Question about Exercise & Fitness
Treadmill whining noise
My precor 936i has a loud when and the faster you go the louder it gets
  • 350 Answers
SOURCE: Whining Noise when idle and gets louder when accelerating on 2000 Nissan Altima GLE
hi more than likley to be the alternator remove your fan belt start engine see if noise disapears yates210456
Posted on Oct 08, 2008
SOURCE: 1998 Ford Mondeo GLX, loud humming sound, front driver side.
Most likely it's a wheel bearing going out.., If you turn to the right, or the left when driving the noise will change pitch. Been there done that.....
Posted on Feb 01, 2009
  • 14 Answers
SOURCE: ???maximum user weight for Precor 9.45i
Normally most home treadmills are 250-300lb user capacity.
Call Precor with your model # and S/N and they can tell you exactly.
Posted on Apr 29, 2009
  • 6 Answers
SOURCE: Precor M9.21 Treadmill - Stops under load
This probably did not happened suddenly right? the problem is not the motor however you can easily check the blue capacitor for peace of mind. with the power disconnected, disconnect one side off the capacitor from the top. with a ohm meter put the 2 probes on the cap,you will ear a temporary beep sound from your meter, then reverse your probes on the capacitor and again a temporary sound that mean your capacitor is good and your motor will run OK.
Your problem is more then likely your run belt and bed assembly. When new, these are coated with a wax of some kind for slipping, has you use the machine wax wears off, and so is the belt. You can see a black rubber dust at the rear of the machine. And so resistance increase when pressure is applied on the running belt.
Just behind the on/off switch where the power cord goes in, there is a auto reset 15 amp breaker that trips when too must resistance against the motor increase the amperage over 15amps. At 7 min/m on your speed setting and if the belt is adjusted correctly with nobody on, the motor pull about 6amps, with someone like me 180lbs, the motor pulls an avg of 10amps with a new belt.
If you have a clamp amp meter you can test it yourself.
2 parts you will need to fix this; 50985-101 (bed assembly) and 36355-101 (run belt 17 X 110) This is real easy to install.
make sure these parts are for your machine model # as they did increased the width of their belt over the years
Since 1998 I had to replace these parts 2 times with an average of 3 people using the treadmill every day. This is a good machine and if everything else is good it's worth it. I paid $300 for these parts, i'm sure if you shoppe a little you can do better.
Have a good one
Ben
Posted on May 26, 2009
  • 3 Answers
SOURCE: My 04 ford explorer is making a loud humming noise
wheel bearings are worn out on the front, i had the same problem in my 2004 ford explorer just recently.
Posted on May 30, 2009
Loud rear whine, not brakes new ones fitted
Was noise there prior to brake replacement? If so, possible wheel bearing noise. Noise should get louder the faster the wheel rotates with a bearing problem.
Feb 22, 2016 | 2007 Hyundai Santa Fe Limited
Where is speed sensor for a prector c 936i
Speed sensors are usually located on the motor flywh
Jun 18, 2014 | Precor C936i Treadmill Upper PCB Display...
Motor making loud buzzing noise
The grinding noise could be asking for lube. If that is possible, do it.
Dec 13, 2013 | Precor C956i Treadmills with HR /...
Whining noise progressively gets louder with speed
One wheel turning faster than the other is normal if both wheels are off the ground. If one wheel is dragging when the other wheel is on the ground, it could be brakes or a wheel hub bearing.
Usually if the noise happens on right turns, the left hub bearing is failing, and vice versa.
May 07, 2013 | 2000 Buick LeSabre
Whining noise from my treadmill
1) LUBE the DECK BELT inmediately, maybe you have a WORN deck replace if is necessary.
2) LUBE the rollers bearings
3) test the motor bearings and repair see the diagram
God bless you
Aug 02, 2012 | Precor C956i Treadmills with HR /...
We have an 05 Pacifica Touring. No engine problems yet.(read a previous post, all Pacificas eventually burn oil) However we have a whining sound coming from the rear. go slow(5mph), no sound, as you...
have you looked at the tires- if they are wore down the wear bars-little bands of rubber that cross the grooves in tread will be exposed and the noise is your warning to get new tires soon
Jul 30, 2011 | 2005 Chrysler Pacifica
My Epic 425 is getting louder and louder, a whirring noise, but can't seem to find maintenance help
It sounds like you have a drive motoer failing. The only other place that can be load or making noise is the front and rear roller. The rollers bearings when failing make a "popping" or "clicking" noise, and increases as you speen up. The motor "growls", and the faster you go the noise is..... well loud. The way to confirm this is to remove the motor hood, then start the treadmill on power/speed level 3. Be very carefull, and use a broom stick (wooden) to put on the drive motor while it is running. You should be able to "feel" what you are hearing. You should then raise the speed, and you will then feel the increase as well.
The replacement motor is around $200.00.
Hope this helps
If you need further help, I’m available over the phone at https://www.6ya.com/expert/matt_8dbc24bf722649ac
Nov 12, 2010 | Epic 425 Mx Treadmill EPTL88105 !
The incline cannot be re set to '0' level ?
Treadmill c956l has a whining noise coming from the front when at 3-5 speed
Sep 07, 2010 | Precor C956i Treadmills with HR /...
Exercise & Fitness Logo
61 people viewed this question
Top Exercise & Fitness Experts
Howard
Howard
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
