Question about Nakamichi Televison & Video
No disc dvd player sees no disc when there is one
2 Suggested Answers
rroath49
  • 35 Answers
SOURCE: The DVD player doesn't play DVD disc only CD discs
first thing to do is try a lens cleaner disk. If that does not help you can try to remove cover and maualy clean the laser pick up with a q-tip and isopal alcahol. If that is not something you want to try have it done by a friend that has experiance or a shop. If that does not fix it you will need a new laser assy.
Posted on Jul 30, 2008
Panasonic dvd player in car
see the cause and remedies:
  1. No disc. - Load a disc into the tray.
  2. Disc has been loaded upside down. Place the disc with the label side up.
  3. Disc region code does not match region code of the player.
  4. Disc type is not the correct type to play.
  5. Disc is damaged or dirty. Clean the disc or try another.
  6. Moisture may be condensed inside the unit. Remove the disc and the leave the power on for one or two hours.
  7. rollers in PLAYER car, is worn or defective.
  8. use clean disk cleaner for to clean the OPU optical pick up or lens. see the block similar to dvd player conventional
Jul 20, 2012 | Panasonic Televison & Video
My dvd player plays dvd discs ok. but when i use dvd burned on my computer shows no disc.the same disc plays fine on my computer
Some DVD and Blu-Ray players will not play a burned disc until it has been finalized. Finalize the disc on your computer then see if it will play. (Finaalizing a disc means it can no longer be recorded to, by the way.)
Aug 27, 2011 | Samsung BD-P1500 Blu-Ray Player
I put a disc into the machine and it keeps saying no disc
Check the disc,see if it dirty or cracks?Tries it,with other DVD disc,same result.Ur DVD player have a bad Laser eye data's readers.Not,worth fixing as u know totay DVD players are really cheap,these days.U can get a brand new DVD player for like $40.
Nov 03, 2010 | KLH DVD8350 DVD Player
I recorded onto DVD-R discs and then finalized but they wont play on my dvd? how can i get them to play ? i usually buy DVD RW
Some dvd players cannot play certain types of discs. You could check to see if the manufacturer of the dvd player has a firmware update to fix this problem. Older dvd players have trouble playing some of these discs. Most newer dvd players do not have issues and have upgradable firmware to adjust for different formats. Does your burner also do DVD+R discs? Maybe try using those and see if it plays on your dvd player.
Sep 05, 2009 | Sony Handycam DCR-HC42 Mini DV Digital...
Samsung dvd vr357 Can not watch copied dvd on other dvd players
I know with the Go-Video, the DVD disc has to be 'finalized' before it's compatible with other DVD players/computers.
Check your 'set-up' menus while that disc is inserted into your Samsung DVD machine and see about pushing the 'up' arrow, if you have one, to see the contents of the DVD disc...then see if you can toggle to the right to see options for that disc, for instance, the title of it. You might see the 'finalize' option there.
Feb 27, 2009 | GoVideo VR3845 DVD Recorder/VCR
PORTABLE DVD PLAYER NOT SPINNING DISCS AND SAYING NO DISC
When it is region lock it will say it on the display, if the player is not reading any disk, it is more likely a lens problem, see below:
Try first using a lens cleaner disk, like the ones here.
If that does not work, the unit must be disassembled, and lense cleaned with q tips and isopropyl alcohol or cleaning solution. See below:
How to Clean the Laser Pickup Lens on your DVD Player
How to safely clean a DVD lens?
Clean DVD lens, or replace player?
Clean CD or DVD ROM lens with a brush?
Cleaning your DVD drive
How to clean a DVD player
How do I clean my DVD player optical lens isoproponol alcohol
Feb 10, 2009 | Televison & Video
Conia M580 DVD player has died, cannot open disc tray to retrieve DVD disc from player. Cannot unlatch the disc tray manually, as there's no pin-hole near the disc tray, unlike most (more expensive) DVD...
Easy... follow these instructions
  • unplug from the mains
  • take the cover off (3 screws on back panel, 1 screw each side, sticker on top front)
  • You will see the DVD disk in the player drive
  • Remove the plastic ******** top of the drive - 2 x small phillips screws
  • Lift out the DVD disk.... done.
Oct 31, 2008 | Conia DVD8500 DVD Player
DVD player not reading dvd's
Check the link below to see how to clean the laser on a DVD player. If cleaning does no work, then the player will need servicing.
http://www.ehow.com/how_2036275_clean-lens-dvd.html
Jerry G.
May 13, 2008 | GoVideo DV1030 DVD Player/VCR
Toshiba disc error
Check formatted disc see if it's +R,-R and see if Toshiba will play homemade disk or just disc recorded in different format.
Jun 25, 2007 | Philips DVP642 DVD Player
Bad disc or insert disc problem
If you are using a copied disc try a real one. But this model of DVD Player is made so cheap. it sound like the laser assembly is bad or the motor that spins the disc is stuck or going out. If you are good at electroninics you could take the lid off load a disc and see if it spins if not give it a spin clockwise and see if it takes off. You probably should replace unit for price of a new one.
Dec 31, 2006 | Cyberhome CH-DVD 300 DVD Player
Televison & Video Logo
13 people viewed this question
Top Nakamichi Televison & Video Experts
Josh Whitehead
Josh Whitehead
Henry  Thomas
Henry Thomas
Are you a Nakamichi Televison and Video Expert? Answer questions, earn points and help others
