Question about SimpleTech Computers & Internet
Wd5000H032 can't see thr drive - SimpleTech Computers & Internet
My car hase no power looks likecit go in to limp mode i had thr battry disconected for an hourgen that afectit ?
You need to read the fault codes, but if you disconnected the battery the codes will have been erased, so you need to drive it until the check engine light comes on and then run a fault code test. Until you have the fault codes you might as well be in a pitch black room looking for the matches to light a candle.
Aug 15, 2016 | Cars & Trucks
CD drive door is jammed
There is a tiny hole just below thr CD drive tray. Straighten a paper clip and insert it into this hole and gently push the paper clip until the drive tray pops out. You can then pull the tray out to the fully opened position.
Feb 09, 2012 | Dell Dimension 4300S (Refurbished)...
How do I password protect a Sandisk Cruser 4 gig flash drive on a Mac?
go to Sandisk site there is free software for Cruser Flash just donwlod that software it will sun in Gruser only
in that software option is thr to have password for it
May 02, 2010 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
TAKEN OUT A TOSHIBA 80GIG DEAD DRIVE, lAPTOP
It is an IDE hard drive. Thr IDE drive will have a double row of 44 data pins
Mar 29, 2010 | Toshiba MK8025GAS 80 GB Hard Drive
Got simpletech duo pro enclosure. Put 2 X 500 GB SATA drives. XP tries to initialize 8GB drive and fails. need drivers?
disconnect the
usb cable from the drive and hold in the reset button on thr drive wth a oaoer clip for 4 seconds while the drive is running, rebout your system whith the running and you should be able to format through manage drives
Oct 03, 2009 | SimpleTech 1TB SimpleDrive Pro Duo...
Add additional DVD Disk Drive
well buddy u need to get an IDE drive and the cable u will find a Vacant IDE port on ur mobo.this should fix it
Jun 13, 2009 | HP Computers & Internet
External hard drive write protection cant undo
Try this:
Start > run > cmd
press enter
type: chkdsk /r F:
replace F with thr drive letter of your external drive. press enter
post your results.
Jul 20, 2008 | Computers & Internet
Computers & Internet Logo
19 people viewed this question
Top SimpleTech Computers & Internet Experts
Gareth Cockram
Gareth Cockram
Lyle Siemens
Lyle Siemens
Are you a SimpleTech Computer and Internet Expert? Answer questions, earn points and help others
