Question about Kitchen Ranges
Where is the start button once you press bake on kitchen aid ykera205
  • 77 Answers
SOURCE: how do you turn on
Check the manual, or your 8 yr old.
seriously though if you have an auto set use it and the oven should go to 350. otherwise push bake and set temp then push start if you have that button. hope the cake comes out good.
Posted on Jun 14, 2008
  • 338 Answers
SOURCE: Kitchen Aid oven does not get up to temp.
you can only calibrate the oven + or - 35 degrees. if you are over 35 degrees off you will need to ohm your temperature probe to see if you get about 1280 ohms if you do then you need to replace the clock control. if you ohm the temperature probe and you are off by more than 10% then you will need to replace the probe. in most cases both the control and probe would need to be replaced.
Posted on Feb 02, 2009
SOURCE: I have a Kitchen Aid range model KGST307GBS0. The
The door light switch was broken (upper right face of oven). The door switch is automatically activated when the door is opened to turn on the oven light. When the door is closed the switch is depressed to turn off the light. It seems the switch position is detected by the oven and if it is in the open position it will not allow the oven to function properly (reach temperature or allow the cleaning cycle to run). I temporarily locked the broken switch in the closed position, which allows the oven to function. A new switch was ordered for replacement.
Posted on Jan 03, 2010
pappapumpdaf
  • 635 Answers
SOURCE: Kitchen-Aid Electric control panel buttons stopped working
This may sound facetious, so don't get offended.
Did you set your clock to the correct time?
Did you clear any and all preset timers?
If none of that helps you can usually find roaches in the strangest places. If you have no roaches, then moisture and heat are the likely culprits which means that your blister pads are simply worn out. Unfortunately these are coated with graphite and don't last forever, so a timer replacement would be your only option unless your touchpad is separate from your timer.
Posted on Mar 05, 2010
  • 574 Answers
SOURCE: Replace oven baking element on Kitchen Aid model # KESC300BWH6
It is easy!! After you remove the two screws pull straight out and do so easily, there are two female spade connectors on the element that you'll have to remove. When removing don't pull on the wire itself,pull on the connector. You may have to use pliers.
Posted on Apr 05, 2010
Kitchenaid ykera205
You will need to replace the control panel. Here is the part to order.
All parts come with a 365 day, any part, any reason return policy.
Oct 14, 2013 | Kitchen Ranges
Oven temp is lower then display
kitchen aids website has the manuals available for download. page 33 has the procedure. opent eh dorr and hold "bake" pad for 5 seconds until you hear the beeb then press "bake" again for each 5 degrees you want it adjusted. If the oven is not hot enough add 5 if it is too hod make it a -5. the range is 35def farenheit either way.
Nov 20, 2011 | KitchenAid KGST307 Gas Kitchen Range
Just installed whirlpool rbs305 oven. Get error code E-5 on the panel. What does this mean. When I press bake button and then try set the temp nothing comes on the control panel, doesn't say bake and...
EVERYTHING I SEE ON THE E-5 OR EVEN THE F5 CODES are related to the door latch mechanism/switch may want to make sure the wire to the door latch/switch is ok and connected/// i hope this helps you out coming straight off the whirlpool / kitchen aid site though what those codes are related to....good luck
Jan 05, 2011 | Kitchen Ranges
Kitchen aid dishwasher not draining....help
Here is a tip that I wrote that will help you with your dishwasher not drainingproblem...
Dishwasher Problems - Water will not drain out
heatman101
Apr 05, 2010 | KitchenAid 24 in. KUDM01TJ - Multiple...
I do not know how to use the DELAY cooking feature, please help! MM
Kenmore Elite: Press the start delay button...enter the time to start...wait for the delay light to stop blinking...both cleaning and bake buttons will blink...press bake button...enter temperature for bake...wait for current time to be displayed...press the cook time button...enter the length of time for which the recipe calls.
Mar 03, 2009 | Kitchen Ranges
Bake button doesn't work even after ignitor replaced
While unlikely, the ignitor in theory could have damaged the ERC (main oven control) it is more likely you have a bad keypad. Try pressing and holding bake and broil pads at the same time for 5 seconds and see if the display shows SF (will look like 5F). If it does, press the start button and try again bake again
Dec 02, 2008 | GE Profile Spectra JGBP79 Gas Kitchen...
How do you turn on the kitchen aid superba electric oven, I'm trying to bake a cake...please help
Jun 14, 2008 | KitchenAid Kitchen Ranges
Can't attach beater to kitchen aid
good day,
hope this link below will solve your problem.
kitchen
Dec 13, 2007 | KitchenAid KITCHEN AID 5 Quart Artisan...
Oven stopped 5 to 10 minutes after pressing START
sounds like a wiring problem check your power source
Nov 29, 2007 | Whirlpool RF262LXS Kitchen Range
Kitchen Ranges Logo
14 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
