Question about Mag Innovision 19" LCD Flat-Panel Monitor LT916S
Screen goes white
When I wake it from hibernation or screen saver, it just goes pure white.
I have to power it off then on a few times before it will display normally.
Would the capacitors have anything to do with this too?
  • 1 more comment
  • Anonymous Dec 02, 2007
    Yea my display does the same damn thing. i don't know what to do. Anybody have fix for this?
  • Anonymous Dec 07, 2007
    yeah men my 17" hp pavilion screen goes white in few seconds...seems covered by fog! I experienced that expecially when installing new video drivers. then I have to close all application or turn off PC
    anybody got an explanation?
  • IcyHOT Mar 07, 2008
    One monitor went white, the other black. The fix for the monitor turning black worked for both. I had a friend examine the capacitors on the power supply board. There was a group of 7 close together, all of them were replaced on both monitors for under 15 bucks.
    Been two months now and working fine.
  • 138 Answers
Hi this is the way how to examine what's wrong with your LCD monitors. After you turned it on and the screen went white, you have to check that if you can see the image on the screen or not by shining a flashlight into the screen, not directly but find the best angle to the screen and take a look very closely. If you can see the icons or any image, there will be a minor problem. This is because of the lamps inside screen. Some of them were broken and it is very easy to replace. If you cannot see anything on the screen, there'll be some problems with inverter board. If you have soldering tool and want to fix it by yourself, check the caps first. It may cause this problem. Some caps might show leaking or burn spot on the board because of too high temp. If you don't have soldering tool, you better go get a technician to do so. Hope this help!! If anything I can help you with, feel free to let me know.
Thank you,
Posted on Mar 07, 2008
I put my Dell Dimension 9200 XPS 410 into sleep mode after connecting a wireless keyboard and mouse and the only way to wake it is to hold the power button in until it shuts off and then switch the power...
I would say it is in the Hibernation Mode To get it out of this mode you need to go to your Control Panel, open "POWER OPTION'S" and deselect the Hibernation mode then reboot.
Sep 26, 2013 | Dell Dimension 9200 PC Desktop
After a while my Lenovo A600 screen turns white and i have to tap the power button to get it back?
If you have adjusted the power settings to HIGH PERFORMACE and ajusted the ADVANCED Power settings to NEVER, Sleep, Hibernate, Dim, etc., etc. Have you updated the Graphics drivers? Lonovo support: Is ther a set time it goes white, say 10, 20, 30 mins.? What is your Screen Saver Time? Found in Display Settings or in Win 7 Personalize. I don't know your OS, Win. Vista, 7?
Nov 29, 2012 | Computers & Internet
Laptop does not wake up after sleep
I see this problem a lot, in most cases it is a problem with the ACPI driver. The easiest solution is to make changes to the Power Management settings. What happens is part of the computer goes to sleep and part goes into hibernate. Unless I am trying to conserve battery power I set the system to always on and use the screen saver to protect the screen from damage. If I am looking to save battery then I still set the screen to always on with the black screen saver and set the rest of the settings to sleep with no Hibernate settings. Hibernation is nice but really does nothing more than write data to the hard drive so the system can restart and you do not save anytime allowing it to operate. It causes more problem in configurations than it solves. In fact the only machine I might consider using a Hibernate setting on would be a server.
Nov 14, 2011 | Computers & Internet
Goes into hibernation won't come out of it if not active for about an hour or so. running win7 and have set the power settings to never hibernate. i've learned through experimentation that once it's...
Try setting your screen saver to none. That might sole the hibernation problem. Sometimes a computer will go into hibernation if the screensaver has been on for a while.
Mar 15, 2011 | Lenovo IdeaCentre K210 - 53133BU PC...
Notebook nc10 screen keeps going white when in use.
Check that hibernation mode is not on, that screen saver is not set, or that monitor is not set to power off in a short amount of time.
You can go to control panel, display, and adjust from here under screen saver settings and power options.
Sep 23, 2009 | Samsung NC10-14ROBL Notebook
My name is Luis and my Ibm thinkpad r40 keeps freezing and my screen goes black.
Hi, could be simply your computer is going into sleep mode and not waking back up. try changing your screen saver option to not hibernate or sleep.
Aug 18, 2009 | IBM ThinkPad T40 2373 Notebook
Dell E173FP Monitor requires unplugging/plugging back in to wake
Perhaps your computer is hibernating instead of going into standby which takes a little longer to wake up from. While you are playing plugs and cables it give it enough time to come out of hibernation.
When the computer is in this mode the USB ports turn off which disables keyboard and mouse so the only way to wake up the computer is to press the power button on the computer itself.
One tell tale sign a computer is in hibernation is that the power light on the computer will slowly blink.
I hope this helps.
Aug 08, 2009 | Dell Computers & Internet
Dell Inspiron 1100 screen goes into power saver mode after 45 sec
it sounds like your most likely having trouble with the hibernate feature try this
start>>control panel>>power options>> click on the hibernate tab
un check enable hibernate mode
this should fix your issue
Apr 10, 2009 | Dell Computers & Internet
My computer comes out of standby mode after 3 minutes. i checked the BIOS and there's no Wake up on LAN option!
It is probably a setting in windows that is your problem.
Try This, Right click your screen and select properties,select the screen saver tab, then select the power button. If you don't want power saving highlight never for the monitor and hard disk. Then go to the hibernation tab and disable ok to all screens to back out. Hope this helps.
Dec 18, 2008 | Computers & Internet
Digital power saving mode
check your monitor power settings.
right click on your desk top then left click on 'properties' in the white box that appears.
this will bring up a 'display properties' box which should have a tab headed 'screen saver' amongst others.
select the screen saver tab.
in this tab there are 2 sections. one to select which screen saver you want to use (and what settings are applied to it), and another section which should be called 'monitor power'.
click the button here which says 'power...' to adjust your power settings.
in the next window there are 4 tabs. select the first tab (power schemes - which should be already selected by default) and you now have 4 options. leave the selected 'power scheme' in the top of the window as it is and just alter the settings for the selected power scheme.
your 4 options are: 'turn off monitor', 'turn off hard disks', 'system standby' and 'system hibernates'  i would recommend setting all of these to 'never', and don't forget to click the 'apply' button after you've done this.
i would also recommend disableing hibernation in the 'hibernate' tab (this is in the same window as the power schemes tab).
once you've adjusted your power settings, don't forget to activate one of your screen savers.  this is only important if you leave the monitor on for a long time with no changes taking place in terms of what is being displayed. if you leave a static image on for hours you will end up with permanent screen burn. (a ghost image that is always there - even when the monitor isn't switched on!).
i don't bother with screen savers personally as i find them annoying, and find it much easier to simply turn the monitor off whenever i'm not going to be using it for the next hour or more.
hope that solved your problem. apologies if it doesn't.
by the way, the tabs etc i described are what i have on my OS (windows XP pro) and may be named differently if you're using a different version of windows.  the 'power options' settings will still be accessible via 'screen saver' tab in desktop properties though.
good luck!
Oct 11, 2007 | Gateway FPD2275W LCD Monitor
Computers & Internet Logo
108 people viewed this question
Top Mag Innovision Computers & Internet Experts
William Miller
William Miller
Rommel Balcita
Are you a Mag Innovision Computer and Internet Expert? Answer questions, earn points and help others
