Question about Dryers
Zanussi Washmachine error codes
My Zanussi washmacine F1226 blinkes 5 times as a errorcode. What is the problem.
2 Suggested Answers
  • 50 Answers
SOURCE: Power 5 time blinks
The blinking code means something is wrong with some components.
It is usually caused by over heating compenents.
Remove the back panel and blow out all the dust using compressed air.
Then vacuum.
Posted on Mar 10, 2010
Zanussi jet system washer error code 247.whats this mean?
Nothing. It is not error code, maybe is time washing for example: 2 hours and 47 minutes. All errors code starts with letter "E" and two numbers or only with two numbers.
Dado
Dec 12, 2016 | Zanussi Washing Machines
Zanussi zwn 6120 l washing machine Error code 5 red 1 green
Your washing machine show the error code E51 what means faulty electronic (triac short circuited). Replace PCB.
A good idea is to check the motor, which in practice can cause this failure (shor circuit motor winding) and sometimes is necessary to replace the electronics and motor and than is question profitability of repair.
Dado
May 07, 2015 | Zanussi Washing Machines
Zanussi washing machine fs1255w green end light flashes 5 times what is this error code
Press START/PAUSE and any one of the option buttons
simultaneously for at least two seconds: the LEDs first switch off,
and then display the flashing sequence corresponding to the
alarm condition.
Examples:
Alarm E43 (problems with the door safety interlock triac) will be displayed as follows:
• four flashes of the END OF CYCLE LED indicate the first digit E43;
• three flashes of the START/PAUSE LED indicate the second digit E43;
So, error code E55 as you specified does not exist. Any how, family error code 5 (first digit) means problem with motor. Error code could be E51,E52,E53 and E54.
Possible causes:
- faulty motor
- motor brushes (very often)
- faulty tachometer (integrated in the motor but is replaceable)
- faulty electronic (Motor power triac short-circuited or motor relay contacts sticking).
Dado
Jan 18, 2015 | Zanussi Washing Machines
My machine had been giving E20 error code - cleaned out filter and pressed start button and it started again ok. During wash it jammed and all lights went on (except spin speeds) and it wouldn't...
E20 is a general error code to get to the real problem try this.. Reading ErrorCodes 1. Wake the washer by pressing any button. 2. Wait 5 seconds. 3. Press and hold
Oct 11, 2011 | Zanussi ZWD1470W Front Load Washer / Dryer
F21 error on kenmore he2plus washmachine. Door locks. Due to no spinning and water remaining in the machine? I run the rinse/drain&spin program (15 minutes) several times. it stays at 15min remaining...
"F21" is a Long Drain error. If the drain time exceeds 8 minutes this error code will be displayed. In addition, a "SUDS" error may also be displayed. This may be an indication of a drain pump problem and/or clog in the drain line. You will need to check the following:
1.First, attempt to unplug the washer for at LEAST 30 minutes to reset the Central Control Unit (CCU). Sometimes this is all that is required to correct momentary glitches with the unit. If the error code returns, proceed to step 2.
2.Check the drain hose to make sure it is not kinked or clogged.
3.Check the electrical connections to the pump and ensure the pump is running.
4.Remove the drain pump filter and check for foreign objects and/or debris.
If the above procedures do not correct the problem, it is recommended by the manufacturer to replace the drain pump.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Mar 23, 2010 | Kenmore HE2 Plus Front Load Washer
Error code E20 comes on during a wash cycle. i
If the filter is clean and the hoses are free of obstructions,you will need to replace the pump
Oct 18, 2009 | Washing Machines
Zanussi tumbledrier TC7103W not heating
Common faults -
1 The heating elements can fail (meaning open circuit)
2 There are cut-outs (T.O.C's) that might need resetting
3 The thermostats (stats) can trip out or burn out (meaning opencircuit)
4 Moderntumble dryers also have sensors and pcb's (Printed circuitboards) thesehave programs that can fail and circuitry although most should produce an errorcode showing you were the fault is.
5 Faultyconnections and burned wires may also be the fault.
Free tumble dryer repair videos
We have a Free full video library on appliance repair video’s
Aug 30, 2009 | Zanussi TC7114W Electric Dryer
Error code e60
Hi I had this on my zanussi not long ago I pressed the reset button in for 5 seconds and it stopped . The computer board needed resetting. Hope this helps
Jul 07, 2008 | Zanussi ZWF1440 Front Load Washer
Zanussi ZSF 6161 Dishwasher error codes
i have got an zanussi des 959 and showing falt code 5 could u help me out
Jan 19, 2008 | Dishwashers
Zanussi electrolux frost-free
blinking is an error code of your fridge
I don't know the model of your fridge but try this it may help
IF THE CONTROL LOOK LIKE THIS
Jan 04, 2008 | Zanussi ZX97 / 5 Bottom Freezer...
Dryers Logo
11 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
