Question about Exercise & Fitness
Schwinn 215p recumbent bike cannot get the pulse feature to work
Cannot get the pulse feature to register or work
5 Suggested Answers
maxtreadmill
  • 832 Answers
SOURCE: Error 3 (E3) on Schwinn 240 recumbent bike. How
No speed/RPM reading, Console displays "E3" error code
Check data cable integrity All wires in cable should be intact. If any are cut or crimped, replace cable.
Check data cable connections/orientation, insure cable is connected securely and oriented properly. Small latch on connector should line up and snap into place.
Check magnet position (requires shroud removal) Magnet should be in place on flywheel. If no magnet is present, replace the flywheel or the entire base unit (if unable to replace flywheel).
Check RPM Sensor (requires shroud removal) RPM sensor should be aligned with magnet and connected to data cable. Realign sensor if necessary ( 1/8" clearance between sensor and flywheel) if still error 3 then check the sensor with a multi meter unplug sensor leads attach meter to sensor connectors. Have someone by hand rotate the pedal while you observe the multi meter opening and closing the internal sensor circuit if no change in meter readings then replace the sensor.
Posted on Jun 01, 2010
roadtech7
  • 297 Answers
SOURCE: my schwinn 240 recumbent bike shows E-3 on
Hello, do you have a manual or electric resistance control? The manual one has a return spring, the electric on has a resistance motor that could be bad.
Posted on Feb 06, 2011
ercupa190
  • 12223 Answers
SOURCE: I just got a schwinn srb-1800 recumbent exercise
Follow this step
o
Open the battery cover from the back of the control screen and take out the batteries.
o 2
Use the screwdriver to take out the screws on the left side of the large plastic enclosure that encased the batteries. You can now bend the enclosure so that you can reach behind it to make the repairs.
o 3
Use the crescent wrench to unfasten the nut that holds the left pedal onto the crank.
o 4
Unfasten the mechanism that keeps the pedal on the crank with the allen wrench.
o 5
Unfasten the screws that keep the plastic side panel on the wheel. Use the stubby Phillips screwdriver to get these four screws off. You will have to bend the outer plastic enclosure to reach the screws; make sure you don't break it. Remove the plastic wheel side panel.
o 6
Put the batteries back in.
o 7
Find the cord that moves the magnetic plate at the base of the wheel. Manually pull the magnetic plate back from the wheel frame. Now that the plate is unstuck, the error message should disappear.
o 8
Replace all parts in the reverse order you took them apart.
Posted on Nov 15, 2011
ercupa190
  • 12223 Answers
SOURCE: The tension does not increase on my schwinn 220
adjust the magnet very well, tigh the bolts if there loose the tension will be not o.k
Posted on May 03, 2012
Where to get user manual for schwinn 230
Do you mean the Schwinn 230 recumbent bike? Then Schwinn has the manual for two models (released in different years) on their product manuals page: http://www.schwinnfitness.com/schwinn_fitness_us/customerservice/manualsen.jsp . Expand the section on Recumbent Bikes and scroll through the list. The direct link to the owner's manual for the 2007 version is http://download.nautilus.com/supportdocs/OM/Schwinn/SCH_130-230_OM_RevB_web.pdf . The 2013 version is here: http://download.nautilus.com/supportdocs/AM_OM/Schwinn/SCH.230-Journey2.0.AM.OM.WARR.EN.pdf . The newer model has a USB port for a flash drive, among other differences.
I hope this helps.
Jan 20, 2016 | Nordic Track Nordictrack Apex 4100i...
Looking for manual or users guide for this electri bike model pristine Schwinn has no info they bought Dorel bike company in PQ and Schwinn has no inf
Check out our Schwinn manuals online.
From the Equipment Parts TAB select Schwinn, then Bikes and then Upright or Recumbent.
I would toggle to see if any bikes match your bike from there, you could also give us a call with your serial number or model number or just try to see if we could help.
Phone is 888-713-2880
Apr 21, 2015 | Schwinn Cycling
What's the best exercise bike there is?
According to me, one of the best Exercise Bike is Fitness form S20 Indoor Cycle Bike. It has adjustable resistance level and adjustable horizontal or vertical seats also. It provides the pulse, distance and speed or has roller wheels to move around easily. In this bike, you can also get a warranty of 12 months.
Aug 09, 2012 | Exercise & Fitness
Apr 24, 2012 | Schwinn 220 Recumbent Exercise Bike - 2012...
Schwinn 215p manual
I can not find anything on the 215p , but I did find a manual for the 217p :
http://download.dfxi.com/supportdocs/OM/Schwinn/SCH_117-217_OM_web.pdf
I hope this helps.
Sep 24, 2011 | Cycling
I'm looking for a manual for a recumbent bike,
Hi lcbir5319...
Go to the following websites for your user manual and parts list for your Schwinn 203.
Please take time to rate me thumbs up
User Manual:
http://download.dfxi.com/supportdocs/OM/Schwinn/SCH_103-203_OM_web.pdf
Parts list: http://download.dfxi.com/supportdocs/AM/Schwinn/SCH_201-203_AM_web.pdf
Schwinn website/customer support:
http://www.schwinnfitness.com/schwinn_fitness_us/customersupport/manualsen.jsp
Sep 12, 2011 | Cycling
Schwinn recumbent bike 203 Ac adapter or batteries?
It uses an AC adapter. You can visit:
fitnessrepairparts.com
This is where I am getting the AC parts for my 201.
Mar 21, 2009 | Cycling
Exercise & Fitness Logo
Top Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
