Question about Samsung RB195ACWP Bottom Freezer Refrigerator
My ice off button stays on wont go off samsung rb195acwp it wont drop ice water is going in the only way to drop ice is the reset button
It is filling up and freezing but wont drop unless I hit yhe reset button
3 Suggested Answers
  • 3 Answers
SOURCE: ice maker has ice motor doen't dump the ice
Your ice-maker may need to be "hard-reset". To do this, perform a manual-defrost by emptying out the freezer (and fridge) and shutting all power off to your unit for several hours (at least half a day unless you can be sure the temp in the freezer has fully reached ambient. Next, with freezer empty, restore power, make sure the "ice" setting is set to off, then set the forced power-freeze mode (you can refill the fridge, but leave the freezer empty for now. When the power-freeze completes (at least 2.5 hours) you can refill the freezer, set the "ice" mode to block/crushed (IE something other than off) and then hit the "black reset button" to restart the ice-maker. IF it still will not dump the cubes then the ice sensor/control board may have failed.
Posted on Sep 24, 2010
  • 1196 Answers
SOURCE: Ice machine not dropping.
In case the ice is not getting ejected and seems to be stuck in the ice maker, the defect lies in the ejector mechanism. Since the ice maker cannot eject the ice, you need to put it to the manual shut off mode, so that ice maker doesn't continue to make more ice. In such a scenario, you will need to shut off the power to the freezer for carrying out the repair, so if you are not comfortable with handling electrical appliances, you could seek professional help.
Posted on Jun 25, 2011
Icemaker is not working properly. It will only make ice after the reset button is pushed.
If the ice room is not getting/staying cold enough, the unit will not harvest the ice and proceed through the cycle... First step in troubleshooting is to determine if the compartment the icemaker sits in is cold enough, if it is, then you have to test the ice room temp. sensor to see if it is not sending the correct temp signal to the main board. These icemakers are modular and pretty much have to be replaced completely if the temperatures and sensor check OK. Samsung Refrigerator Temperature Sensor DA32 10104N
Jun 21, 2016 | Samsung RF263BEAESR Stainless Steel 26 cu....
How do I remove the back wall of freezer on samsung rb195acwp
Annonymous, what problem are you trying to solve? Is the water at the bottom of the refrigerator because the fridge is not cooling? If that then unplug the fridge, Keep the fridge and the freezer doors open after salvaging food items. Keep it unplugged for about 12 hrs and any ice buildup in the back wall will melt. You will see a pool of water on the floor. Clean that and the inside of fridge and freezer. Re-connect. You might get lucky!
Jul 29, 2014 | Samsung RB195ACWP Bottom Freezer...
Ice build up under the produce drawers of a Samsung refrigerator model RB195ACWP.
You need to contact Samsung about that. there is a fix kit out for that issue. I've put several of them in myself but cant find online how to order it. basically the water is leaking from the evap in the fridge to your fridge bottom and then it freezes because it sits there in the cold for so long. Hope this helped!
Aug 09, 2013 | Samsung Refrigerators
How to install water line to a samung refrigerator
One line hooks to the water supply, the other line hooks to the ice maker. How old is refig?
May 08, 2012 | Samsung RB195ACWP Bottom Freezer...
I changed my water filter which is flowing correctly and it wont dispense yet discolured water is going into the ice bucket discoluring the ...
IT TAKES SOME TIME TO FILL WITH WATER,YOU MAY NEED TO HOLD THE FILL BUTTON FOR A MINUTE OR TWO IT, BE PATIENT .. JAY THE POOL PUMP REPAIR GUY IN LONGWOOD FLORIDA.. HIT THE YES BUTTON IF I WAS OF HELP .. THNX JAY
Jun 15, 2011 | Samsung RS2534 Side by Side Refrigerator
Ice maker not working.........
Reset button on the bottem front right of ice maker
Jul 22, 2008 | Samsung RB215LASH
Samsung Ice Maker on Mdl RB215LASH
It is quite possible the water line near the ice-maker is frozen. I would try a warm hair drier to thaw it out.
Apr 21, 2008 | Samsung RB215LASH
Samsung Icemaker Problem
I also had the ice tray stuck in the dump position. I unplugged it waited 5 minutes and pluged it back in. And the Ice tray moved back into the correct fill position, and the arm did drop down, But now it has not filled with any water. So now what should I try?
Feb 20, 2007 | Samsung RS2534 Side by Side Refrigerator
RS2556SH Side by Side - Icemaker not filling; fill tube not iced over!?
press the reset button (black) on the bottom of the icemaker, the system will go through a cycle, and water will pour into the tray.
Oct 23, 2006 | Samsung RS2630SH Side by Side Refrigerator
Samsung RB195ACWP Bottom Freezer Refrigerator Logo
32 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Paul
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
