Question about Grundfos MQ3-45 1 HP Pressure Booster Pump
Noise in pump
Grundfos mq3-45
2 Suggested Answers
  • 44411 Answers
SOURCE: My house pump is just making a humming noise when I turn it on?
replace the start/run capacitor on the pump
any electric motor repair shop will have a suitable replacement
Posted on Apr 12, 2017
Apr 12, 2017 | Grundfos Plumbing
No water
Does the motor turn it self off after a couple of minutes of no pumping?= ran out of water. If there is water up to the pump and still no water, check filter/s ( if there is any). Undo V band and check pump internals, impeller may be broken from shaft? When putting back together tap V band with block off wood or back of screw driver evenly as you do up the clamp to stop it distorting
Apr 14, 2014 | Grundfos Pumps Grundfos MQ 3-45 1 HP...
Grundfos pump
Louise, since there is several different types and models of Grundfos pumps it would be hard to answer your question. To possible point you in the right direction below are a few links to where you can find some PDF documentation about a popular Grundfos pump the MQ series and direct link to the manufactures "Service Support".
Service support
Grundfos MQ Series Pumps
Feb 07, 2014 | Garden
The circulation pump making noise.
Question posted under Grundfos recirculation system.
If pump is making noise, then air or sediment is probably trapped at the impeller.
Remove pump, and connection between hot-and-cold pipes and clean with white vinegar.
Or use CLR but do not soak parts in CLR or it can cause damage.
Additional Resources:
http://waterheatertimer.org/Water-heater-recirculation-system.html
Take a moment and rate answer:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Sep 06, 2011 | Grundfos Comfort System Recirculator ...
My Grundfos central heating pump is making all sorts of noises since I drained the system to replace a radiator valve. Any suggestions how to fix?
Did you bleed all air from the heating system after replacing the valve?
Did you bleed several times?
Gary
Apr 25, 2011 | Grundfos Plumbing
A friend has a grundfos comfort hot wter recirc system and is getting a chatter or water hammer noise at night after the toilet is flushed.he tells me it sounds like it's coming from under the counter...
1) Unplug grundfos and see if same problem occurs.
2) Noise can be cause by water not flowing freely.
Disassemble parts and clean with CLR (calcium lime rust).
3) Any time there is a humming sound, it can be the motor.
I would also use CLR and clean out Grundfos pump.
4) Any pump or motor that slows down, is overheating, and burn out.
Add a comment for more free help.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Mar 06, 2011 | Grundfos Comfort System Recirculator ...
Pump started to make a rattling noise after 4 yes of perfect operation.
Pull off the pump and clean it out.
The noise could be sediment build up causing pump rotor to make noise.
Noise could also be bad bearing or bad rotor.
Noise could be air bubbles in the line.
Once pump motor begins to slow, no mater what the cause, it overheats and begins to burn out.
Many times, once a motor has slowed, it never recovers and spirals downhill and stops working.
There are no repair parts for recirculation pumps.
Following page has general information plus links to Grundfos manuals, installation, and contact.
http://waterheatertimer.org/Water-heater-recirculation-system.html#Grundfos
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on water heater or any do-it-yourself project.
Feb 05, 2011 | Grundfos UP10-16B5/ATLC Comfort Series...
My Grundfos MQ3-35 has become very loud. Does it need lubrication, which has not been done in years? If so, I do I lubricate? Thanks, Ken
The bearings fitted to this pump are lubricated for life - if the noise is bearing related they will need to be replaced. If the noise is not from the bearings you will need to establish the cause - possibilities are:
Cavitation (sounds like frozen peas inside the pump!) caused by restricted suction - check for blocked strainer etc.
Foreign matter in the pump....
Loose impellers
Sometimes a piece of wood or a large screwdriver used as a stethoscope can be very handy in determining where abouts in the pump the noise is coming from.
Given more specific information I can suggest the next course of action.
Good luck
Mike G
Sep 26, 2010 | Grundfos MQ3-35 3/4 HP Pressure Booster...
Grundfos MQ3-45  1 HP Pressure Booster Pump  Logo
83 people viewed this question
Top Grundfos Garden Experts
john h
jasbo
jasbo
Audrey Messer
Audrey Messer
Are you a Grundfos Garden Expert? Answer questions, earn points and help others
