor and indoor units have to "talk" to each other before getting in the mood to display temperatures.
Feb 03, 2013 | Oregon Scientific Wireless IndoorOutdoor...
The projection part started to flicker one day and now it doesn't work.
if you get display on clock it may be the bulb, if it is totally dead check batteries. here is a manual for the clock
www2.oregonscientific.com/ulimages/manuals2/RM818PA.pdf
good luck
Jul 12, 2011 | Oregon Scientific RM 818P Clock Radio
Outside temp does not read new batterys in both inside & outside unit
Double check the batteries to make sure they are installed correctly. If one of the batteries in the outdoor sending unit is in backwards, it will not send the outdoor data. On the indoor unit, there is typically one battery that is used for receiving the signal from the outdoor unit. If all of the batteries are in correctly but that one, you will see the display and the indoor temperature information, but the outdoor information will not be displayed.
Aug 21, 2010 | Acu-Rite AcuRite IndoorOutdoor Wireless...
Dashes in my outdoor weather reading of Oregon Scientific station
The signals are not being received by the main unit. Try to reposition the unit or move it to a different location. Also make sure the antenna is in the clear and not next to any thing like a cordess phone or charger as these can make RF noise that can block or cover the needed signals.
Feb 07, 2010 | Oregon Scientific Audio Players &...
Sir, oregon scientific model 188 is not sync. It says error. contact for assistance from you. pl help
How are the batteries in the remote unit. Is it or the terminals corroded in any way?
Jan 14, 2010 | Oregon Scientific Lwb0997110113004...
80 people viewed this question
Top Oregon Scientific Audio Players & Recorders Experts
Mohammad Abumuailek
Mohammad Abumuailek
Gyula Lacz
Are you an Oregon Scientific Audio Player and Recorder Expert? Answer questions, earn points and help others
