Question about Bosch AHS 48 Li Cordless Hedge Trimmer
Cannot maintain cutting action - Bosch AHS 48 Li Cordless Hedge Trimmer
My 88hp Johnson won't tilt up when moving in water unless I am going slow therefore I can't get topend speed what would cause this?
outboard motors some times are designed to not run at speed while tilted as the water pump inlet is above the water line and the engine will over heat and the pump impellor will be destroyed.. With an engine tilted the load from the propeller tends to lift the nose of the boat high and makes it unstable on the water . The best situation is to have the propeller tend to drive the nose down thereby promoting a planeing action that improves economy and speed Once the boat is on the plane you can cut back on the throttle and still maintain the same speed . Moving with the leg tilted should only be used to navigate shallow water at very slow speeds
Jan 26, 2014 | Cars & Trucks
Tried to adjust my HP620 screen brightness using "fn" f3 failed
HP Support Assistant can perform an analysis of your computer to keep your computer up to date and give you alerts and tips from HP by using the Maintain tool. Click to download the latest version of HP Support Assistant . The Maintain tool can help you complete the following actions:
  • Health Analysis , examines the computer system and lets you know about the latest drivers to maintain the health of your computer.
  • Software Updates , gives you updates to you software to avoid any problems.
  • Usage Tips , updates you with the latest alerts and tips from HP.
  • Automated Tune-up , a tune-up can be scheduled periodically maintain your computer automatically.
Dec 06, 2011 | HEWLETT-PACKARD 620 XT964UT Notebook PC
What should cut in and cut out on low pressure control be when used as a tstat
85# cut-in and 65# cut-out to maintain 38f in the fresh food section
32#cut-in and 8#cut out to maintain 0f to 5f in the freezah.
See page 7
Get all rest parts 24 hours at day at partstown.com
Apr 06, 2011 | Delfield F2987C
Levelor fails to maintain proper water level
clean the sensor if dirty or slimy it will send false information
May 19, 2010 | Jandy Levolor Water Leveling System - Fill...
Is it normal that A/C compressor clutch work sometimes andstopped
If you have auto air the clutch on the compressor will cut on and off as the inside temp of car change.normal.
If the system isn't cooling good the clutch will cycle on and off if it is low on freon.
May 27, 2009 | 1996 Mercury Grand Marquis
Blade misalignment
The 1590, like several Bosch jigsaws, has a selector switch to choose the type of cutting action. You have to choose the appropriate cutting action, either straight or oscillating, to accommodate the material you cut and the blade you cut with. For instance, if using a very slender blade for clean curved cuts in wood, a slight oscillating motion ( setting II or III) reduces friction on the blade.
If you choose the straight cutting action you get maximum accuracy, but drastically increase the friction because the blade is held firmly to the roller bearing.  A slender blade can handle that for brief periods, (say... less than thirty seconds) in soft, thin wood with a straight cut. In hard woods or engineered wood products ( plywood, MDF etc.) the thin blade will heat up and bend.
You can reduce friction by choosing an oscillating cutting motion, or you can use a larger, sturdier blade. The "Aggressor" blades do not cut as smoothly as the "clean" blades, but they cut faster and are stronger. To cut thick wood ( 4x4 ) or a long cut in engineered material, that is the blade I use. Select number III or number II for 'type-of-cut' and use a bigger blade. See if that stops the "bucking."
Mar 24, 2009 | Bosch 1590EVSK 6.4 Amp Top Handle Jigsaw
Class action
Did you maintain the computer?
Did you have over 15% free space left on the hard Drive?
I missed this issue you posted.
Did you defragment the computer regularly?
Feb 01, 2009 | Acer Aspire L100 PC Desktop
Clippers jam and won't cut when trying to use attachments
OIL THE CLIPPERS AND CLEAN THE HAIR OUT REALLY GOOD.
Jan 11, 2009 | Oster 76076-010 Hair Trimmer
Bosch AHS 48 Li Cordless Hedge Trimmer Logo
27 people viewed this question
Top Bosch Garden Experts
roeb
George Merkley
George Merkley
Are you a Bosch Garden Expert? Answer questions, earn points and help others
