Analogy of he is to she , there is to here - Computers & Internet
Video matrix switch uninitialized?
Use a Hyper terminal, Hercules SETUP utility is user friendly for this. Attach a Serial cable to the unit (straight through cable not null modem) or use a USB to serial cable.
Set the Baud rate to 115200
Data size 8
Parity none
Handshake OFF
Mode Free
do not check the box for Hex
For the 12x8 digital/ analog audio matrix switch cat5 enter the command [S,M,Q]
12x8 digital/ analog audio matrix switch [S,M,L]
8x8 component video digital/ analog audio matrix switch cat5 [S,M,C]
8x8 component video digital/ analog audio matrix switch [S,M,B8]
12x8 component video matrix switch [S,M,I]
12x8 component video matrix switch cat5 [S,M,H]
8x16 digital/ analog audio matrix switch [S,M,G]
8x16 digital/ analog audio matrix switch cat5 [S,M,E]
8x16 component video matrix switch [S,M,F]
8x16 component video matrix switch cat5 [S,M,D]
12x16 component video matrix switch [S,M,J]
12x16 component video matrix switch cat5 [S,M,O]
12x16 digital/ analog audio matrix switch [S,M,K]
12x16 digital/ analog audio matrix switch cat5 [S,M,R]
Oct 31, 2013 | HDTV Supply 12x8 stackable digital/analog...
Left analog stick My Xbox left analog stick does
Analog stick might be bad and may need replaced. If you don't feel comfortable tearing it apart, you may want to look into a new / used one.
Oct 12, 2013 | Microsoft Xbox 360 Controller
Problem with logitech dual pad right analog
Try to disassemble the pad. Reseat the analog stick and re-assemble the pad.
May 12, 2012 | Logitech Dual Action for Pc (963292-0403:)...
Classifications of computer
types of Computer According to Operation.
There are three basic types of computer according to their operation:
1. Analog Computers.
2. Digital Computers.
3. Hybrid Computers.
1. Analog Computers:
"Those computers which are used for measuring of physical quantities are calledAnalog Computers". Analog means variable and physical quantity always changes.
"Those computers which measured analog type of data are called Analog Computers"
These computers accept input in analog form and provide an analog output of information. It represents physical quantities like distance, velocity, acceleration and temperature. It measures continues changes in physical quantities. e.g. speedometer of a care, temperature, needle's watch for measuring the time, volt meter for measuring voltage. Now a day analog computers are using for Engineering and Scientific works. In Oil Refinery measures flow and temperature of oil. They are also used in Paper making and Chemical Industry. Out put of the analog computer is generally in the form of readings. These computers are dial in situation where data can be measure directly from measuring instrument without having to convert into numbers or codes. Now a day Analog Computers are proceed to Digital Computers. For example: Analog watch to Digital Watch, Analog Balance to Digital Balance and Analog Thermometer to Digital Thermometer etc.
2. Digital Computers:
"Those Computers which accept digital input and provides information in digital form are called Digital Computers".
"Those Computers which measure in term of digital quantity are called Digital Computers".
These computers works on the base of binary digits i.e. (0 & 1).
The results of the Digital Computers are more accurate, precise and reliable then the result of Analog Computers. Digital Computers are faster then Analog Computers. Analog Computers lack memory while Digital Computers store information.
Accounting machine and Calculator are the common example of Digital Computer.
Now a day Analog Computers are proceed to Digital Computers. For example: Analog watch to Digital Watch, Analog Balance to Digital Balance and Analog Thermometer to Digital Thermometer.
3. Hybrid Computers:
"Those Computers which accept digital inputs and provides outputs in the form of analog and vice versa".
Hybrid Computers have the characteristics of both Analog & Digital Computers. It is the computer which measures both the analog and digital quantities. It combines the both features of analog and digital computer. Hybrid Computer has process with the speed of analog and accuracy of digital computer. They are used for special purpose. These are designed to perform special task. For example ECG machine. Hybrid Computers are also used in Air Defense System. Data Communication and Transmission and in different laboratory for medicines.
Basically computer has two types according to their function.
1. Special Purpose Computers:
2. General Purpose Computers:
1. Special purpose Computers:
"Types of computers which are manufactured for specific task are called Special purpose Computers".
These computers are also known as "Dedicated Computers" because these are designed for special jobs. In other words they are designed to handle specific problems. e.g. they are used in Computer Games, Control of Traffic Lights and in Defense System. A set of instruction permanent program feed to them. As they have to perform only one job so they are very fast.
"Types of Computers which can perform all types of jobs and can run all types of programs are called General Purpose Computers".
Those computers are performing variety of jobs and use for General Purpose. For example with a personal computer a user can perform typing, can play games, can make graphics and can do arithmetic operations. General Purpose Computers are versatile but they are slow in processing and less efficient as compare to Dedicated Computers.
Classifications of Computer Classifications of Computer
Computers are classified into different categories according to their physical size, cost and speed. We can general classified them into 05 categories. (Classifications of Computer)
1. Very Small (Micro Controllers)
2. Small (Micro Computers)
3. Medium (Mini Computers)
4. Large (Mainframe)
5. Very Large (Supper Computer)
Jul 12, 2011 | Computers & Internet
I have a casio ediface 5033 80W-M10008 how do I set the analog time
Thank you for contacting FixYa.
To set the analog time, press the lower left button 6 times. Next, press and hold the upper left button until the digital time starts to blink. This indicates that you are in analog time setting mode.
Analog time adjustment is completed using the lower right button. Every time you press the button, the analog time will advance 20 seconds. If you need to make a big change to the analog time, press and hold the lower right button to make the hands move faster. Once the analog time is set, press the upper left button to exit the analog time setting mode.
Best regards. Jewel
Sep 15, 2010 | Casio Edifice EFA109-7AV Wrist Watch
Analog is cutting in and out while channel isn't being changed. Also, channels in analog have no sound at all. I tried to switch signal select to auto and the problem continues. what should I try next?
If you're only using analog audio, switch the signal selection to manual or analog.
If the source(s) that do this are primarily digital and they experience any problems the unit will want to dynamically switch to its analog path. If there's no analog path connected from the same device(s) you'll get silence every time it switches to analog. Observe the display when the problem occurs.
May 30, 2010 | Pioneer VSX-90TXV Receiver
How to use olympus telephone pickup tp7
Look this instructions is the same operation Comparable Models:
  • SONY ECM-TL1 Cellular, Cordless, Analog, Digital, VoIP Telephone Record Adapter
  • Olympus TP7 Cellular, Cordless, Analog, Digital, VoIP Telephone Record Adapter
  • TC-L Cellular, Cordless, Analog, Digital, VoIP Telephone Record Adapter
  • CC-10 Cellular, Cordless, Analog, Digital, VoIP Telephone Record Adapter
  • CC-20 Cellular, Cordless, Analog, Digital, VoIP Telephone Record Adapter
  • TC-W Cellular, Cordless, Analog, Digital, VoIP Telephone Record Adapter http://www.tvps.com/ecsdownloads/ECS-EBPR/ECS-EBPR-Cordless-Cellular-Telephone-Recording-Adaptor.pdf
Feb 11, 2010 | Olympus Audio Players & Recorders
The analog works fine in the options menu but when
Try calibrating your PSPs analog stick, here's how: 1. Go to Settings>System Settings 2. With the System Information screen displayed, rotate your analog stick in a circular motion (clockwise and counter clockwise). This will adjust the analog stick's range of motion. 3. Exit the Settings then run your game and test the analog stick. (it should be working well by now)
I hope this helps.
Apr 12, 2009 | Activision Video Game Consoles & Games
Analog
Seeing the word "analog" on your screen means the monitor has recognized video input on the vga "analog" input connection.
Most computers output "analog" vga (15 pin) which must be converted to digital for a flat panel monitor to display the image.
Many LCDs now have both analog and digital inputs.
Mike
May 01, 2008 | ViewSonic VP191b 19" LCD Monitor
My JVC tv Is in digital and i want it in Analog
Look to see if your remote has a button with A/D on it. That is the button to press to switch back and forth between the analog and digital tuners.
Mar 28, 2008 | JVC HD-56G886 56" Rear Projection HDTV
Computers & Internet Logo
15 people viewed this question
David Payne
David Payne
