Question about HP 2159M Monitor
HP 2159M Monitor pink lines
Pink lines, vertical 1 pixel size. marching ants. each line is spaced over a quarter inch apart and span the entire screen.
  • 156 Answers
SOURCE: Vertical lines in my HP screen
Please check if you get those line as soon as you turn it on, If yes, so need to get a replacement for the screen , and if it is no, try updating video driver of your system from the manufacturer website.
Hope this work
Cheers!!!!
Posted on May 25, 2009
  • 225 Answers
SOURCE: Vertical red line on HP w2207 monitor
Please try to connect the monitor to another PC, if problem still exist then probably there's an internal problem in the circuit board of your monitor wherein an elecronic part/s might be cold soldered / defective. I recommend to bring the monitor to an authorized HP service center to fix the problem. If the monitor display is good if connected to other PC, then your previous PC should be checked if the VGA card (if there is any) is properly placed to its slot & working properly as well as it cables & connections. regards
Posted on May 30, 2009
  • 60 Answers
SOURCE: tiny pink dots will appear over the entire monitor viewing area
Its a signal cable problem,between AD bord to Panel..Fix it poperly, If no then replace the LCD panel..
Posted on Jul 10, 2009
pgh_pa_guy
  • 2992 Answers
SOURCE: hp monitor has vertical yellow line. Is this dead
Unfortunately, your display problem is not repairable, except by replacing the display panel itself. What's happened is that something in the electronics built in to the display panel has failed, and it's keeping that column of pixels stuck on all the time. There isn't any way to get at those electronics to repair them, so the only cure is a new display.
This kind of defect would be something that the manufacturer would fix if the monitor was still under warranty. Yours is probably out of warranty, but it can't hurt to check your owner's manual or the HP website, and see if there's any hope. If your monitor is past any warranty, it's time to look for a replacement.
I wish I had a more positive answer. Thanks for using Fixya anyway!
Posted on Jan 01, 2011
1alexh
  • 484 Answers
SOURCE: Running a Mac with an Hp monitor
You are using a monitor created for use with a MAC, the only monopolistic systems manufacturer in the world. No one may make anything for MAC except MAC. That you are able to get something working is a testament to your tenacity.
Now, see whether you can use different cabling to connect the monitor to the MAC.
Use the DVI, or single round multi-pin connector between the two devices, PC and Monitor ... sorry, MAC and monitor.
With the digital signals more tightly aligned, you should be able to get the pair running in sync a lot more easily than with normal monitor to PC cables.
The MAC has been made to be a finer machine for the creative industry, so you must also be creative, and get the two working together using the right technology.
Cheers!
-a.
Posted on Apr 20, 2012
Why are there thin red lines on my pc screen?
Electronic parts are defective in the monitor. You can either live with the problem or buy a new monitor.
Jun 22, 2014 | HP 2159M Monitor
When scanning dots show up in a vertical pattern
Printer DPI and PPI Ratings, General Dots per inch stands for the maximum number of tiny spots of ink that the printer can place in a straight line where the spots are theoretically small enough (i.e. ignoring spreading or smearing effects of ink on paper) that if placed in every other such dot position leaving white space between them, the spots can be individually distinguished. Pixels per inch stands for the maximum number of unique positions in a straight line that the printer can place an ink spot under control from the outside world, namely from a computer connected to the printer. Lines per inch stands for how close thin parallel lines can be printed and still be distinguished in the finished printout. The spaces between the lines count as "lines". Pixels per inch and dots per inch originally referred to the same thing. The printer mechanism was under the direct control of the computer and was physically positioned and placed dots as directed by the computer. Back then, most printer mechanisms were limited to placing dots only in positions suggested by a grid of dots X per inch horizontally and Y per inch vertically, for example 100x100 dpi Nowadays, many printers put dots "wherever they want" as opposed to in positions suggestive of a horizontal/vertical grid. Still there is a minimum dot size and a minimum dot spacing. A picture file (image file) represents pixels in a uniform horizontal/vertical grid pattern. And the printer needs to make a finished picture of the size, say 5x7 inches, that the user chose regardless of the number of pixels in the picture file. To simplify the process of relating the pixel count in the picture file to the possibly non-uniformly spaced dots on the paper, the printer or its supporting software may generate a temporary intermediate picture file with a set number of pixels per inch. The printer may have, internally, several choices of ratio of pixels to dots and the published rating can be the largest ratio except that the published rating may not exceed the dpi rating. Therefore there might be three "per inch" values involved at a given time, the pixels of the original picture file, the pixels per inch that the printer works with, and the dots per inch of the printer mechanism. Pixels per inch is usually not mentioned with printers. All printers come with their own software (including parts called drivers) to install on your computer. Usually the software does not let you exercise control over individual dots using your picture file. Rather the printer takes your picture file or data file and uses its own built in logic to lay down the dots and create the printed output. We are led to believe that a printer's ppi is usually a fraction such as a half or a third of its dpi rating. When a temporary picture file is created, there are at least two levels of software in use. High level software (which may run in your computer) takes your picture file and creates the temporary file. Low level software runs in the printer, takes the temporary file and controls the dot size and dot placement on the paper. Sometimes a printer is advertised using a phrase such as "300 dpi 1200 dpi quality". This means that the printer has some way of making dark edges on a light background appear smoother than the first number would otherwise suggest. A printer with 300 dpi 1200 dpi quality definitely cannot resolve alternating dark and light pixels less than 1/300'th inch each. But curved and diagonal lines and color boundaries should not have jagged edges suggesting individual dots rigidly positioned on a grid with a 1/300'th inch pitch.
Oct 24, 2010 | HP LaserJet 3050 All-In-One Printer
Pink and blue vertical lines through
It could just need the print heads cleaning or aligning
If you are not sure contact the shop you purchased your printer from it is under warrenty for 12 months
Apr 03, 2010 | Computers & Internet
Tekan tournament
Alternate Mokujin sounds
To hear different hit sounds for Mokujin, hold DOWN on the D-Pad or joystick before a match in which you are controlling him. Mokujin will now sound like a block of wood when damaged.
Arcade History Dip Switches
While at the Press Start screen for any of the Arcade History games, hold the select button and you will be given a list of dip switches. You can use these for such things as changing number of rounds or unlocking hidden characters, such as Baek in Tekken 2.
Choose Victory Animation
After winning a round and you see the replay showing, pressing each button( [X], [O], etc...) will result in a different victory animation. This also works when the opponent wins.
Play in 'Devil' mode in 'Devil Within' mini-game
This allows the player to play as Jin in permernent Devil mode without having his life bar drained out. The devil bar will be considered as his laser bar. The downside of this code is that it kills of you opponents faster thus unable to reach a higher combo rate.
Note: You must clear Devil Within under Medium difficulty. Then start a new Devil Within or Stage Select.
FOR THE BEST VISIT THIS SITE:
http://tinyurl.com/ydeuw6k
Nov 11, 2009 | Video Game Consoles & Games
HP c7280 scan 2 vertical lines
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00899181&tmp_task=solveCategory&lc=en&dlc=en&cc=us&product=3204785
this fixed it for me
Sep 20, 2009 | HP Scanjet 8250 Flatbed Scanner
Tiny pink dots will appear over the entire monitor viewing area
Jul 10, 2009 | HP w17e Monitor
Pink vertical line
From what you discribe it sounds like you have a row of dead pixels.
You can use this website to test for dead pixels:
http://www.gdargaud.net/Hack/DeadPixels.html
If you run the test and confirm that you have dead pixels, contact the laptop's manufacturer for support.
May 19, 2009 | Toshiba Satellite P105-S6177 Notebook
HP 2159M Monitor Logo
42 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
