Question about General Electric JEB1860 1100 Watts Microwave Oven
GE microwave JEB1860 light bulb change - General Electric JEB1860 1100 Watts Microwave Oven
4 Suggested Answers
  • 128 Answers
SOURCE: GE PEB1590 microwave oven. Interior light burned
Remove the screws from around the rear of the oven and slide the cabnet off to the rear. You should be able to access the bulb from here.
WARNING: any time you work on a microwave you have to be careful of the capacitor. Unpluge the microwave and discharge the capacitor with a large screwdriver with a plastic handle.
Be careful.
Posted on Dec 31, 2009
heatman101
  • 43501 Answers
SOURCE: GE microwave JEB1860 runs like normal but no
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101 gfsghhgs
Posted on Sep 30, 2010
MicrowaveSvc
  • 9047 Answers
SOURCE: change bulb inside ge pvm1870Sm2SS
You can download GE owner's manuals and installation instructions
here.
The manual will cover bulb replacement.
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
Posted on May 31, 2012
How do you change a light bulb in a ge 1504 wv
Go online about changing light bulbs in microwave ovens they should be able to show you how to install it on You Tube.
Apr 28, 2015 | GE Microwave Ovens
How to change the light bulb
What kind of microwave oven is this? A counter-top model or an over-the-range microwave? Do you have a brand and model number? And which light bulb do you want to replace - the cavity light bulb, or the bottom light(s) of an OTR microwave?
Oct 19, 2014 | Microwave Ovens
Changing interior light bulb on GE jes1289sk
I have had this trouble before but with a different model. There may be a plastic screen inside the microwave that will just pop off exposing the bulb. Now all you will need to do is to find out what type of bulb you will need to change the other bulb. I hope this made things easier on you.
Jul 25, 2013 | Microwave Ovens
Change bulb inside ge pvm1870Sm2SS
here.
May 17, 2012 | General Electric PVM1870SMSS Microwave...
How do you change the light bulb under the microwave?
put the bulb of microwave down . and then install a new bulb on it .before do these .you should turn off the switch .
home light bulbs
May 02, 2012 | GE JVM1650 1000 Watts Microwave Oven
GE microwave JEB1860 runs like normal but no heating. 21 months old. What is causing the no heating.
heatman101 gfsghhgs
Aug 05, 2010 | General Electric JEB1860 1100 Watts...
Light bult in a Microwave oven is burned out.
There should be a panel covering the bulb iside the cookspace with a screw holding it on. Remove screw, cover then bulb.
Oct 12, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Change light on a ge convection microwave
If you can change the bulb there will be some screws on the outside at the back. On some models however you cannot replace the bulb.
Jun 06, 2009 | General Electric Microwave Oven
Can not change interior lightbulb
how do I change the little light bulb on the top to take off the cover what do i need.
Please, lvinci@gmnew.com
Feb 01, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Open Questions:
GE microwave JEB1860 runs like normal but no heating i have a GE microwave JEB1860. it is little over 2 years old and has a problem. The microwave lights/turns/sounds/operates like normal except no heat. Absolutely no heat. Clues are that it started making sound like it was operating, when not being used with the door closed (doesn?t do it anymore.) Also few days ago a cup of milk was overheated and spilled in the oven. And before that many days ago I had a faint suspicion that the oven wasn?t heating fast enough. I used my digital multimeter to probe the following and they all check out right: . I checked both the primary and the door interlock switches and they are inf when door is open and 0 when closed . I didn?t check the monitor interlock since the fuse is still intact . I checked out the transformer. The primary input leads are 0.3-0.4 ohms (the shorted mutimeter probes itself reg 0.2). the filament leads are 0.2 ohms. Both set of leads are open wrt the ground. The high voltage lead registers 82 ohm to the ground (as is in the circuit diagram.) . the magnetron leads look pristine. They are short between themselves and open to the metal case. This also true with the multimeter leads switched. . the diode looked open (both directions) with the diode function on my multimeter but turned out to be not the case. My guess is that the 2v that my multimeter puts out is less than the cut-in voltage of the diode. In any case it is confirmed that this is not the problem because I replaced it and the heat isn?t there still. . the capacitor measures 959nF as is stated in the circuit diagram. Also the ohmmeter registers increasing voltage until it matches resistance of the 10Mohm internal discharge resister. . the temperature sensor is closed (0.2 ohm) so fine . humidity sensor tested fine as mentioned in the service pamphlet left inside the oven. (the inter-terminal resistances were not exactly as what was mentioned but seemed close enough) any thoughts on what might be wrong?
Feb 27, 2017 | General Electric JEB1860 1100 Watts...
General Electric JEB1860 1100 Watts Microwave Oven Logo
Top General Microwave Ovens Experts
William Miller
William Miller
ken skalski
john h
Are you a General Microwave Oven Expert? Answer questions, earn points and help others
