Question about Bissell 3102-0 EasyVac Upright Vacuum
Removing end to hose of a bissell easyvac
I accidently sucked a small sock into hose
  • 37 Answers
SOURCE: Our Bissell vaccum turns on
check and clean all filters or look for any obstruction in the hose.
Posted on Oct 01, 2008
rylee_smith
  • 8619 Answers
SOURCE: clogged hose...
Hi!
Low suction, poor pickup, or no suction may be due to a clog in the vacuum cleaner. If you notice a change in the sound of the motor or a reduction in the spinning action in the Dirt Container, check for clogs. Unplug cleaner from electrical outlet. Empty Dirt Container. Check Upper Tank and Louvers for build up or clogs. Check to make sure Louvers are installed correctly. To unlock the Louvers, grasp the rim and turn toward the left. Pull straight down to remove. If the Louvers are missing or not locked into place, check and clear the tube in the center of the Dirt Container. Remove the Twist ‘n Snap Hose from the vacuum by turning to the left. Check the Suction Inlet, Hose and Hose Wand for clogs. Remove any clogs from the hose using a long, narrow object. Check the Foot Hose for clogs. If needed, remove the screw attaching the Hose Wand Base to the vacuum. Straighten the Foot Hose and unclog with a long, narrow object. If the clog persists, then check the Rotating Floor Brush the Air Passageway for obstructions.
Please do rate this solution as FixYa and revert for further assistance.
Thanks
Rylee
Posted on May 10, 2009
SOURCE: need filter, bissell 3102-0 EasyVac
The filters can be found on GoVacuum.com for 11.90 with free shipping
Posted on Oct 12, 2009
  • 5 Answers
SOURCE: Bissell easyvac 3108.No suction.Changed
I had the same problem, ended up I had to clean out the hose for the accessories...I found out how to do it by looking at the troubleshooting section of my owner's manual online at bissell.com. (Just type easy vac under troubleshooting and choose the instruction manual based on your model number). If none of these things work, you can always contact bissell at 1-800-237-7691. hope this helps!!
Posted on Feb 03, 2010
  • 5 Answers
SOURCE: bissell easyvac filters
Replace Filter
As you vacuum, dirt and debris are deposited in the Dirt Cup
while air passes through the filter before being returned to
the room. This process enhances the vacuum path while
dramatically reducing dust, dirt, and potential allergens from
the air you breathe. Replacing the filter periodically enhances
vacuum power and air quality. To replace the filter:
1. Remove the Dirt Cup.
2. Grasp the filter frame and pull it straight from the Cup.
Empty the Cup.
3. Replace the filter. Push new filter into place at the top of the
Cup, place the small tab at the bottom of the Cup into the
slot at the bottom of the Canister cavity, then press the upper
portion of the Cup into place until the lock button snaps
into place. Use only BISSELL Style 6, #32047 Filters
[package of 2] in your BISSELL EASY VAC™ Model 3101-0.
4. EASY VAC™PLUS Model #3102-0 features a high efficiency
3M Filtrete™ Filter. To keep your cleaner operating at peak
efficiency and to remove irritating allergens from your
home, you should change the FILTRETE™ filter every six
months. Use only BISSELL Style 6, #32046 Filters [package
of 2]. The cup-shaped filter lifts out from the top of the
Dirt Cup, and the new one fits into place.
You may purchase these filters
by calling
BISSELL Consumer Services
1-800-237-7691
Monday - Friday 8 a.m. — 7 p.m. EST
Saturday 9 a.m. — 2 p.m. EST
or from the BISSELL website —
http://www.bissell.com
I have a sock caught in the vacuum cleaner hose it is about 5 ft past the beginning of the hose and very stuck I have tried sucking it to the canister but no luck please help the suction is almost too good...
take a coat hanger and straightn it the best you can then make a small hook on one end of it and if you can unhook one end of the hose straightn the hose and try to go fishing with the coat hanger.
Mar 20, 2011 | Vacuums
My Bissell easyvac is nolonger picking up rpoerly, I cannot find the user manual. What can I do?
You can download the user manual from the manufacturer's web site at
http://www.bissell.com/DownloadAsset.aspx?id=577
Mar 06, 2011 | Bissell 3102-0 EasyVac Upright Vacuum
Bissell 35962 Cleanview Bagless Revolution Upright Vacuum hose is clogged with sock where hose meets handle attachment. Attempted to use broom handle to push back through suction opening. Sock is...
If you have access to a small sink "snake" used to clear clogs in sinks, you might be able to use it to "snag" the sock and pull it out. Needs to be a metal sewer snake so that you can tug on it if and when it snags the sock.
Sep 05, 2010 | Bissell 35962 Cleanview Bagless Revolution...
So... my friend sucked a sock in his maybe '07 bissell.
its there and is stuck itll take some time and patience to get it out its probally stuck at the sammlest poit pf suction .and the coat hanger and such is really the only way unless you wanna tear it down?
Jul 06, 2009 | Bissell 2600 Sweeper Vacuum
Bissell easyvac filters
Replace Filter
Empty the Cup.
by calling
1-800-237-7691
Jun 29, 2009 | Bissell 3102-0 EasyVac Upright Vacuum
Does the hose come off the dyson? I accidently sucked up a rag now it is stuck in the hose
hi. i can help you. the best way to remove the rag is to straighten out a wire coat hanger and put a small bend at the end to act as a little hook. shove it into the hose, snag the rag and pull it out.
Jun 23, 2009 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Bissell easyvac 3108.No suction.Changed filter/cup.Brush working fine.
May 09, 2009 | Bissell 3108 EasyVac Powerbrush Upright...
Clogged hose
if you have a drain auger then you can stick it in until it won' go any further then you have hit the sock.turn the cable and grab the sock and pull it to the surface.please leave feedback
Mar 30, 2009 | Electrolux Central Vacuum
Need filter, bissell 3102-0 EasyVac
Mar 13, 2009 | Bissell 3102-0 EasyVac Upright Vacuum
My bissell easy vac won't pick up after first use
Well after reading and re-reading my bissell easy vac manual (I had only used the vac twice), I went through all the troubleshooting recommendations. I cleaned out all filters and even though I had only used my hose attachment once, I was shocked that it was completely clogged! I took the whole thing apart and thoroughly cleaned it out according to the manufacturers instructions. It is working beautifully again now, I just take extra care to check it after every use...it can be a hassle, but I find that's what happens when you buy bargain items; you spend less but end up investing more time in upkeep. I hope this helps!! :)
Dec 20, 2008 | Bissell 3102-0 EasyVac Upright Vacuum
Bissell 3102-0 EasyVac Upright Vacuum Logo
14 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
