Question about Home
Gainsborough diplomatic power shower ipx4
Making strange whirring noises
5 Suggested Answers
muralme
  • 20 Answers
SOURCE: Hi, Advice please, my shower when on hot comes
If you are taking about then neck of the shower head this is what you must do. its no need to turn the water off to the house or to the bathroom first you will need a pair of channel locks and some Teflon tape. first remove the shower head if you dont want to scar the nut on the shower head place cloth between the pliers and the fitting, once removed (very important) turn the channel locks upside down stick one side of the blue handle up in the neck of the shower and rotate to your left to loosen if you are having a leak leak there it should already be semi loose, once removed wrap the threads with the Teflon tape and re-insert making sure it is tight, then wrap the the outer end of the neck with Teflon tape and place the head back on.The reason it leaked is because the plumber who installed it did not tighten it up completly because he wanted it to look straight coming out of the wall and the additional water pressure causes it to leak wheras the hot water causes it to expand and seal
Posted on Jul 16, 2009
  • 3 Answers
SOURCE: i have a Gainsborough Royale Antique and i can not get cold water
how old is the shower?
Its a mixer, am I correct?
Posted on May 07, 2010
SOURCE: Water coming from around the bottom of
Piece of P: youre prob right and its the pressure relief device, which is a silicone rubber ball that gets blown out of a branch of the exit pipe just behind where the hose screws on. If you are careful you can push it back with a small (non sharp) screwdriver etc, looking up from underneath. It would be easier to see if you unscrew the hose first.
Posted on Oct 29, 2010
  • 118 Answers
SOURCE: My gainsborough shower gets tepid but not hot,
there is a scald proof device in the valve. remove the handle and adjust.
Posted on Dec 05, 2010
Battery light came on and 2006 dodge stratus makes a strange whirring noise. What is this? I just started last night
It sounds like the bearings in your alternator are going so it's charging your battery but no a 100%.
Jun 23, 2014 | 2006 Dodge Stratus
My 04 Honda TRX 350 makes a strange whirring noise after the engine is turned off
Check the pinion gear and the ring gear, most probably they are not messing right....or get it to a mechanic to check that out!
Jun 14, 2014 | Computers & Internet
Strange whirring noise just started behind clio dash engine runs but lumpy on acceleraction
Possible that you have a vacuum leak behind the dash. That would cause the noise and the run issue. No info in the USA on that car but lots of vehicles have vacuum controls for the heater and a/c. Need to disassemble enough to determine the source but very likely vacuum.
May 26, 2014 | 2002 Renault Clio
Strange Noise While engine is running
do you have ac in your car let me know
Jan 04, 2014 | 2008 Toyota Prius
Whirring noise when car moves
Could be a transmission issue. I would take it to a dealer for assessment.
May 16, 2017 | 2003 Acura 3.2TL
My Dyson is making a really strange loud sound. It appears to be working. I just took it apart and cleaned the filter and the wand. When I put everything back together, it started making a heavy whirring...
Check the tips of the beater bar. I "bumped" mine to hard and broke a tip. Still worked! Just noisy. Called Dyson support and they sent me a new one no charge. Note. Mine had a loud whirring and a vibration.
Jan 30, 2011 | Dyson DC17 Animal Bagless Upright Cyclonic...
I have a Frigidaire Upright Freezer making strange noise.
Check the condenser fan,m sounds like the bearings are failing.
Good Luck,
Gilsh
Nov 28, 2009 | Refrigerators
My LG washer/dryer started to make a strange noise this morning when I put a few towels in to tumble dry. I put it off immediately, and have just tried again (7.30pm). Still making strange noise, not...
Your michines are still under manofacture waranty call LG customer service at the address below.
LG Support Representative at (800) 243-0000
"Was this helpful?"
May 09, 2009 | Dryers
My pc is making clicking and whiring noises
It sounds like you have a hard disk drive that's going bad. Take it to a computer expert and have them check it. The "clicks and whirs" might also be a cooling fan going bad.
Mar 28, 2009 | Computers & Internet
Differential making annoying whirring sounds.
this noise is caused by the pinion bearing in most cases, of course without removing the bearing to look for pits in the race it is at best an educated guess.
Feb 15, 2009 | 1999 Dodge Durango
Home Logo
59 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
