Question about GE Microwave Ovens
I have a 2010 GE Spacesaver Microwave.how do I replace light bulb inside the microwave?
How do I get to the light bulb for inside the microwave.when I open the door the light does not come on.
MicrowaveSvc
  • 9047 Answers
SOURCE: Replacement light bulb for GE spacemaker microwave
That model number doesn't look quite right, but nevertheless:
If there's no obvious removable cover over the bulb (and the owner's manual doesn't address it) some disassembly may be required.
Always unplug a microwave before removing or installing any bulbs.
If it's an over the range type, remove the vent grille across the top and see if bulbs can be accessed there. There may be a panel on the bottom covering the light(s), instead.
If not, chances are you'll have to remove it from the wall, then remove the outer cover. If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
Once it's out of the wall, the outer cover (wrapper) will need to be removed, just as you'll need to do on a counter top model.
On a counter top model, be sure it's unplugged, but otherwise ignore the instructions above this paragraph.
The screws you need to remove should be pretty obvious, but a special driver (such as a T20H Torx type or GTXH20-100) may be needed.
Be sure to put all the screws back in the right holes, since some may be special grounding screws.
Bulbs can be had in most grocery stores, hardware stores, home improvement centers, and big box or department stores.
Many models use halogen lamps. You must not touch the new one with your bare skin, as the oils will shorten the bulb life.
Posted on Sep 16, 2008
  • 2692 Answers
SOURCE: Replacing GE Spacemaker Light Bulb inside Microwave Oven...
Here is the GE download page for your manual. Page 35 of your  manual gives the light bulb replacment instructions.
http://genet.geappliances.com/DocSearch/Dispatcher
Posted on Dec 31, 2008
SOURCE: Microwave interior light
Very easy to replace...at least on my JVM1790. Remove the top vent....the long plastic thing that runs along the top of the MW. Two screws on top of the micro. Behind the charcola filter (if you installed one) is an access area to the bulb. remove one screw and the entire assy comes out. Simply R & R the bulb.
Posted on Apr 02, 2009
SOURCE: Is there a replaceable light inside microwave oven
Found info on another website.
Posted on Jun 05, 2009
jsrock516
  • 5911 Answers
SOURCE: The door handle broke off my GE microwave
Actually the door handle CAN be replaced at a cost much less than pruchasing an entire new microwave oven. And, YOU can repair this yourself and save the cost of a service call. On MOST microwave ovens, you just have to remove the inner door panel that goes around the perimeter of the glass. The following link explains how to replace the door handle:
http://www.fixya.com/support/r3696942-microwave_oven_door_handle_replacement
If the model number is correct, the part number is WB15X322. The cost is about $40. Replacements may be purchased at the websites listed in the link I provided.
If you have any questions, or if your model number is different than the one listed, please post back and let me know. I hope this helps you
Posted on Dec 31, 2009
Product is GE Microwave (Spacesaver-type) JNM1731DM1BB. New surface light bulbs installed. Unable to turn them off or change from bright to dim
Bottom lights are controlled through relays on the main control board which is mounted on the back of the touch pads (control panel).You can check and see if wires are touching each other on the board but my guess is the board is defective and needs replaced.
Apr 02, 2015 | GE Microwave Ovens
How to change the inside bulb in a ge spacemaker microwave that has a top vent fan
My Spacesaver bulb replaces from the top. You have to remove 2 screws that hold the upper vent cover. W/ cover off you will find a phillips head screw about the center that holds the bulb cover. Remove the cover screw & lift up & remove the cover, then replace the bulb, the cover & screw then put the vent cover & it's 2 screws back. There may be some variance but they are all similar.
Mar 16, 2013 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacesaver Microwave not heating, inside fan not working
I suggest you have the microwave oven replaced, the prices have dropped considerably for the last several years and you have got your money worth out of the unit.
Mar 02, 2012 | GE JVM1640 Microwave Oven
"door error", "start?" - When
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic Microwave Oven Troubleshooting Tips
heatman101
Nov 29, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
CAN'T GET BULB ACCESS DOOR OFF TO REPLACE UNDERNEATH BULBS
Hello there:
first you need to remove the screws from the back of the microwave that hold on the casing and there might be some on the bottom too. then remove the outer casing
the bulb is under the casing towards the front right corner as you are looking at the front of the microwave
Sep 09, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Heat doesn't come on in microwave
If you have the experience with discharging a capacitor and you have a (VOM) Volt Olm Meter. Unplug microwave, discharge capacitor, and check the resistance of the two thermal cut-off discs by removing the lead and set VOM to RX1. If you don't get a reading of zero, replace the discs. For part go to www.partselect.com and enter your model number. If you found any of these suggestions helpful, please rate my solution. D. Lange
May 01, 2009 | Microwave Ovens
I need to find an incancent 40w 120v bulb for microwave
This is a common item. Take the bulb to a home depot and they will match it for you or direct you to a local source.
please mark my answer as a fixya!
Mar 10, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Dec 30, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave Ovens Logo
13 people viewed this question
Top GE Microwave Ovens Experts
D. E. Hev
 Larry
Larry
Shekar Avadhani
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
