Question about Makita UC3530A 14" Electric Chain Saw
Chain is dry as oil is not sucking through on to chain
Using the chainsaw, I can see that no oil is getting on to the chain even though the oil tank is full and there doesn't seem to be any blockages. Please advise
  • 22 Answers
SOURCE: Makita 5012B chain cannot be tightened
some chainsaws have different knotches where the bar locks onto the saw. loosen the nuts and see if you can move the bar.
Posted on Dec 13, 2008
dontbother10
  • 2220 Answers
SOURCE: makita dcs 34 oil not getting to chain bar
Clarification Request
Posted by rowdy45176 on Feb 21, 2009
What I would do first is remove the bar and run the saw a short time to see if oil coming out of pump (make sure there is oil in the tank) if so recheck the bar for blockage in the small round hole in the side and run something like a paper clip or small piece of metal to clean out the groove. If you need a breakdown for this tool you might want to try Makitatools.com. I haven't checked to see if it is there but usually it would be. Good luck
We need Make, model and serial numbers from the manufacturer's tag to help you any more. Your manuals can be found here:
Dolmar/Makita
http://www.makita.ca/index2.php?event=toollist&categoryid=7
GL
Lou
Posted on Sep 14, 2009
dontbother10
  • 2220 Answers
SOURCE: makita 520 chainsaw chain carnt get the right chain
Oregon Bar & Chain Selector
http://www.oregonchain.com/commonpgm/Selguide_Selctmfg.asp?BusId=OCS&SellReg=USA&LangId=ENG&ShowRem=Y&ShowAnsi=Y&ShowQuality=Y&ShowCombo=Y&usertype=OCC
An Oregon part Number can easily be converted to other manufacturer's. HTH
Lou
Posted on Oct 02, 2009
dontbother10
  • 2220 Answers
SOURCE: Ryobi Chainsaw - PCN 4545
Ryobi boasts a two year warranty. Have you contacted anyone about a warrantied repair?
An IPL (expanded parts list) for your saw with any oil system detail can be found here:
Homelite/Ryobi.com
https://www.gardnerinc.com/recons/disclaimer-lg.php - Agree; Choose “Product Line”; “Select OEM” & “Select Catalog” both to “Homelite Consumer Products”. A drop down list appears; self explanatory from here.
The numbers Homelite & Ryobi use don't match the numbers everyone posts. A careful inspection of your saw should find something that matches.
Oil System Plugged.
Remove the clutch cover, bar and chain. Clean the oiler hole and channel. Start the saw and see if it oils when revved up. If yes reassemble your saw.
If no a blunted, hooked piece of wire can be used to pull the hose in the oil tank out. I recommend the filter be replaced. Work your way through the linkage cleaning and replacing any defective parts as you go. Carefully check the hoses for cracks especially at bends and connections. If equipped with an oil pump it is usually behind the clutch (clutch is probably left handed thread). Please make extensive notes & some digital pictures will help during reassembly. GL
Lou
Posted on Oct 08, 2009
dontbother10
  • 2220 Answers
SOURCE: chain fell off
That often creates burrs, this may help with removal, Your OM is excellant for installation, maybe the best I have seen.
http://www.fixya.com/support/r4146814-chainsaw_chain_installation
See pages 19 & 20.
http://www.makita.ca/data/upload/tools/dcs6401%20F-E.pdf
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
Posted on Apr 09, 2010
Chainsaw chain keeps getting tighter when using?
this is a sure sign of chain overheating , due to not enough oil to bar , this will eventually cause bar to wear down and chain to not stay on
ck your oil pump and oil tank for proper operation
Aug 25, 2015 | Husqvarna 435 - 16" 41cc Consumer Chainsaw
My homelite chain saw is not getting oil on the chain from the automatic oiler?
either a faulity oiler or oil lines cloged try using compresed air to clear the lines by blowing in the oil tank
Nov 15, 2011 | Garden
What kind of oil or oil mixture do I need to use my Remington 2.0 HP 14" Electric Chain Saw?
Hi brown9148..
The only oil you need for your electric chain saw is "Bar and Chain" oil...specially formulated oil sold at Loews,HomeDepot,Ace Hardware, Auto parts stores,etc...
You use this oil to lubricate the chain and bar of your chainsaw when you are using it.
It will go into the oil tank and auto feed to the chain and bar...but keep a check on the oil level to make sure it is being used.
Refill tank when needed.
Please take time to rate me
Sep 24, 2011 | Remington Electric Chain Saw
The automatic chain oiler does not get oil to the chain. Yes, it has chain oil. The black tube to the top chamber at the bar, seems to be plugged and I cant get it off to clean it out. Thanks, Steve
I have never seen an automatic chain oiler that worked. Even new ones don't seem to work. Just pour a little used engine oil on the bar once in awhile like everyone else does.
In theory there is a small piston that rubs on an eccentric at the chain sprocket, and that sucks in oil and pushes it through a hole, into the center groove of the bar.
But if the piston is dry, it won't pump.
If the holes are clogged with sawdust, it won't work.
Here is a video that may help:
http://www.ehow.com/video_4756894_a-chain-saw-bar-oiler.html
Mar 12, 2011 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Chainsaw seems to be burning the wood?
If the chain is oriented as the lower portion of the photo it is dull.
Chain sharpening is an art, if not correct it will not cut straight. I suggest you consider having it done professionally ($10± for 20" chain).
If you have more questions or need additional help please reply below and I will get back to you. HTH & Good Luck.
Lou
Thank You for using FixYa.
Jul 15, 2010 | Stihl Chainsaw 42mm Piston Rings 025 O25...
NO OIL ON THE CHAIN
Remove the bar and chain, and start the engine. If oil comes out of the port near the sprocket, then clean all holes in the drive end of the bar including the small passages into the chain slot. If no oil coming from the port, then the pump may be bad or a line from the oil tank to the pump and/or from the pump to the port at the bar may be in bad condition. The oil tank end (inside) has a filter. If dirty oil has been put in, the filter may be plugged. On some saws there is provision for adjusting the flow rate.
Aug 10, 2009 | Garden
Mcculloch chainsaw 2014 Eager ****** Model 00032-14
a fix that sometimes works is to add kerosene to oil tank where the oil would go normally and rev saw several times with out load holding blade in down position over a piece of dry card board so you can see the oil spraying on the piece of cardboard careful of moving chain
Jan 02, 2009 | McCulloch 16 In 4.5 Hp Electric Chainsaw...
Excessive chain oil coming from oil tank onto the chain.
change the oil cap put a new one on the problem should go away.
Jan 02, 2009 | Echo 30.1CC Chainsaw With a 14 In.bar and...
Chainsaw chain won't move on 16" Homelite bar
Sounds like th clutch brake is engaged. Try Pushing firmly foward on the hand guard in front of the handle. It should click to release the clutch brake.
Let me know if this helps.
Dec 29, 2008 | Homelite Consumer Products 9.0 Amp, 14 In....
Location of bar oiler adjustment screw on p4018wt
THIS WORKED FOR ME....I have a 2014. I've had that problem for quite awhile. I finally decided to try to fix it. I took the bar and chain off, removed all the crud in there. Then I took a small air compressor and blew out the entire area so it was pretty clean. I started the saw at this point and gunned it some. The oil became noticible within a few seconds where it comes out at, above the outer chain bar bolt. Once I found the hole, I then drained the oil tank, and then using the air pump, blew out the hole from the blade area to the tank, leaving the oil cap OFF. Upon refilling the oil tank with a lighter oil (10 wt), I restarted the saw, and the flow was really coming. After the oil; tank empties, I'll start using the regular bar-and-chain oil again, but it's pretty heavy, even though it says it is 30 wt.
JimBo
Nov 09, 2008 | Garden
Makita UC3530A 14" Electric Chain Saw Logo
Top Makita Garden Experts
JOHN LAPIER
Paul Sikkema
Paul Sikkema
Are you a Makita Garden Expert? Answer questions, earn points and help others
