Question about Viking Kitchen Ranges
Viking viv600 motor
Blower not working
I have found an old boat engine with no make and no cover for it made in Canada patented in Canada in 1956, 57, 58, 60 serial number is C384919 and model number 25DE21V or could be 2IV who made it
Eaton's Viking
[PDF]Eaton's V Eaton's Viking Outboards Model Y iking Outboards Model Y ... www.romeosmarine.com/images/Outboards/VikingModel-YearGuide-2007edition.pdf
  1. Cached
  2. Similar
Eaton's Viking Outboards Model Y iking Outboards Model Y iking Outboards Model Year Guide ear Guide ... 25DE21V 25.0 Electric Starting. 40D15V 40.0 ...
[PDF]Eaton's Viking Outboards Model Year Guide ... - Richard L. Paquette
https://richardlpaquette.ca/VikingModel-YearGuide.pdf
  1. Cached
Eaton's Viking Outboards Model Year Guide. 1933-1969. Richard L. Paquette, Third Edition, August 2009. Year: 1933-35. 1936-38. 1939. 1939-41. 1940-41.
Original 1963 Eatons Viking 25 HP Outboard Motor Parts Catalog ...
blackcatantiques.net > Manuals > Boat Motor Original. 1963. Eaton's Viking. 25 HP. Outboard Motor. Parts List. Model 25D21V. &. 25DE21V. NOS. (Sellers Inventory no. B111003). Up for sale, we are ...
Original 1963 Eatons Viking 3 HP Outboard Motor Parts Catalog ...
blackcatantiques.net > Manuals > Boat Motor Original. 1963. Eaton's Viking 3 HP. Outboard Motor. Parts List. Model 3D19V. NOS. (Sellers Inventory no. B111000). Up for sale, we are offering an original ...
Original 1963 Eaton's Viking 5 HP Outboard Motor Parts Catalog Model
  1. Cached
Original. 1963. Eaton's Viking. 5 HP. Outboard Motor Parts List. Model 5D22V. NOS. (Sellers Inventory no. B111001). Up for sale, we are offering an original ... Eaton Viking 25DE21V Google Search
Sep 21, 2017 | Boating
I have a Viking VSM700 mixer that worked one day and was put under the counter. Next time it was brought out, it did nothing. No smoke, no noice, nothing. Any ideas?
On mine, one of the two brushes was NOT advancing to hit the motor armature as it wore. Had no power. Had to take unit apart to get to motor. We spread the metal brush holder slightly with a screwdriver and allowed the brush to slide so it can make contact with the armature. Motor now works fine. Shame on the Viking Company for dropping the ball on this product!!!
Jan 17, 2014 | Viking VSM700 Stand Mixer
Hi I have a Viking Husqvarna 6360, and although
Dead right, the part you can see is a suppressor which on most machines you don't need these days, snip it off, id the machine does not work when you have taken it off you can get the part from most sewing machine shops
Oct 21, 2013 | Husqvarna Viking 1
We have a viking cook top and the vent goes up and down but the fan does not always turn on ? Can you help
Some units have a dead man switch, which means that if the filters are not in place correctly the blowers will not operate. Its a safety thing to prevent little ones from dropping toys into a running blower. Double check the filters placement, if the filters are in the proper location than I would look at the power to the blower unit. The vent has two jobs, (1) to raise and lower, (2) to turn on the blower unit once in the full up position. If this is not the case, the upper switch in the vent system has failed. If you already confused, you will need to call a Viking expert to correct this problem. Its not difficult but can be time consuming.
I hope this helps
I have seen this problem twice and found the filters were the problem, rarely replace blower motors..
Jul 26, 2011 | Viking Cooktops
I have a viking Professional range hood. While
FLASH covers a multitude of possibilities. What is the voltage of the blower motor. What you are describing often happens when 220 is wired to a 110 lighting circuit. I would not be running the blower motor although I hope it has inherent built in motor protection. If the voltage is applied higher to light bulbs they become flash bulbs. Florescents can become fire fixtures fast. If you are not an electrician back away from this and disconnect power at your breakers. Do not open up and trouble shoot if you are not qualified so you do not get embarrassed and have a dirt nap. It only takes about 40 vo;ts and a few milliamps cross chess to kill you. Also when ever you turn something on start and keep the habit of using one hand to turn it on and one hand to grab your pants behind you. OK OK or skirt. This prevents a cross chest shock . Old Navy (USN) death defeating rule that sved me many times and still. Remember call a pro when you do not know .
Dec 03, 2009 | Viking Kitchen Ranges
Viking downdraft ventilator electrical problem.
You seem to have a slightly different model, but see a solution at:
http://www.fixya.com/support/t410261-viking_downdraft_ventilator_electrical
it is probably the same thing
May 28, 2009 | Viking VIPR101 Kitchen Hood
Fan switch not work - Viking 3048SS brand new range hood
There is the on off switch and the blower control that controls the speed of the fan. It is more than likley the blower control that would need replaced.
There could also be a wire disconnected in the hood.
Aug 19, 2008 | Viking VWH3048 Kitchen Hood
VWH 3648 Hood
most of them you have to take the filter off. under the filter, there are some screws. take them out and then it should drop the motor and you will see the electrical.
good luck
Jun 21, 2008 | Viking VWH3048 Kitchen Hood
Vicking VIDV500 Kitchen Hood
steve...first, is the light working? If not, you may not have power. If so, turn off all power to the unit at the breaker. Remove the filter and see if the blower turns easily by hand. Yes...switch could be bad...no...motor bad.
Open up unit and using test light from the hardware store and motor plug disconnected...turn on fan and probe the motor feed wire for power. It may be the switch that's bad. This should tell you.
Dec 01, 2007 | Viking VEDV900 Kitchen Hood
Kitchen Ranges Logo
70 people viewed this question
Top Viking Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Craig Butler
Craig Butler
Are you a Viking Kitchen Range Expert? Answer questions, earn points and help others
