Question about Samsung WF448AAW 4.5 Cu. Ft. Front Load Washer in Neat White WF448AAW
No power. Stopped running during cycle. Door locked and no lights on the front panel
2 Suggested Answers
caroldon
  • 17130 Answers
SOURCE: I have a front louder
The machine has to reset to bringg tthe lock to release, check the link to the lock settings to make the program complete the cycle and release the lock. Do not force it as you end up damaging.
Posted on Sep 01, 2010
Motor won't turn on Samsung VRT Plus WF433B*GJ**
When washing heavily soiled loads, do not overload your washer in order to assure good cleaning results.
To add a forgotten item:
1. Press the Power button.
2. Press the Start/Pause
3. Wait for the door lock light to go out (Immediately).
4. Add the item, close the door, and press the Start/Pause
The door safety state continues for 15 seconds and the cycle is restarted.
ensure thorough cleaning,
To
Try washing bedding, towels, undergarments,
contact using the ActivFresh
GETTING STARTED
1. Load your washer.
2. Close the door.
Z_
Push the laundry into the drum completely to prevent the laundry from being caught in the door or
....... from falling out of the drum.
3. Press the Power button.
4. Add detergent and additives to the dispenser (page 20-21).
5. Select the appropriate cycle and options for the load (page 14-16).
6. Press the Start/Pause
7. The Wash Indicator light will illuminate.
8. The estimated cycle time will appear in the display.
The time may fluctuate to better indicate the time remaining in the cycle.
The actual time required for a cycle may differ from the estimated time in the display depending on the
water pressure, water temperature, detergent, and laundry.
9. Before your washer starts to fill, it will make a series of clicking noises to check the door lock and do a
quick drain.
When the cycle is complete, the door lock light will go out and "End" will appear in the display.
DO NOT attempt to open the door until the door lock light is off. To add a forgotten item, see
"Loading your washer" section (page 13).
When your washer is restarted after a pause, expect a delay of up to 15 seconds before the cycle
continues.
Pressing Power button cancels the cycle and stops your washer.
The pre wash, wash, rinse and spin indicator lights will illuminate during those portions of the cycle
Nov 28, 2013 | Samsung 4.3 cu. ft. VRT Plus , Steam and...
Frigidare gltf1670as
You likely have a broken or slipped drive belt or broken spring on the belt take up arm on the drum. Appliance Parts.com has a lot of DIY instructions on how to get at the belt and make repairs.
Jan 23, 2018 | Washing Machines
During the cycle, it has stopped and the screen is flashing F- 21, what does that mean? The door is locked and when I do get the door open, water spills out. What do I do?
The drain cycle only runs for 8 minutes. F-21 is a blocked drain tube. Open the panel in the front bottom and locate the drain tube (front right) Disconnect it and you will find a little collection area in the tube as it first comes out of the washers tub. Clean it out and try resetting it to drain then all should be fine. I always find coins and other stuff like tissues blocking the flow.
Jan 20, 2011 | Kenmore HE2 Plus Front Load Washer
Washer stopped in rinse cycle.
Sounds like a control or door lock problem. Try resetting you ccu ( computer control) by unplugging the unit for 30 minutes first. If this does not work then you probably have a bad door latch or bad ccu. You should have a technician do this repair. The wrong soap will not cause this problem, although it can eventually cause other problems. Good Luck, Appliance Specialists
Dec 14, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Our front loading neptund door will not lock . any help would be appreciated
you will need to remove the door, the front panel, and raise the top to gain access to the locking mechanism. you will need to check for power to the wax motor that latches the door, if power exists during the spin cycle and its not moving and latching then you need to replace the : 12002535 - WAX MOTOR.. if no power exists to the wax motor and/or the microswitches there during a spin cycle then the main control board is toast and part number depends upon what series unit u have..
best of luck,
ttfn
Oct 25, 2009 | Maytag Neptune MAH5500B Front Load Washer
Stopped during rinse/spin cycle
try removing the bottom front panel and see if there is something blocking the drain.
Oct 31, 2008 | Whirlpool Duet GHW9150P Front Load Washer
GE Energy Star WBVH5200 Front Load Washer
My GE Energy Star Front Load Washer is reading 5.9 instead of 59 minutes and not washing clothes. We cleaned the filter and still no luck. Please help.
Jul 30, 2008 | GE Energy Star WCVH6260F Front Load Washer
Door Lock
door lock blown this sometimes blows tracks off the main pcb behind the control panel. appliance doctor
Jan 29, 2007 | Hotpoint WMA44 Front Load Washer
Samsung WF448AAW 4.5 Cu. Ft. Front Load Washer in Neat White WF448AAW Logo
13 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
