Question about Healthometer Health & Beauty
Kg to lbs
Changing the kg to lb
SOURCE: Tanita, the Ultimate Scale
The scale may have instructions on the bottom of the scale. (Example for the Tanita: The Ultimate Scale w/ the body fat analysis). The instructions on the back state the following steps: Step 1: press both the "Set" and the triangle buttons. Step 2: press the "triangle" button until you select the appropriate weight measurement (a) kilogram, (b) stone lbs or (c) lbs. Step 3: press the set button.
Posted on Nov 20, 2008
SOURCE: I can not change measuring The omron scale model HBF-400
how can change lb to kg
Posted on Dec 07, 2008
SOURCE: Scales show weight in kg. How to get them to show lbs.
Body Fat Monitor/Scales: TBF-611, TBF-612, TBF-621, TBF-622, BF-541, TBF-560, TBF-572. UltimateScales: 2000, 2001, 2001T. BF-662, BF-555, BF-556, BF-558, BF-559, BF-625, BF-626.
Press the Set and Up Arrow buttons at the same time. Release the buttons, the display will flash. Press the Arrow button to cycle through each weight mode until just the mode that you require is displayed. Then press Set. The display screen will flash to confirm your selection and store in memory.
Note: If weight mode is set to pounds or stone-pounds, the height programming mode will be automatically set to feet and inches. Similarly, if kilograms is selected, height will be automatically set to centimeters.
Posted on Mar 14, 2009
SOURCE: can not change from Kg to Lbs
Flip over the scale, on the back there is a black button, slide it to pounds.
Posted on Apr 05, 2010
SOURCE: How to change from kg to lb on visage glass
how to change from kg to lb
Posted on Jan 09, 2011
What is the correct metric weight for 13 stone.
14 lb = 1 stone
so 13 stone = 182 lbs ( troy )
182 lbs = 67.929 kg
or in ave poy lbs
182 lbs = 82.5 kg
the difference is depending on which country you are in
Jun 07, 2017 | The Health & Beauty
Conversion from kg to lb
Multiply by 2.2 to get lbs. In this case, 84 kg should convert to approximately 184.8 lbs.
Aug 19, 2014 | Cars & Trucks
What is the air pressure for shocks on a 97 flhtc
I do not know but you could call a Harley Service department or better go there in person and ask.
Recommended Suspension Air Pressure: FLHX, FLTRX, FLHR/C
Solo rider up to 150 LB up to 68KG10-20 0 psi0kPa
Solo rider up to 150-200 LBup to 68-91 KG0-10 psi0-69kPa
Solo rider up to 200-250LBup to 91-113KG10-20 psi69-138kPa
Solo rider up to 250-300LBup to 113-136 KG20-30 psi138-206kPa
Solo rider up to over 300LBup toover 136KG30-50 psi206-345kPa
Solo rider with capacity luggage of 40 lbs (18 kg) up to 150LB up to 68KG 10-20 psi 69-138kPa
Solo rider with capacity luggage of 40 lbs (18 kg) up to 150-200 LB up to 68-91 KG 20-30 psi 138-206kPa
Solo rider with capacity luggage of 40 lbs (18 kg) up to 200-250 LB up to 91-113KG 30-40 psi 206-276kPa
Solo rider with capacity luggage of 40 lbs (18 kg) up to 250-300LB up to 113-136 40-50 psi 276-345 kPa
Solo rider with capacity luggage of 40 lbs (18 kg) up to over 300LB up to over 136KG 50 psi 345 kPa
Rider plus passenger ALLWeights 40-50psi 276-345 kPa
Maximum GVWR ALL Weights 50psi 345 kPa
If Tour-Pak is installed, add 5-10 psi (34-69 kPa) to shock pressure.
Do not exceed 50 psi (345 kPa) suspension pressure.
Apr 17, 2014 | 2001 Harley Davidson FLHT Electra Glide...
Kg to lbs calculator
One kg is about 2.204 lb, so 20 kg is about 44.09 lb.
Apr 06, 2014 | Office Equipment & Supplies
How to change a Bfm883dqn 01 from kg to lb
Hold the 1st button down until kg pops up on the screen. Let button go, hit 1st button again, it should change to lb. hit select button. Should stay on lbs.
Jul 06, 2012 | Healthometer Health o meter BFM883DQN 01...
How to convert from kg to lbs on the defrost cycle
.45 kg = 1 lb
2.22 lbs = 1kg
So if you know kg and need lbs. multiply the number of kg by 2.22. for example if you have 4 kg
4 x 2.22 = 8 lbs
May 10, 2010 | Panasonic NN-H275 Microwave Oven
How to change kg to lb and km to mi
Multiply the reading in kg by 2.2 to convert it in lbs
Divide the reading in kms by 1.67 to convert it in miles
Nov 03, 2009 | Gaiam Walking Fit Kit Pedometer Advanced
Oct 31, 2008 | Omron HBF-400 Fat Loss Monitor with Scale
Health & Beauty Logo
23 people viewed this question
Top Healthometer Health & Beauty Experts
StormERage
Level 1 Expert
Tom Chichester
Terry
Terry
Are you a Healthometer Health and Beauty Expert? Answer questions, earn points and help others
