Question about Kitchen Ranges
Replacement knobs for mabe stove model JEM1770XO
Original stove knobs damage cannot turn . Need replace
SOURCE: I have GE Sealed
AH ha, I found one with these guys after a painful online hunt. I hope this helps. it was like $7.57 after the cheapest shipping option. but you can get the part number from the same link and keep hunting. http://www.appliancepartspros.com/partsearch/model.aspx?model_id=214753
Posted on Jul 20, 2008
SOURCE: I need metal replacement stove knobs.
My Jenn-Aire stove knobs melted and also crack at the base because they are plastic. I got new ones from Jenn-Aire after my 1 year warranty was up after arguing with them. The new ones are also cracking and melting (2 unrelated problems). I now cannot be sure the gas is off because they do not fit tight on the stem, so when you think it is turned off it really isn't. I just alerted Jenn-Aire about this serious safety/fire hazard and they are sending someone to my house to check out the stove. All I want is new knobs that aren't cheap plastic! They said they were unaware of the problem. I can't believe I am the only one this has happened to.
Posted on May 17, 2010
woodchuck789
  • 4070 Answers
SOURCE: Hot Point stove model #RB787WH1WW,
Yes, The control for that one burner is the problem since the others are OK. Here is a DIAGRAM and parts list.
Posted on Jan 14, 2011
bblizard
SOURCE: Mabe Stove Parts
replacement glass top for mabe gas stove top
Posted on Feb 16, 2011
Kenmore gas range 790, not getting gas to the stove top, oven works, all 4 igniters fire when any knob is used. Is this a safety shutoff and how do I fix it?
Burner Spark Electrode Replacement - Kenmore Gas ...
? 2:23
www.youtube.com/watch?v=U0VcfMJPaiY
Nov 12, 2010 - Uploaded by RepairClinic.com
+Tony Eatinsky If the electrode is not damaged than the spark module ... I have a kenmore gas stove ( 362.7555190) that won't ignite unless I use a match. ... I have a Kenmore Elite 5 burnergas range top, it auto light continually sparks? .... You most likely will need to cut or grind off the screws and get new ...
kenmore model 790 gas range. the gas stove top burners ...
www.shopyourway.com > Manage My Life > Questions
kenmore model 790 gas range. the gas stove top burners stopped sparking. ... NOTE: I do not recommend measuring voltage unless you have experience and feel ... if the spark module is getting 120 volts when the burner knob is turned to the ...
Oct 19, 2015 | Kenmore Kitchen Ranges
Where can I go near Polanco to find replacement knobs for my stove?
Actually, I'm not sure where is "Polanco"; guess you are in Mexico City?
Now, to find a site where you may get parts for your Kitchen Range or stove, you should do a google search indicating terms
Parts, Make and Model of your Kitchen Range and Mexico city
If you can't find one near, you might search for an international website, contact them and maybe they can send it to you via some international courier service
Aug 06, 2015 | Kitchen Ranges
One of the nobs on the front of my gas stove is broken and i would like to know where i might get a replacement on ? the burner still works if i push the nob back on and turn it but it is broken in half...
Hello Danny, I have seen replacement knobs at Home Depot and Lowe's Hardware. Write down the make and model number of your stove and take a knob with you to compare.
Mar 24, 2015 | Kitchen Ranges
My oven wont turn off from the knob it keeps turning
You didn't say whether you have a gas or electric oven, or oven & stove. I'll assume you have a stove, just to cover all bases.
First, you should shut down the oven: a gas stove will have a valve on the gas line behind the stove. The valve will either have a red handle or a flat stem that usually has a hole in it. Turn either valve 1/4 turn to shut off gas, use a wrench on the flat stem. An electric stove should be shut off by flipping off the double circuit breaker for it in your electric panel. Do not unplug an electric stove when it is on; this can damage the plug &/or electrocute you.
Most likely the inside of the knob has stripped out. Look at the knob for a hole that has a setscrew in it: a small allen wrench or screwdriver will loosen the setscrew, most knobs don't have them and will pull off. Be careful to use even pressure on two sides of the knob; if you can't pull it off, use two butter knives or flat screw drivers to pry it up enough to get a grip on it.
Look at the center stem on the back of the knob, it will likely be cracked or stripped. Some stems have a D-shaped metal insert that strips out inside the plastic stem. If you have one, pull off a burner knob and compare the stems in the back, if they are the same size, put the burner knob on the shaft for the oven control, and use that knob to turn the oven control off.
If the burner knob won't fit, use your fingers or a pair of pliers (gently) to turn off the oven control shaft. If the shaft stops normally, you can turn the stove back on using either the gas valve or the circuit breaker. If you have a gas stove that doesn't have electric ignition (a clicking noise when you turn on a burner) you may need to re-light the pilots for the burners. Lift the covers off the burners to re-light the pilots.
If you have succeeded in turning off the oven, you need a new knob -- you can get one at an appliance parts store or maybe a hardware store. If the oven control did not turn off normally, I would leave the oven/stove turned off: the control itself will need to be replaced by a qualified repair person.
Mar 03, 2013 | Ovens
GAS OVEN KNOB STUCK
The valve is 'seized'. Grease gets into them and over time turns acidic corroding the valve from the inside out. Replace the valve. Any appliance parts seller can get it for you. Turn off the gas before starting repairs!
Apr 30, 2017 | Whirlpool SF325 Gas Kitchen Range
MABE Stove Manual in English Model : EM6120B2
hello i recently bought a mabe 6 burner gas stove but i need to know the manual is not in english and do i have to plug in before i can turn the gas on? its electronic ignition by the way
thanks
customer
May 19, 2010 | GE Profile Spectra JGBP90 Gas Kitchen...
Mabe Stove Parts
Aug 27, 2009 | Blodgett Kitchen Ranges
www.sears.com go to the parts dept and have make and model ready....this will fix ya!
Dec 11, 2008 | Kenmore 46123 Stainless Steel Electric...
Kitchen Ranges Logo
159 people viewed this question
Top Kitchen Ranges Experts
Oloyede Monsuru
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
