Question about Wine Enthusiast EuroCave SoWine Home Wine Bar
Not cooling Does not cool
My Nilfisk GU305 cuts out after a few minutes use
You are probably right. There is not enough air flow around the motor. It uses the air from the vacuum as the cooling air.
There is a secondary filter after the first filter bag. You may think the bag is not full and don't think you need to change. Sometimes the material you vacuum is so fine that it will clog the filter bag. I've done it vacuuming sheetrock sanding dust. Then just below the main filter is the secondary filter. Depending on the age and amount of use, there could be other problems. Motor brushes about to fail. A wire connection that separates as temperatures rise. Then reconnects when "cool". Plug end may be a problem. Its connection to the switch. The switch it'self could be.
Mar 21, 2015 | Nilfisk Vacuums
My dirt devil breeze turbo shut off while I was vacuuming. I've checked 3 outlets and nothing happened
It may have overheated from a restriction or clog. If so it will come back on after it cools down.
Mar 01, 2015 | Dirt Devil Breeze Turbo Upright Vacuum
I have a Fantom Thunder TH469KA and it shuts off after 5-10 min of running How do I fix this?
on all vacuum cleaners the air flow cools the motor. If the filter is sufficiently clogged there would not have enough air flow to cool the motor and trips out from over heat. Clean out the filter thoroughly and try again.
Jan 01, 2015 | Fantom Vacums Vacuums
The Suction motor has stopped operating. Is there a reset switch?
The thermal reset is built into the motor. It shuts the motor off until it cools down. If it won't runs hen the motor is cool check the cord and switch first.
Jan 15, 2014 | Hoover U8143-900 Upright Vacuum
Vacuum was working fine now it won't even turn on
Did the vacuum just stop dead while you were using it? The vacuum contains a thermal-fuse which will cut the power off if it gets too hot. Unplug it and leave to cool for 10-20 minutes and then try it again.
If the vacuum has already been allowed to cool and there is no power, there are many possible faults including the power switch, motor and thermal fuse. In order to determine where the fault is, you will need an ohm-meter / multi-meter.
If you've allowed the vacuum to cool and it's still dead, please post back for further assistance and let me know whether you have any electrical test equipment.
Regards,
BElectric
Dec 09, 2010 | Electrolux EL7020A Oxygen 3 Ultra Canister...
Ice and water are developing in my almost emty refridgerator. How can I fix it?
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Sep 06, 2010 | Vacuums
Where is reset button on Hoover Wind Tunnel vacuum?
Hello my good friend, this cleaner doesn't have a reset button or anything, it resets by itself after cooling down, it takes about 30 minutes to cools down.
Nov 07, 2009 | Hoover Company Wind Tunnel U53019 Upright...
It runs for a couple of minutes shuts off then restarts 30 seconds later runs a couple of minutes and does this over and over
Most vacuum motors are protected from overheating by a thermal switch that resets after cooling down. Check for blockage in the hose,
power head or a full bag that would block cooling air from cooling the motor.
Tom
Oct 22, 2009 | Tristar Vacuums
Wine Enthusiast EuroCave SoWine Home Wine Bar Logo
22 people viewed this question
Top Wine Enthusiast Vacuums Experts
JoeVacs
Are you a Wine Enthusiast Vacuum Expert? Answer questions, earn points and help others
