Question about Horizon T91 Treadmill
Unpacked upside down
Of course didn't read directions first and unpacked upside down. legs flung open (luckily missing my daughters face by about three inches)...how do I get the legs to go back down? tried pushing but really hard and they don't stay. if I turn deckover to correct side, it is at a 2 feet incline...not sure what to do and no notes in instructions. Can't proceed with putting together until get the legs back doen. thank you...
2 Suggested Answers
  • 84 Answers
SOURCE: My T81 treadmill quit working. All of the lights
you need to check voltage going to the motors. no power ,the contoller board is not working. check the connections on the boardmake sure they are in all the way,also the power connections
Posted on Mar 18, 2011
Testimonial: "Thank you soooo much! Now I have somewhere to start and try to figure this out!"
Don't have the directions to put evenflo exersaucer together, need help. Is there somewhere I can get the directions? reg. number 07T-0538604
Instructions
    • 1 Place the large, round base on the floor. The outwardly curving edge should be facing downward.
    • 2 Attach the three pedestals to the base. To do so, insert your finger into each pedestal and loop the spring within around the hook found on the base in the appropriate holes. Insert the three plastic tabs on each pedestal into the base, locking them into place.
    • 3 Press the wider end of a lower leg assembly onto each pedestal piece. By wiggling the lower leg assembly side to side, you will eventually snap the pieces into place.
    • 4 Hold the seat ring in your lap with the open edge facing upward. Press each of the six wheels into the wheel holders around the edge of the seat ring. Each wheel will snap into place when positioned correctly.
    • 5 Insert the cloth seat into the seat ring, aligning the diamond on the cloth seat with the triangle on the seat ring. Each plastic tab lining the edge of the cloth seat attaches to a peg on the seat ring. Snap these connections into place.
    • 6 Hold the Exersaucer tray on its side and press the seat ring into the center. Once the seat ring snaps into place, it should be able to spin in place.
    • 7 Attach the three spring caps to the Exersaucer tray. These spring caps cover the three large holes in your tray, and are attached by a firm clockwise twist.
    • 8 Attach the upper leg assemblies to the upper leg crowns. These crowns act as the "socket" and the upper leg assemblies act as the "ball." By pressing them together with a click, the upper leg assemblies can twist and rotate in place.
    • 9 Turn the tray upside down and press each upper leg crown base into the round holes in the tray with a firm twist. Each upper leg crown features a height adjustment hole, which will face outward when properly attached.
    • 10 Turn over the tray so that the upper leg assemblies are facing downward. Insert each upper leg assembly into a lower leg assembly, being sure to pull away the height adjustment tab to allow the assemblies to slide together.
    • 11 Press each toy into its respective port on the surface of the tray. The toys each have a distinct base, which clicks into the correspondingly shaped tray port
May 10, 2011 | Toys
I have a Maytag Model # LA806-02, which dances across the flor when in the spin mode. Tighting the three centering spring has helped very little.
If your Maytag is dancing across the floor the most common problem is the leveling. If one or more of the feet are not level it ill wobble and walk around the floor. When you level the machine on the top both directions make sure the set nut is tightened so you will not have to retighten it again later.
May 08, 2011 | Maytag Washing Machines
The disc comes up reading only briefly then nothing and does not rotate
put in the disk and remember the direction it was facing then take it out after a few seconds if it has changed then good
simply turn the ps2 uside down and put the disk in and let it read it upside down!!
it worked 4 me!
Mar 16, 2010 | Sony PlayStation 2 (PS2) Console
Kitchenaid Dish Drawer unit is canted forward; I need to get to the back legs to adjust them downward. How do I get to them?
Open the dishwasher door and undo the two screws that secure the face to the counter-top. Open the kickplate and slide the diswasher out of it's hole. You should be able to easily access the back legs now. It may be easier to disconnect the drain and supply hoses (turn off the angle stop first) and flip the dishwasher upside down using a carpenter's level to make sure all your feet line up. Flip it over, reconnect, and reinstall.
Jul 01, 2009 | KitchenAid Dishwashers
Canon DR-9080C Duplex Rotation issue
Scan in portrait mode only. Of course this takes more time as compared to Landscape mode. The top module 'reads' left to right as we see it and the botom module 'reads' right to left, if you look from top. So if you scan in landscape mode and rotate, the back side is rotated by another 90 degrees and hence you see it upside down. If you are using PDF file and have Adobe Acrobat, you can specifically rotate odd or even pages.
S. Mohan, Chennai, India
Jun 23, 2009 | Xerox DocuMate 252 Path-Through Scanner
2002 Honda Odyssey
The tracks may be clean but the rollers can get damaged. I found one door with a roller entirely missing. There are several rollers on each of three brackets; top, middle, and lower. For example, the middle bracket has two rollers which rotate axially in the horizontal direction to track the side of the rail---and a vertical roller to carry the weight of the door on the bottom of the track. If any of these rollers becomes chipped, cracked or simply are missing, you will get grinding noises and bucking problems. Use a strong flashlight and check ALL of the rollers for damage.
Sep 07, 2008 | 2002 Honda Odyssey
How to remove the hard drive for pavilion ze5000?
First and foremost be sure it is off and the battery is removed.
To remove the hard drive on the hp pavilion ze5000 turn the laptop upside down.
On the end of the laptop next to the lid release is the hard drive.
It is secured by three screws.
Two are in plain site remove them as well as the hidden one.
With the laptop upside down facing you there is a rubber stop directly above the hood release switch.
Pry it out with a precision, very small, flat blade screw driver. After the rubber piece is removed unscrew the screw that it was hiding.
With the three screws removed you should be able to pull/slide the hard drive out.
Feb 18, 2008 | HP Pavilion ze5000 30 GB Hard Drive
Upside Down Screen i880
No it is a mechanical problem it hase to be fixed by an authorized serivce center or sent to motorola directly sorry
Oct 27, 2007 | Motorola Mobility i880 Cellular Phone
One Leg has loss it's grip.
take it apart, there is a rubber ring like a belt or rubber band, either broken or missing. you will have to find a relacement for that, may have to take apart another leg to have one to compare, course I don't honestly know where you will find that piece. too take it apart just keep spinning the lock counterclockwise until it comes off. good luck.
May 26, 2007 | Velbon Ultra MAXi Tripod
Horizon T91 Treadmill Logo
27 people viewed this question
Top Horizon Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Matt Olenzek
Matt Olenzek
Trevor Turner
Are you a Horizon Exercise and Fitnes Expert? Answer questions, earn points and help others
