Question about Trendnet 300Mbps Wireless N PoE Access Point TEW-653AP (White) Router
Trendnet tew-653ap forgotten password
5 Suggested Answers
puertobori
  • 7733 Answers
SOURCE: trendnet tew-652brp username: admin password: admin Computer
Just reset it! At the back of the router is a small hole.With a toothpick or some like press gently for 30 seconds and wait for the router to start up again.Log in to http://192.xxx.xxx and start a new configuration.
Ifyou need more help come back.
Post/ thumbs / testimonial are welcome!
Posted on Dec 27, 2010
puertobori
  • 7733 Answers
SOURCE: How to reset Trendnet TEW 652BRP Wireless N Home
In order to get your router back to the original settings, you must push in the reset button (usually on the back of the router) for somewhere between 10 and 30 seconds depending on the router. You may need a pin or something small to push in the button, because it can be recessed. Once you have reset the router, the username and password will be changed to the defaults, admin and password, respectively. One thing you must remember is that resetting the router will change all of the router settings back to the factory settings. This means you will lose all of the changes you made since you got the router. Make sure to write down any things you've changed, so you can change them back after the reset. Also, I recommend updating to the latest firmware after the reset.
There a great article at General Router Setup.
If you need more help post back!
Thumbs and testimonial are welcome!
Posted on Feb 12, 2011
  • 18 Answers
SOURCE: how can i connect a
depending on what you are doing with the two devices, there are a bunch of different answers. usually connecting two like devices requires a crossover cable. This is different from the traditional straight-through cables that you can buy at walmart. but for simplicity sake, use a crossover cable
Posted on May 09, 2011
maxcarson
  • 7627 Answers
SOURCE: pin for trendnet TEW-654TR
Try the user manual: http://www.trendnet.com/downloads/list_subcategory.asp?SUBTYPE_ID=1347
Posted on Dec 17, 2012
Why my router trendnet tew-731BR doesn't working?
You have to look on the tag at the base or back and find the IP address and admin / password sign in to set it up. Set of numbers like 192.168.0.1 or www.routerlogin.net then when on the routers server you can enter your ISP details to get the router setup.
Dec 05, 2014 | Trendnet TEW-731BR 300 Mbps Wireless-N...
Pin for trendnet tew 652brp wireless n home router
Is it a password? May be try the default password Or you can try 'reseting' the router. Beware, that resetting removes all settings and shift it to factory defaults
Apr 07, 2014 | Trendnet TEW 652BRP Wireless N Home Router...
I have forgorren my user and password of my trendnet tew-424ub router after a long time of not using them. Can anyone help me recall or maybe just reset them, so I can addess tyhe router page...
I have forgorren my user and password of my trendnet tew-424ub router after a long time of not using them. Can anyone help me recall or maybe just reset them, so I can addess tyhe router page again?
Nov 21, 2010 | Trendware TRENDnet TEW-424UB 54Mbps...
Can't assess password to set up a new computer
Here is the PDF file that shows how to reset the router if the password is forgotten.
http://downloads.trendnet.com/TEW-432BRP/FAQ/FAQ_TEW-432BRP.pdf
Oct 14, 2010 | Trendware TRENDnet TEW-432BRP 54Mbps...
Reset password
What password are you referring to; Wireless Security or Web password to access the Router's interface?
If it's the 2nd; Open http://192.168.0.1 (default IP) on your web browser, type username: admin and Password: password. Click on Password then change the default password.
If it's the 1st; Open http://192.168.0.1 (default IP) on your web browser, type username: admin and Password: password (put you correct password if you change the default password).. Click Wireless on the left, Enable Encryption WEP or WPA; for WEP 64 bit you will have to use 10 HEX, meaning 0-9, A-F (e.g. common is phone number). If WPA; password can be set from 8-64 characters long.
Angel .
Jun 30, 2010 | Trendware TRENDnet TEW-435BRM 802.11g...
I lost my trendnet router tew 231brp password
You can reset the router by pressing the reset button with a paperclip. The button should be by the antenna. You have to press it an hold it for about 15-20 seconds to reload the router to the factory defaults. Then you can login with the default password and set up the wireless again.
the factory default password for the router login should be admin both for username and for password.
Jun 19, 2010 | Trendware TRENDNET TEW-423PI Wireless...
How I can reset the password? I do not remember it
You must remove all power from router, and press the reset button, this will return the unit to factory spec's then you can login, as default, and re-setup the router.
downloads.trendnet.ru/TEW-231BRP/Manual/QIG_TEW-231BRP_EN.pdf
http://www.trendnet.com/downloads/list_subcategory.asp?SUBTYPE_ID=869&SUBMIT=Go
All in these manuals above..
Apr 09, 2010 | Trendware TEW-231BRP Wireless Router...
How to change password for Trendnet TEW 432BRD wireless router
First RESET your router to defaults.
for that press RESET button for 10 seconds RESET button is in back side of router.
Then connect your router to computer with ethernet cable.
Then you can access it with following link.
http://192.168.1.1
or
http://192.168.0.1
type user as "admin" and password as "admin" or blank or "password"
Then you can see configuration page of router.
Set WAN settings as your internet service provider settings.
Enable DHCP .
CLick on wireless and enable wi fi.
If you want secure router then enable WEP security then add new code it is your password key for connect wi fi.
Let me know if you need further assistance.
Thanks.
Nov 06, 2009 | Trendware TRENDnet TEW-435BRM 802.11g...
Trendnet 300Mbps Wireless N PoE Access Point TEW-653AP (White) Router Logo
15 people viewed this question
Top Trendnet Computers & Internet Experts
youbrokeit
Level 1 Expert
Are you a Trendnet Computer and Internet Expert? Answer questions, earn points and help others
