Question about PetSafe Eatwell 5 Meal Pet Feeder
Where can I buy a replacement motor? - PetSafe Eatwell 5 Meal Pet Feeder
I have a champion generator with a Briggs and Stratton 12 up motor that someone put antifreeze and oil in and it froze up is there anyway this can be fixed
the generator section is ok just motor needs to be repaired or replaced if you know how to rebuild a small motor can buy a rebuild kit but you might encounter internal damage cracks in blocks which would make a replacement motor more cost effective or depending on power needs might be cheaper to buy another unit compare costs of repair ,replacement or complete replacement
Aug 28, 2016 | Briggs Electrical Supplies
Tip
Outboard motors
Keep the gas in your outboard new/clean with new oil every 6 months..Keep your motor covered when not in use, Dirt dabbers (dobbers) will build nest under the hood and break loose and ruin your motor, ,,Change your water pump and thermostate every year when motor is used a lot.....Dont run stainless steel props on small hp motors ,when you hit a log it will bend your prop shaft costing big $$$ to replace..Ck your lower gear oil if water is noted ,replace lower seals...Dont buy used motors unless you run a compression ck....ck for water in gear case , Dont buy 4 strokes to heavy to slow to many parts AND are being replaced by fuel injection 2 strokes .... Dont buy FORCE motors not made by mercury no parts being made and or extink and pure junk . Etex best motors , .
on Mar 16, 2011 | Boating
I have a Jacuzzi Magnum 1500 pool. I want to replace the bearing on it. Which bearing size should I buy Motor is a Century Centurion 7-186087-20
Most pool pump motors use 6203 2RS. There are two in each motor. If you haven't done this before I wouldn't attempt it. Once the motors get to a certain age you cannot get the 4 thru bolts out to disassemble the motor. Plus you need a bearing puller. I suggest buying a replacement motor for under $200.00
Jul 29, 2014 | Jacuzzi Pool & Spa
2004 Buick Lesabre blower motor repair
You dont.
Replace the motor.
Buy a good one at Napa or Autozone. Dont buy advance because they have poor quality electrical parts in my experience.
Install new motor. Done.
Mar 14, 2014 | 2004 Buick LeSabre
Motor wont start but runs without the belt on
replace the new capasitor,the capasitor is placing near the motor,unplug the unit before remove it and be carefull to touch the pin of the capasitor coz of high voltage,check the micro farad of capasitor and buy a new one,,but sometime the motor also problem if the motor have water mark is means replace the motor of new one,but ask the price of new one if is expensive try to buy a new one with 1warranty compare the motor you buy is only 1month warranty.
Dec 24, 2010 | Maytag Neptune MDE5500AY Electric Dryer
Dryer motor noisy, service call said bearing are shot in motor, replace motor is as costly as new dryer all most. Where can I order new motor best buy as neighbor can install motor( Doctor electrical...
<span style="FONT-FAMILY: 'Trebuchet MS'; FONT-SIZE: 10pt; mso-ansi-language: EN" lang="EN">Hi,<br />Yes, that is not that hard to fix and you can easily buy the parts yourself online...<br /><br />Here is a tip that will help you with the online buying...<br /><br />How to Buy Appliance Parts Online<br /><a href="http://www.fixya.com/support/r3907570-buy_appliance_parts_online" target="_blank">http://www.fixya.com/support/r3907570-buy_appliance_parts_online</a><br /><br />heatman101 <br style="mso-special-character: line-break" clear="all" /></span><br />
Aug 26, 2010 | GE Profile Harmony DPGT750EC Electric...
Dyson dc14 Animal motor brush replacement
By the time the brushes are shot, so is the armature. You need a motor.
Oct 24, 2009 | Dyson DC14 All floors Bagless Upright...
I have a Kenmore series 80 that I bought it used two years ago, it now has a bad motor, it was manufactured in '96. I replaced the motor coupling a month ago. My question is, is it worth replacing the...
hello, i'ld say buying a new motor is far cheaper then buying a new unit unless the maching is in bad condition for a new motor your looking at anywere from 50.00-175.00$ depending on the model number of your machine. good luck on making your decision, and if you decide to buy the new motor and need help finding one let me know i can help you find the motor you need.
Mar 22, 2009 | Kenmore 24442
Need replacement motor for Ventamatic Attic Fan
common motor. get from butler ventamatic or Johnstone Supply if you have an account. Hint, buy a whole new fan for $60; cheaper then buying piece by piece, then you get a new blade,motor and tstat for a little more then motor alone costs.
Apr 26, 2008 | Ventamatic Gable Mount Power Attic...
PetSafe Eatwell 5 Meal Pet Feeder Logo
23 people viewed this question
Top PetSafe Pets - Others Experts
Ross Keen
Tom Chichester
Ruth summersides
Are you a PetSafe Pets - Other Expert? Answer questions, earn points and help others
