Question about Smeg Microwave Ovens
My smeg FME24X microwave plate is not turning
The microwave is heating up but the plate is not turning. I have tried the button to reset the 'cancel turning' but its still not turning.
SOURCE: Need to remove this fitted SMEG FME24X Microwave
Thanks for the quick reply. As you said this has been mounted into a recess and surrounded like a picture frame.
I found some screws are very deep inside the recess and it has been obstructed by the grille/frame.
If you have any pics or any illustration, can you please forward it to me.
Thanks
Posted on Oct 24, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: microwave won't heat
Sorry my Clarification Request came out as a single blob of a paragraph.
That's not how I typed it. I never write that way!
So I've pasted it here, but as a solution.
Magnetrons generally should last about 2000 hours, but several factors can shorten that.
If it's not OVER ten years old (from the purchase date or the date on the tag inside the unit) then the magnetron is still under warranty.
From the owner's manual:
"For the second through the tenth year from the date of original purchase
"The magnetron tube, if the magnetron tube fails due to a defect in materials or workmanship. During this nine-year limited warranty, you will be responsible for any labor or in-home service costs.
"For the above limited warranty: To avoid any trip charges, you must take the microwave oven to a
General Electric Customer Care® servicer and pick it up following service. In-home service is also
available, but you must pay for the service technician’s travel costs to your home."
GE Customer Service is here, and you can verify the warranty status and find your nearest authorized servicer.
If you're sure the magnetron's bad, it's still under warranty, and you or a friend are handy, they will send you the magnetron to do it yourself. Call them at 888-239-6832.
Be persistent. You may have to speak with a supervisor.
It does sound like the magnetron overheated and the magnetron's thermostat opened until it cooled down.
An overheating magnetron can be due to:
  • operating oven without cover(s) in place
  • wrong magnetron installed in oven
  • an old or otherwise failing magnetron
  • cracked magnetron magnet
  • improper power line voltage (should be 110-125VAC)
  • foods low in moisture (popcorn & bacon, e.g. - add 1/2 cup of water in rear oven)
  • failed or inoperable cooling fan or hood vent exhaust fan
  • deteriorating foam weatherstripping seals in air ducts or on outside cover
  • blocked air vents (dust, animal nest debris, insufficient free air space behind & around oven, etc.)
  • clogged or greasy charcoal filter or grease filter
  • blocked duct in hood vent exhaust
Since yours is a counter top model, there are less of those factors to worry about.
When you hit Start to microwave, do the inside light, cooling fan, and turntable all come on?
Any unusual noises? Is it louder or quieter than usual?
We have a sound clip of what a microwave should sound like when the cooling fan and high voltage section are operating here.
You can find helpful exploded view diagrams and order parts if needed by entering your full model number from the tag on the oven here.
Let us know what you find out or decide.
Posted on Jul 07, 2009
heatman101
  • 43501 Answers
SOURCE: I have a Smeg FME24X 900 Watts Microwave Oven, and
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Posted on Sep 10, 2010
heatman101
  • 43501 Answers
SOURCE: microwave doesn't heat, plate doesn't turn
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
heatman101
jkfjfk
Posted on Sep 30, 2010
SD Tech
  • 14553 Answers
SOURCE: Siemens HF26066GB plate is moving when door closed and not moving when open
Have a shop look at this---there usually is a recessed safety switch inside the jam that will prevent the unit from working with door open--sounds like the problem may be with it.
Posted on Nov 04, 2012
My smeg microwave will not heat the food ...... possible causes
If everything else is working but it won't heat the food, the causes are the magnetron "common failure" or the high voltage capacitor and diode can be a factor, the three work together to heat the food. Depending on the nature of repair it can be close to the cost of a new microwave oven.
Feb 27, 2011 | Smeg FME24X Microwave Oven
Need intruction to operate microwave
I am writing to ask how to set the clock on the FME24X 900 Microwave Oven
Just need to know how to set it and where can I get an operating manual from
Area we live in is Windsor
Nov 14, 2010 | Smeg FME24X Microwave Oven
Door latch does not catch ,yet light goes on and turn table turns but does not heat. what part is needed and special tools?
Possibly door catch and/or door interlock switch may be damaged.
No special tools are required, maybe a torq 20 screwdriver.
Nov 04, 2010 | Smeg FME24X Microwave Oven
Fme24x not heating and burning smell with loud noise
Those are classic symptoms of a bad magnetron tube, the microwave source. It is possible to replace the part, but usually not worth it. The magnetron is expensive and you should let a professional do the repair. There are lethal voltages under the cover and the chance of microwave leakage if the repairs aren't done correctly. Between the part cost and labor charge, it's usually not much more expensive (sometimes even less!) to buy a new oven.
Oct 31, 2010 | Smeg FME24X Microwave Oven
I have a Smeg FME24X 900 Watts Microwave Oven, and has stopped working, no power but occasionaly the display lights for a fraction of a second, any ideas? Have tried replacing fuse in plug but still only...
heatman101
Sep 08, 2010 | Smeg FME24X Microwave Oven
Turntable does not spin
There is a coupler that connects the turntable motor to the plate. It's the square or odd shaped object in the center of the microwave after the turntable is removed. You can try to pull it up from the microwave to see if it is broken or if it will turn by hand, it is probably broken.
Jun 21, 2010 | Smeg FME24X Microwave Oven
Thanks
Oct 24, 2008 | Smeg FME24X Microwave Oven
Microwave Ovens Logo
Top Smeg Microwave Ovens Experts
William Miller
William Miller
jason
Are you a Smeg Microwave Oven Expert? Answer questions, earn points and help others
