Question about Microsoft Xbox 360 Console
Xbox 360 slim won't boot. no lights on console
So my xbox 360 slim won't power on at all from the power button or controller. I have already confirmed that the power supply is working on a different 360 console. None of the USB ports are making contact with the case so that's not the problem either. The console is currently completely torn down and I have confirmed with a multimeter that the board is receiving 5 volts (is in standby mode). An inspection of the capacitors shows that they are perfectly flat and smooth the touch and there is no sign of burn marks on the board around them. My feeling is that the MOSFETs are the next logical place but I'm not sure how to properly test them. I am good with a soldering iron and don't mind removing them from the board if that's necessary to test them but don't want to do so needlessly. Any help would be much appreciated.
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 33 Answers
Your sure the power supply inside the xbox hasnt just died
Posted on Feb 17, 2014
  • 2 more comments
  • andrew orth
    andrew orth Feb 18, 2014
    Absolutely positive. The output of the psu itself is 5v and I can confirm that there is also 5 volts at pin 10 of the power socket on the mobo. 5 volts should indicate that the psu is simply in standby mode. Unfortunately I'm not sure where I should be looking next to find the problem. As I said, my feeling is that the mosfets are the next likely culprit but in order to test them I would need to first desolder the coils from the mobo. If thats the case then so be it, I would just really like to hear the opinion of someone with more knowledge than myself on the subject before i start down that road
  • andrew orth
    Well actually I guess I'm not sure. How would I test that?
  • andrew orth
    I'm not sure what you're referring to. The plug receptacle for the power cord.
  • andrew orth
    ? I meant
4 Suggested Answers
SOURCE: My xbox 360 wireless button doesn't work????
I had the same problem with my new controller. The trick is to hold the connect button on the console for a few seconds and then hold the connect button on the controller. The main part is to hhhhoooolldddd it until the ring lights up.
Posted on Jan 09, 2008
  • 3 Answers
SOURCE: xbox 360 sync problem - controllers will not connect
maybe the only way is take it a part and see if the sync button is not broken some how. therefore i advise you to buy a new controller maybe even a used 1 if you dont want to spend more than $20.
Posted on Mar 31, 2009
techprogrami
  • 57 Answers
SOURCE: Xbox 360 nothing displayed on the screen
first make sure the switch on your cable is on "tv" not "high def"
Posted on Jun 01, 2009
Xbox slim 360 no lights but connects to xboxlive but cant control anything no greenlights at all
So for all intents and purposes your Xbox works but your controller isn't controlling it at all, is that correct?
If so please follow the steps here which may help:
http://support.xbox.com/en-GB/xbox-360/accessories/connecting-game-controllers
Regards,
Steve
Jun 16, 2014 | Microsoft Xbox 360 Console
Xbox 360 slim wont turn on but it beeps and lights up
there is a short somewere In the system and it is in protect mode and will not turn on so that the console does not get harmed anymore than it already is. the best solution for this is to send it in to Microsoft and get this problem fixed
Jul 11, 2013 | Microsoft Xbox 360 Slim Black Console
Xbox 360 won't eject with front button.
Depending on your Xbox slim(black) or original (white), you can hold down the Xbox button, or go to the main menu and eject from there manually, this is a temporary bug, it also dependes on the ae of your xbox so don't mess with it and retry every few hours
Mar 17, 2013 | Microsoft Xbox 360 Console
My xbox 360 will not sync with any controllers besides the one controller I've already had synced. I haven't had any problems with it until recently, and now it seems like the xbox won't...
If you have an xbox slim model then there is a button above the USB slots at the bottom. Press Start and Back on the controller until the center button lights up. Then press the button above the two USB solts and hold it for a couple secs.
If you have n old xbox there should be a simliar button some where.
Also if you bought one of the charging packs for the controller, use the cord that came with it.
Thank you for your time, Good luck and I hope it works.
Jun 05, 2011 | Microsoft Xbox 360 Console
How do you turn on an xbox 360?
Simply press the big button that has green lights around in front of your console
Apr 21, 2010 | Microsoft Xbox 360 Console
How to setup two wireless controlers to an xbox
  1. Press and hold the Xbox Guide button until the controller turns on. The Xbox Guide button is the round button with the green "X" near the center of the controller.
  2. Make sure that your Xbox 360 console is turned on. If your Xbox 360 console is not turned on, press the power button. The power button is the large round button on your Xbox 360 console.
  3. On the Xbox 360 console, press and release the Connect button. The Connect button is the small round button on the Xbox 360 console.
  4. On the controller, press and release the Connect button. The Connect button is the small button on the front edge of the controller, between the left bumper button and the charging port.
  5. After the Ring of Light spins and flashes one time on the controller and on the console, the controller is connected. The quadrant on the Ring of Light that remains lit indicates the position in which the controller is connected.
  6. Note If you want help connecting an Xbox 360 Wireless Controller to your Xbox 360 console, you can contact Xbox Customer Support. For more information about how to contact Xbox Customer Support, please visit the Xbox Support (http://www.xbox.com/support/) Web site.
  • The controller remains connected to the Xbox console even when you turn off the Xbox console.
  • The controller is connected to only one Xbox console at a time. You can connect the controller to a different Xbox console at any time, but your connection to the previously connected console is lost. You must repeat these steps to reconnect the controller to the original console after your connection to the console is lost.
  • The controller works within 33 feet (10 meters) of your Xbox 360 console. However, objects between the controller and the console may reduce this range.
  • If the controller does not turn on, the batteries may have to be replaced.
Mar 22, 2010 | Microsoft Xbox 360 Console
My controller will not link with my xbox. it just flashes 4 green lights around the circle. what can i do?
Did you sync it? here's how to sync it:
Step 1: Power on your Xbox 360 console2_bing.gif. In this guide I'm assuming everyone already has their console2_bing.gif hooked up, if not, contact me.
Step 2: Power on Xbox2_bing.gif 360 Controller. Make sure it has a battery pack that has correctly place and working batteries or charged re-chargeable battery pack.
Step 3: Locate the small circular sync button on your controller. It is near where your controller can be plugged in (between the LB and RB).
Step 4: Locate the small circular sync button on your Xbox 360 console. It is next to Memory Unit slot 2.
Step 5: Press and hold the controller sync button until the green power lights start spinning.
Step 6: While your controller lights are still spinning press and hold the console sync button. The console's lights should spin also, then flash, and finally show the player slot light on both the console and the controller.
Viola! You've synced your wireless controller! You can sync up to four controllers.
Also, you can use this guide to sync to different Xbox 360 consoles. So you can bring only your controller to your friend's house.
Note: If you sync your controller to another console, you will have to re-sync it to your own afterwords.
Jan 23, 2010 | Microsoft Xbox 360 Controller
My controller and xbox wont connect
To connect the controller to your Xbox 360 console, follow these steps:
Aug 28, 2009 | Microsoft Xbox 360 Wireless Controller
My xbox 360 and wireless controller will sync but then it wont show that they are connected and even though i turned on my console by using the button on the console it just shows the green light turn on...
  2. Make sure that your Xbox 360 console2_bing.gif is turned on. If your Xbox 360 console is not turned on, press the power button. The power button is the large round button on your Xbox 360 console2_bing.gif.
  5. After the Ring2_bing.gif of Light spins and flashes one time on the controller and on the console, the controller is connected. The quadrant on the Ring of Light that remains lit indicates the position in which the controller is connected.
Aug 15, 2009 | Microsoft Xbox 360 Console
Setting up a 360 wireless controller
Turn Your Console and Controller On The Xbox® Guide button in the center of your controller puts the Xbox 360® experience at your fingertips. Press and hold the Xbox Guide button to turn your console on.
To turn on your console only, press the power button on your console. To turn on your controller only, press the Start button on your controller.
Once on, pressing the Xbox Guide button gives you immediate access to the Xbox Guide. To turn off your console, press and hold the Xbox Guide button for three seconds and then confirm your selection.
Turn Your Console and Controller Off To turn your console and controller off, press and hold the Xbox Guide button on your controller for three seconds. Then select whether you want to turn off just your controller or both your controller and your console. (Selecting the console will turn off both the console and all connected controllers.)
To turn off one controller when multiple wireless controllers are connected, press and hold for three seconds the Xbox Guide button of the controller you want to turn off, then select Turn Off Controller.
To turn off your console only, press the power button on your console
When you connect a controller to your console, it is assigned a specific quadrant, which glows green to indicate the controller's number and position. Each subsequent controller connected to the console (up to four) is assigned an additional quadrant.
If system problems should arise, the Ring of Light on the console will flash combinations of red.
I hope this solved your problem.
Happy Gaming!
Oct 17, 2008 | Microsoft Xbox 360 Wireless Controller
Microsoft Xbox 360 Console Logo
53 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
