Question about Maytag Washing Machines
Maytag 2000 series washer model# MHWE201YW00 is getting F6--E1 error codes at same time what does it mean and how do i fix the problem?
It stopped working in the middle of the cycles
aborcass
  • 2651 Answers
SOURCE: F6 Code
f6 communication error in ht emotor controll board, located in the lower left front of machine
Posted on Nov 07, 2008
SOURCE: What does error code Lr mean and how do I fix it?
http://www.bobvila.com/wwwboard/messages/155863.html
says:
just an FYI to anyone who might need to know. my neptune started kicking up an error of LR and stopping. i ended up sending an email to maytag and got a response back from one of their techs. the LR code means "Locked Rotor". when this happens the cause is one of two items. 1) the circuit board at the top of the unit has lost connection to the motor and its control board at the bottom (connector loose) or 2) the motor and or control board at the bottom have trashed and need to be replaced (P/N 12002039).
hope the info helps someone as i had a heck of a time finding it.
Posted on Jan 14, 2009
SOURCE: I have a Frigidaire Gallery front load washer with E10 error code
When ours does that it is because of the hard water build up. We have to un-hook the hot water clean out the minerals and it stops doing it.
Posted on Dec 03, 2009
blueextc3221
  • 15935 Answers
SOURCE: Sears Kenmore HE3 Error Code F35
F35 is a water level error.
The water level switch (pressure switch) has malfunctioned.
If you remove the top panel, three screws in the back, you will have access to the pressure switch.
With the tub empty, remove the vinyl hose from the switch and blow backwards through the hose to clear any restrictions.
If the fault codes return after doing this, you will likely need to replace the pressure switch.
Also - please be sure to use He soap.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 25, 2010
livewire874
  • 618 Answers
SOURCE: maytag 3000 series washer f70 error code only the
If you unplug the M13 connection from the ccu (main control) and the error goes away then replace the MCU (motor control unit) if it does not go away then replace the CCU
Posted on Nov 20, 2010
I have a maytag 5000 series washer. We are getting an f21 error code. I unscrewed the white drain filter and cleared it. There was little in it. I keep getting the f21 error though. Can you help?
Search Results
    whirpool f21 error code - YouTube
    ? 3:04
    https://www.youtube.com/watch?v=b24PVv-ORqg
    Jul 1, 2012 - Uploaded by davidmontabon
    whirpool f21 error code. ... Maytag , Whirlpool Washer Repair - Drain pump error, no drain - F9E1- MHWE201YW00 - Duration: 4:29.
    My maytag 5000 series steam washer stopped and said Sud ...
    www.fixya.com/support/t8682656-maytag_5000_series_steam
    Mar 17, 2011 - my maytag 5000 series steam washer stopped and said Sud and now says ... Clicking this will make more experts see the question and we will .... I bought aMaytag 3000 seris in 2008 and I am getting these messages: F21 ... Maytag 5000 Series washer F21 error code was flashing and door will not open.
    Whirlpool/Kenmore/Maytag & more-F02/F21 & Sd error codes
    fixedappliance.blogspot.com/.../whirlpoolkenmoremaytag-more-f02f21-...
Feb 09, 2016 | Maytag Washing Machines
Washer error F06 E01
The error codes F6 E1 for Maytag Maxima 6000 front load washer means that the MCU AND CCU are not communicating. You need to check the wiring and plugs to make sure they have a good connection.
Feb 10, 2015 | Maytag Washing Machines
Washing machine E1
You have not included the make and model of your washer so that makes it pretty hard to answer for sure. A google search shows that several makes have an error code of E1 and it refers to a slow drain. Attached youtube video link is for a whirlpool washing machine and might help. If not repost with the make and model of your washer.
Washer Repair Drain Pump Error F9E1 Maytag 2000 Series Whirlpool Duet...
Aug 16, 2014 | Washing Machines
Maytag 2000 series error codes
I have a Maytag Maxima frontload washer that was getting these two error codes. I found in my case it was due to the tub not draining water as quickly expected. On my model there were two screws at the bottom of the front panel (one on each side towards the floor) Once these screws were removed and my husband tilted the washer up I was able to get my hand behind the panel and unscrew the filter cap that is located towards the middle at the bottom. It is a large plastic circle that you unscrew. With your hand remove any gunk or objects blocking the filter (usually filled with gunk) screw the filter cap back in, screw the front panel screws in and try to run another load. I have had to do this twice so far. You would think if the filter needs to be cleaned out every year or so they would make it more easily accessible.
Feb 23, 2014 | Frigidaire ATF6000ES Front Load Washer
Maytag front load washer mod mhwe251yg00 cde e1-f6
Serial communication error you have two computers one up top the CCU and one down below the MCU it's saying the two are not talking to each other the tech sheet has you go thru about 20 steps to basically come to the same conclusion it's either one or the other which I could help more but I run into the same problem in the field. Most times it's a failed CCU
Jan 20, 2014 | Maytag Washing Machines
F3 E2 error code on my Maytag washing machine
I just had the same problem with my MayTag washing machine - F3 & E2 error codes.
I cleaned out the drain trap then proceeded to remove the top and rear panels to check the Temperature Sensor. The sensor was tested with an Ohms meter and found to be working properly.
I went over the wiring from the Temp Sensor and found that both black wires had been 'cut' under one of the zip ties near the bottom of the washer.
I had to reconnect them with marretts and presto; the washer works perfectly again. If you encounter this same problem - be diligent in going over the wiring. I missed it the first time around.
It's an easy fix for anyone who can strip a wire of the plastic coating.
Good luck :)
Feb 23, 2013 | Maytag MAH6500 Neptune Front Loading...
Maytag 2000 series shows error code f6 e1. How can I fix?
Before spending much time and possible unnecessary work, the E1-F6 code may be nothing more than your bottom cover plate is not in place or missing. Recently was servicing a Maytag 2000 series wash and during the inspecting of the cycles it quit and flashed those codes. I had been testing it WITHOUT the bottom cover plate on. When I went to install it back on the code disappeared. Problem simply solved.
Mar 28, 2012 | Maytag MHWE200XW Washer
Washing Machines Logo
130 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
