Question about Frigidaire ATF6000ES Front Load Washer
Wm1832cw washing machine spins sometimes - Frigidaire ATF6000ES Front Load Washer
  • Frigidaire Master
  • 5,323 Answers
SLIPPING CLUTCH? OR LOOSE WORN BELT
Posted on Apr 01, 2015
LG WM1832CW, what is the key code combination to cause it to spin only?
The machine has a "Rinse & Spin" button in the "Options" side of the control panel. Press this button to accomplish the spin "cycle" that you require.
Oct 12, 2014 | LG WM-1832C Front Load Washer
LG wm1832CW Front load washer , error code OE and shut down, drain cleaned pump ok, ?
Yes, could be that the pump has dropped down on the efficiency.
check this link for tips to reset or rework the pump
Click on Pump
Jan 15, 2013 | Washing Machines
Hello, I have the LG Washing Machine Model WM1832CW and I'm having drain issues. The machine itself wont drain the water out. The water remained in the machine. Please advised on what I need to do in...
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Apr 26, 2011 | LG WM-1832C Front Load Washer
LG WM1832CW IT IS VERY LOUD WHEN IT SPIN FAST LIKE BEARING GOING OUT ARE SOMETHING LIKE THAT
Hi...if it sounds like like a jet taking off?? Yes you have a inner tub and outter tubs gone bad
Mar 23, 2011 | LG Washing Machines
WM1832CW has stopped spinning. Tries to spin but
If the drum is loose it probably means that the bearings at the rear.....OR...The arms that connect the drum to the pulley shaft have broken.....Major job....Sorry.....Nomess
Apr 18, 2010 | LG WM-1832C Front Load Washer
Lg-wm1832cw front loader washer won't spin and drain
did anyone solve this problem? Mine is doing the same thing... uggh!
Apr 12, 2010 | LG WM-1832C Front Load Washer
Over filling,will not spin out water, timer will not advance. lg model # wm1832cw
It sounds like it's the electronic control board. Contact an appliance service company.
Feb 24, 2010 | LG Washing Machines
Noisy on spin cycle LG WM1832CW
this is joyce
Go to lg.com and download your manuel put in your model #
thanks
joyce
Feb 07, 2009 | LG WM-1832C Front Load Washer
LG wm1832cw shaking bad in spin after move
manual,,lg.com...but befroe youdo that,,put the unit in spin ,,get a small wrench or the wrench that came with the installation pack..now when unit goes into high spin the fastest spin,,tighten the lock nuts on the legs one at a time dont turn the leg itself,,just the lock nut on the legs,,it might take two spin cycles but you will get it ..tighten all the way uop to the base,,,onthejob
Jan 09, 2009 | Washing Machines
LG WM1832CW
hi linda from what you describe? the machine does wash cycle? but won't spin cycle? if the machine is a couple of yrs old ? it may well be the motor that runs machine is in need of some new brushes fitting ? they are not expensive and may be worn too low to activate the higher revolutions needed for spin cycle it is not a difficult job to drop motor off and check/replace if you have a good male/ friend? with elec competence ? have found this problem on other machines and most recent zanusi cost £5 for 2x new brushes as apposed to the £££££s the lady was estimated for a timer ? by plumber so why not check it out b4 you part with money ? best wishes/luck
Oct 16, 2008 | LG WM-2277HW Front Load Washer
Frigidaire ATF6000ES Front Load Washer Logo
19 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
